tortron Posted February 2 Report Share Posted February 2 Kero and a rag and several hours of hate 2 Quote Link to comment Share on other sites More sharing options...
Beaver Posted February 2 Report Share Posted February 2 52 minutes ago, Alfashark said: What does the OS hive-mind recommend for removing a shitload of tar from alloys/lower door sections that won't root the paint? Road works crew went overboard on a couple of km yesterday, laying down a good 75mm of extra chip above the tarred surface which has left me with a few extra kg of wheel weights and the black shitty mess everywhere. I've had good results with the CRC bug and tar remover 1 Quote Link to comment Share on other sites More sharing options...
Alfashark Posted February 2 Report Share Posted February 2 Thanks lads, I have kero and I'll grab a can of the CRC stuff while I'm out on Friday. Quote Link to comment Share on other sites More sharing options...
datlow Posted February 2 Report Share Posted February 2 Ring council and Karen them into a free grooming 2 1 Quote Link to comment Share on other sites More sharing options...
cletus Posted February 2 Report Share Posted February 2 Crc 556 works too I think? Years ago I had a mint r32 gtst coupe I went though some concrete splashes that there was no sign for When I washed the car a week later I discovered that it wasn't mud That really ripped my undies That car was a magnet for damage 2 Quote Link to comment Share on other sites More sharing options...
Alfashark Posted February 2 Report Share Posted February 2 44 minutes ago, datlow said: Ring council and Karen them into a free grooming It's been well swept during the day, probably by every cunt flying down the hill and around the bend into the zone while ignoring the signs... Quote Link to comment Share on other sites More sharing options...
ThePog Posted February 11 Report Share Posted February 11 So I have an 80w solar panel, a suitable solar controller and various batteries, ie a smallish sealed gel type and old car batteries. I am thinking of buying a thermoelectric cooler to keep my beersies cold while camping. I can set the cooler to run off this sort of setup i guess, but I'm wondering about adding functionality by replacing the battery with a decent jump pack, then it will be charged all the time, will run the cooler but could be used as a jump pack. Is this a dumb idea? Quote Link to comment Share on other sites More sharing options...
mjrstar Posted February 11 Report Share Posted February 11 You know the jump pack is an expensive plastic box with some leads coming out the top and a sealed agm battery inside yeah? 1 1 Quote Link to comment Share on other sites More sharing options...
ThePog Posted February 11 Report Share Posted February 11 5 minutes ago, mjrstar said: You know the jump pack is an expensive plastic box with some leads coming out the top and a sealed agm battery inside yeah? Yea I guess when you put it like that. I had yet to make the logical connection that I could use a start battery as a...... jump battery. Thank you. Quote Link to comment Share on other sites More sharing options...
JustHarry Posted February 20 Report Share Posted February 20 Ended up with this. 50x100 welded onto the channel to hold the coupling and jockey wheel. Plated underneath with some 6mm under the join. Will run some 25x25 rhs underneath as a brace right up to under the coupling. Should stiffen it right up. 3 Quote Link to comment Share on other sites More sharing options...
SOHC Posted February 23 Report Share Posted February 23 Whats going on here? Quote Link to comment Share on other sites More sharing options...
tortron Posted February 23 Report Share Posted February 23 Corona stain. Oil in the air burns on to it Quote Link to comment Share on other sites More sharing options...
SOHC Posted February 23 Report Share Posted February 23 21 minutes ago, tortron said: Corona stain. Oil in the air burns on to it Is the lighting escaping? Quote Link to comment Share on other sites More sharing options...
tortron Posted February 23 Report Share Posted February 23 those two dark patches are burnt or are they smoo? you might have arcing from the boot happening or soemthing as well Quote Link to comment Share on other sites More sharing options...
SOHC Posted February 23 Report Share Posted February 23 27 minutes ago, tortron said: those two dark patches are burnt or are they smoo? you might have arcing from the boot happening or soemthing as well Yes the 2 dark patches are burnt, I am thinking of getting a new coil, this coil came with the ignition module and its hard on ignition components Quote Link to comment Share on other sites More sharing options...
SOHC Posted February 23 Report Share Posted February 23 It actually looks like that plug has a hair line crack in the insulator 2 Quote Link to comment Share on other sites More sharing options...
GregT Posted February 23 Report Share Posted February 23 Not unknown for the porcelain to come loose from the body of the plug. You tend to get stains around the joint when it happens. 2 Quote Link to comment Share on other sites More sharing options...
SOHC Posted February 23 Report Share Posted February 23 34 minutes ago, GregT said: Not unknown for the porcelain to come loose from the body of the plug. You tend to get stains around the joint when it happens. I have seen alot of champion plugs do that Quote Link to comment Share on other sites More sharing options...
tortron Posted February 23 Report Share Posted February 23 Sounds like you work for Big Plug Cease your investigations! 1 3 Quote Link to comment Share on other sites More sharing options...
cletus Posted February 27 Report Share Posted February 27 Electrical question. if I'm using fused relays, do I need to run circuits through a fuse box first? Would prefer this for simplicity. Or is it better to use regular relays and a separate fuse box? Will use relays for fuel pump/fans/ignition box /etc Quote Link to comment Share on other sites More sharing options...
