Roman
On 31/03/2024 at 20:30, NickJ said:
Also those are very nifty relays that I really should have on a few cars.... But I won't actually be needing because I'm going to put efi on everything and live like a boss.
  • Haha 1
  • Replies 6.1k
It's not optimum - but it does work.  The flat 6 won't have a lot of overlapping vacuum so distribution should be good enough. From experience with a 36/36 Weber on a hot 202, the volume of the main log of the manifold is fairly critical. Too small and the ends starve. Too big and response goes away.
On 10/04/2024 at 15:54, yoeddynz said:
Some fella from the group commented on the photo and said two carbs are for primary fueling, the others for secondary.
Seems a bit complex? :scratch:
No worse than pontiac tri-power.
ah, I think I probably do... I just saw "sohc 4g63" and figured it was the old model but of course they probably kept building them forever.
Oh well now i have a set of new TTY bolts on the way, I suppose I'll use them - the engine was rebuilt not that long ago, can't be sure that the head bolts that went in at that time weren't TTY too
