kyteler Posted May 17, 2016 Share Posted May 17, 2016 They didn't show the afr on the 3" run either. Quote Link to comment Share on other sites More sharing options...
xsspeed Posted May 17, 2016 Share Posted May 17, 2016 What are they hiding 1 Quote Link to comment Share on other sites More sharing options...
kyteler Posted May 17, 2016 Share Posted May 17, 2016 Probably nothing. Likely just editing constraints. Quote Link to comment Share on other sites More sharing options...
Beaver Posted May 17, 2016 Share Posted May 17, 2016 Guys. Bigger is better ok. A Greek told me 1 Quote Link to comment Share on other sites More sharing options...
UTERUS Posted May 17, 2016 Share Posted May 17, 2016 Supertrapps for everyone 1 Quote Link to comment Share on other sites More sharing options...
Mr Vapour Posted May 17, 2016 Share Posted May 17, 2016 fryburger says it in his opening line, they are putting 620 odd horse power through the muffler. even in a twin system that would still be 300 per bank and way over what most expect, IM only going to have 220-240hp and many more of us are wishing to even see over 200. its very different looking at a big power 8 and a 4age, or a 1600 crossflow or in my case a 6cyl bmw 1 Quote Link to comment Share on other sites More sharing options...
yetchh Posted May 18, 2016 Share Posted May 18, 2016 They didn't use an x pipe either.. Quote Link to comment Share on other sites More sharing options...
kyteler Posted May 18, 2016 Share Posted May 18, 2016 fryburger says it in his opening line, they are putting 620 odd horse power through the muffler. even in a twin system that would still be 300 per bank and way over what most expect, IM only going to have 220-240hp and many more of us are wishing to even see over 200. its very different looking at a big power 8 and a 4age, or a 1600 crossflow or in my case a 6cyl bmw It's not actually that much different, have a look through kprs thread, he's done quite a bit of exhaust system fluffing about. Quote Link to comment Share on other sites More sharing options...
kpr Posted May 18, 2016 Share Posted May 18, 2016 It depends how you get to said hp number.  Pity they didn't do the runs on something with a more aggressive cam/s.  But still, you can see how the open header comes on power sooner, in the 3500-4000rpm range.   Everything i have tired on 4age junk is basically the same. No big gains up top, but big losses as it comes on power in lower mid range with exhaust restriction.  more cam overlap the worse it gets.  So now you can throw away your little restrictive exhaust. put that 3" on and go to the next size up cams. have the same powerband and more top end.     its totally different on something that doesn't run much/any cam overlap. (most stock engines & turbo stuff) exhaust can be smaller.  with exhaust restriction losses will more likely be at max hp, when the most flow is required. 3 Quote Link to comment Share on other sites More sharing options...
yetchh Posted May 18, 2016 Share Posted May 18, 2016    with exhaust restriction losses will more likely be at max hp, when the most flow is required. Yeah you can def see both the 2.5 and 3 loose a few hp over opens right up the very top Quote Link to comment Share on other sites More sharing options...
M.H. Posted June 8, 2016 Share Posted June 8, 2016 I need to make an exhaust for my audi. It originally had a 20v turbo 5cyl and now has a 4.2 40v v8. The original exhaust is a twin pipe 2.25 inch. Im wanting to make it 2.5 inch. Does anyone have any recommendations for a twin inlet and outlet mufflers? Quote Link to comment Share on other sites More sharing options...
xsspeed Posted June 8, 2016 Share Posted June 8, 2016 If I have learned anything from this thread, its that you need 3" 1 Quote Link to comment Share on other sites More sharing options...
M.H. Posted June 9, 2016 Share Posted June 9, 2016 If I have learned anything from this thread, its that you need 3" It will be twin 2.5 inch. I dont think there will be room for twin 3 inch Quote Link to comment Share on other sites More sharing options...
Muncie Posted June 10, 2016 Share Posted June 10, 2016 Flowmaster 40 series mufflers! Probably others that flow slightly better but will sound utterly amazeballs in twin 2.5 inch. Quote Link to comment Share on other sites More sharing options...
mjrstar Posted June 10, 2016 Share Posted June 10, 2016 I need to make an exhaust for my audi. It originally had a 20v turbo 5cyl and now has a 4.2 40v v8. The original exhaust is a twin pipe 2.25 inch. Im wanting to make it 2.5 inch. Does anyone have any recommendations for a twin inlet and outlet mufflers?  40 valves! imagine replacing the stem seals and setting clearance in that...   depending on your budget and packaging requirements you could consider some second hand Fg xr6 turbo falcon ute mufflers these are twin in and out, and flow well on a boosted 4 litre. often these are removed for "performance" upgrades but these are fine at over 350 wheel KW, my ute runs 22+psi on the fatory rear half of the sytem (does have a bigger dump pipe and cat)  http://www.gumtree.com.au/s-ad/aberfoyle-park/engine-engine-parts-transmission/ford-falcon-fg-ute-turbo-2008-on/1084126623  not in NZ I know but gives you an idea of what they look like. 2 Quote Link to comment Share on other sites More sharing options...
M.H. Posted June 12, 2016 Share Posted June 12, 2016 This is the original exhaust. It weighs almost a ton Quote Link to comment Share on other sites More sharing options...
M.H. Posted June 13, 2016 Share Posted June 13, 2016 How many mufflers should I use? Needs to be legal but not too quiet Quote Link to comment Share on other sites More sharing options...
UTERUS Posted June 13, 2016 Share Posted June 13, 2016 A supertrapp for each pipe 1 Quote Link to comment Share on other sites More sharing options...
M.H. Posted June 16, 2016 Share Posted June 16, 2016 A supertrapp for each pipe Just googled them up. They look ugly as fuck. 1 Quote Link to comment Share on other sites More sharing options...
morkster Posted June 16, 2016 Share Posted June 16, 2016 It will be twin 2.5 inch. I dont think there will be room for twin 3 inch I'm thinking full twin 2.5" (with crossover), with a Dynomax Superturbo muffler in each pipe, placed about where each of your current mufflers are placed. Quote Link to comment Share on other sites More sharing options...
