Yowzer Posted October 1, 2014 Share Posted October 1, 2014 Yup that's the main thing, them old V5s don't have the greatest resolution so tuning idle / low throttle driving gets more difficult. Ideally you want the injectors to be running around 80% at full noise, although with a better ECU you'd have more res to play with so could get away with larger injectors much more happily. In any case, they'll still work fine. Quote Link to comment Share on other sites More sharing options...
Rookie Posted October 1, 2014 Share Posted October 1, 2014 Any tips on getting fuel injectors to seal in the rail? Quote Link to comment Share on other sites More sharing options...
Stu Posted October 1, 2014 Share Posted October 1, 2014 You wont have any issues with 560's on a v5, ran bigger than that on a few setups and had no issues with idle/cruise etc 1 Quote Link to comment Share on other sites More sharing options...
Rookie Posted October 1, 2014 Share Posted October 1, 2014 That doesn't help me. 1 Quote Link to comment Share on other sites More sharing options...
Vintage Grumble Posted October 1, 2014 Share Posted October 1, 2014 Any tips on getting fuel injectors to seal in the rail? Â Are they just bottom feed ones with an o-ring that pops into a recess in the rail? Quote Link to comment Share on other sites More sharing options...
Rookie Posted October 1, 2014 Share Posted October 1, 2014 Yes, I have a fuel fountain currently. 1 Quote Link to comment Share on other sites More sharing options...
Spencer Posted October 1, 2014 Share Posted October 1, 2014 Use o-rings. 2 Quote Link to comment Share on other sites More sharing options...
Vintage Grumble Posted October 1, 2014 Share Posted October 1, 2014 Yeh, what he said. It is easy to damage them when slamming the rail in. The flower brothers should be able to get you fuel proof ones. Quote Link to comment Share on other sites More sharing options...
Rookie Posted October 1, 2014 Share Posted October 1, 2014 Hmm, maybe I shall try new orings, any other suggestions? Quote Link to comment Share on other sites More sharing options...
Spencer Posted October 1, 2014 Share Posted October 1, 2014 I had a buddy down at seal imports and I would just roll down there and hunt the shelves for fatter O-rings until it worked. 1 Quote Link to comment Share on other sites More sharing options...
Vintage Grumble Posted October 1, 2014 Share Posted October 1, 2014 Yeh, there's not much else it could be, unless the rail or injector has a mark in it? Quote Link to comment Share on other sites More sharing options...
Rookie Posted October 1, 2014 Share Posted October 1, 2014 I don't thing so, I will have another look. Quote Link to comment Share on other sites More sharing options...
Rookie Posted October 1, 2014 Share Posted October 1, 2014 But fatter orings sounds like a deal. Quote Link to comment Share on other sites More sharing options...
Spencer Posted October 1, 2014 Share Posted October 1, 2014 You probably know but get viton ones if you can, they handle the fuel and heat betterer. 1 Quote Link to comment Share on other sites More sharing options...
Stu Posted October 2, 2014 Share Posted October 2, 2014 Sometimes you can fit two o rings on the injectors to help seal them Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted October 2, 2014 Author Share Posted October 2, 2014 I had a buddy down at seal imports and I would just roll down there and hunt the shelves for fatter O-rings until it worked. Fatter seals?... 4 Quote Link to comment Share on other sites More sharing options...
Spencer Posted October 2, 2014 Share Posted October 2, 2014 He looks so happy. 1 Quote Link to comment Share on other sites More sharing options...
Yowzer Posted October 2, 2014 Share Posted October 2, 2014 Slap a bit of rubber grease on them so they slide in easier. Helps prevent damaging them and stuff. 1 Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted October 2, 2014 Share Posted October 2, 2014 Measure the size of the injector and the rail. Tell seal imports this and they will give u the correct orings. Bigger isn't better. Correct is better. Also will need lube to install them. Quote Link to comment Share on other sites More sharing options...
Ja1lb8 Posted October 2, 2014 Share Posted October 2, 2014 I think it's more to do with difficulty in controlling super small pulsewidths? As in, your ECU cannot control below 2% opening time. (for example) That might be fine for 350cc injectors as 2.5% pulsewidth gives you correct idle. But 560cc might need 1.5%, which your ECU cant do. Or whatever. Had this exact problem. Think they were 720cc and was using a microtec which is shit and couldnt get it to idle. Put 370cc back in and was all good. Quote Link to comment Share on other sites More sharing options...
