Yowzer Posted October 18, 2014 Share Posted October 18, 2014 Did you also change the enrichment pulse width? I found that made the most difference on my V5. One thing I can't fathom is how the cold start values all work. I'll get there one day. I think I left that the same Yeah the cold start is a bit weird. Still haven't got that right. Quote Link to comment Share on other sites More sharing options...
Rookie Posted October 23, 2014 Share Posted October 23, 2014 Any of you dudes know how to make the rev limiter really noisy and shoot flames? I have it spark cutting at the moment, but I think I am cutting too many spark events or something. Tips? Quote Link to comment Share on other sites More sharing options...
stillway Posted October 23, 2014 Share Posted October 23, 2014 more spark cut, less fuel cut.. more unburnt fuel = more bang ..hows your limiter setup atm? http://www.learntotune.com/discussions/topic/rev-limiters/ 3 Quote Link to comment Share on other sites More sharing options...
kpr Posted October 23, 2014 Share Posted October 23, 2014 don't know if you can do it on ms. but link you can retard the timing when rev limiting. so it starts to spit more fuel out the exhaust and make poser bangs and flames 2 Quote Link to comment Share on other sites More sharing options...
Yowzer Posted October 23, 2014 Share Posted October 23, 2014 Just tweak the timing down on the ign table once it reaches redline Quote Link to comment Share on other sites More sharing options...
Yowzer Posted October 23, 2014 Share Posted October 23, 2014 Pretty sure the MSExtra allows quite a few variations of rev limiter, such as combining ign retarding and cutting every second spark for max fireballs Quote Link to comment Share on other sites More sharing options...
Yowzer Posted October 23, 2014 Share Posted October 23, 2014 Ok it doesn't do the spark thing I said, but here's this 8.3. Rev LimiterClicking Basic/Load Settings > Rev Limiter will display the following screen:From this screen you are able to control settings such as hard rev limit, coolant temperature limit, spark retard,spark cut and fuel cut.8.3.1. Hard Rev LimitHard Rev Limit (RPM)Specifies the rev limiter max RPM (you must also select a rev-limiter type below.)Soft Limit Zone / Hysteresis (RPM)Sets an RPM deadband, soft limiters start this many RPM below the hard limit. If fuel cut is enabled, then theRPMs must fall by this much before fuel is re-enabled. A number of hundred RPM is suggested.8.3.2. Coolant Temp LimiterRev Limiter CLT basedEnables optional coolant based rev limiter, so that the rev limit can be lowered when the engine is cold. The© 2014 James Murray 2014-09-08 Page 73/195Megasquirt-2: TunerStudio MS Lite Reference Guidecurve on the right hand of the screen (or the values for Coolant Temperature and Rev Limits) can be customizedeither by dragging the points on the curve or entering values into the table. This sets the lower 'retard above'limit at your chosen temperatures.Rev Limit TPS Bypass (TPS %)Above this TPS% the coolant curve is ignored. This should be set to a high percentage, so that only in anemergency when you really need full throttle on a cold engine can you override the cold limit. Or set to over100% so that the limit in the curve is always used whatever the throttle position.RPM When In TPS Bypass (RPM)Rev limit when the TPS bypass limit has been passed.8.3.3. Spark RetardSpark Retard ModeThere are four options for spark retardation to limit revs:• Off – no spark retard used;• Progressive retard – timing is progressively retarded above the set RPM;• Fixed angle – above the set RPM the timing is immediately changed to this angle.Maximum Retard (deg)Maximum timing retard.Retard To (deg)Timing value used in fixed angle.8.3.4. Spark Cut and Fuel CutEnable Spark Cut LimitingEnables spark-cut limiting (will not work with EDIS, TFI or GMDIS.)If enabled this option can cause catalyst damage and is noisy in operation.Enable Fuel Cut LimitingWhether fuel-cut rev limiting is enabled.Progressive Fuel CutEnables a progressive non-rotational fuel cut that drops cylinders as revs rise between the lower and hard fuelcut limits. Requires Sequential/Semi-Sequential.This option must not be used with staged or throttle-body injection. Quote Link to comment Share on other sites More sharing options...
UTERUS Posted October 23, 2014 Share Posted October 23, 2014 Would it be ghetto to change the cells at/around rev limit to a fairly retarded timing number and adjust to suit desired fire level? Quote Link to comment Share on other sites More sharing options...
Rookie Posted October 23, 2014 Share Posted October 23, 2014 Ok, this is what I have at the moment/to play with. So if I change the spark retard mode to "Fixed" and say "-10" will that give me poser flames? Quote Link to comment Share on other sites More sharing options...
Rookie Posted October 23, 2014 Share Posted October 23, 2014 Next question, how much extra fuel do I have to add to the high rpm/low load cells for epic flames on over run? 20% Quote Link to comment Share on other sites More sharing options...
Yowzer Posted October 23, 2014 Share Posted October 23, 2014 Most probably. Tweak the fuel cells to dump in heaps of extra fuel too, and report back. 1 Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted October 23, 2014 Author Share Posted October 23, 2014 Such fun ! My question today. I realise each engine is different but what sort of cruise afrs do you fellas aim for. Let's say 4 or 5th gear at 50 kph on the flat. I notice when I go too lean it starts hunting so I'm around low 15s. I wonder what factory ecus aim for. Quote Link to comment Share on other sites More sharing options...
Rookie Posted October 23, 2014 Share Posted October 23, 2014 If you are at low 15s you are doing pretty well in my book, that should keep the Scotsman in you happy... 1 Quote Link to comment Share on other sites More sharing options...
Testament Posted October 23, 2014 Share Posted October 23, 2014 10:1 everywhere 3 Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted October 23, 2014 Share Posted October 23, 2014 Such fun ! My question today. I realise each engine is different but what sort of cruise afrs do you fellas aim for. Let's say 4 or 5th gear at 50 kph on the flat. I notice when I go too lean it starts hunting so I'm around low 15s. I wonder what factory ecus aim for. Just go as lean as you can before you notice it. My escort (turbo pinto) does about 15.5 at 100kph in top and about 16.5 at about 50kph in 4th. Never go that lean under load obvisously and you need the accel enrich to be pretty good to make it wake up nicely 1 Quote Link to comment Share on other sites More sharing options...
Spencer Posted October 23, 2014 Share Posted October 23, 2014 Old bore wash Tommy at it again. I was PMing JasonK about tuning his Q-jet last night. Apparently it is running 9:1 on the secondaries, sweet economy. I aim for as low as possible Alex, usually ends up around the low 15's. Its very motor specific though stuff with way better heads/combustion/fuel mixing can usually go leaner. 2 Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted October 23, 2014 Author Share Posted October 23, 2014 Yeah I figure that until I activate the AE I can't go lower. I'm hoping with AE on and tuned I can go that bit lower and still have a nice cruise with out it bogging when I apply gentle throttle. Someone on here ages back mentioned I shouldn't ever have it sitting exactly on 14.7 ? Don't know why? Something about it being a dangerous place?!!! Quote Link to comment Share on other sites More sharing options...
Spencer Posted October 23, 2014 Share Posted October 23, 2014 Lies. Quote Link to comment Share on other sites More sharing options...
Rookie Posted October 23, 2014 Share Posted October 23, 2014 It is a dangerous place if you have something against making NOx though hahaha Quote Link to comment Share on other sites More sharing options...
Rookie Posted October 23, 2014 Share Posted October 23, 2014 Also why don't you have AE turned on? I can't even get my car to come off idle without it (it might be something to do with the slides though) Quote Link to comment Share on other sites More sharing options...
