Yowzer Posted December 7, 2017 Share Posted December 7, 2017 Pretty sure you can buy an off-the-shelf reluctor conditioning module for stuff all, which would.make installation easier Edit: I take that back. I couldn't find any. Possibly using the wrong search terms Quote Link to comment Share on other sites More sharing options...
kpr Posted December 7, 2017 Share Posted December 7, 2017 the cherry ones i used are pretty small, only 25mm long. same body diameter as the pink 60mm long version. that most people seem to use https://sg.rs-online.com/web/p/hall-effect-sensors/3076224/ https://sg.rs-online.com/web/p/hall-effect-sensors/7659321/ i couldnt find any useful vr sensors. the hall gives a better output anyway. just vr can handle more heat Quote Link to comment Share on other sites More sharing options...
NickJ Posted December 7, 2017 Share Posted December 7, 2017 3 minutes ago, Firetruck said: Pretty sure you can buy an off-the-shelf reluctor conditioning module for stuff all, which would.make installation easier Edit: I take that back. I couldn't find any. You're correct, the circuit is simple, but my logic is the hall effect requires no additional gizmos, simpler and initially one less thing to worry about. 1 Quote Link to comment Share on other sites More sharing options...
kws Posted December 7, 2017 Share Posted December 7, 2017 This is the VR conditioner i use on my board and works mint https://speeduino.com/shop/index.php?id_product=17&controller=product I use a mondeo sensor, PN 928F6C315A1F Quote Link to comment Share on other sites More sharing options...
Ash Kelly barr Posted December 29, 2017 Share Posted December 29, 2017 Re MS is there anyone in Auckland with megasquirt experience I can come bring all my shit to for help? got it built, got it connected to tuner studio so ports setup, db9-USB works, and tuner sees it as an ECU. tried to load up firmware, followed all the steps (jumper boot etc) it went threw all the steps and says it's loaded all the code lines into the pcb. once it's written them says download failed, and response of (boot< response: what) press any button to continue, do that and the window closes. ive now tried again and the ECU isn't powering up. I've got a board built I use for powering up PLC's for work so it's a reliable supply. power it up, LED doesn't light up for two seconds any more, and I can't connect anymore. if there's anyone with a lot of experience that can help please get in touch, I'm not far off throwing it in the bin haha 0212666684 Quote Link to comment Share on other sites More sharing options...
Ash Kelly barr Posted December 29, 2017 Share Posted December 29, 2017 To add to that ^ when powered up and led no longer comes up. I still have 5V where I should Quote Link to comment Share on other sites More sharing options...
Yowzer Posted December 30, 2017 Share Posted December 30, 2017 Some decent wedge of info on race spec loom construction https://www.rbracing-rsr.com/wiring_ecu.html 2 Quote Link to comment Share on other sites More sharing options...
Transom Posted December 30, 2017 Share Posted December 30, 2017 Some interesting reading there really liked their eat shit and die section at the bottom https://www.rbracing-rsr.com/eatshit.htm 1 Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted December 31, 2017 Share Posted December 31, 2017 On 12/29/2017 at 22:12, Ash Kelly barr said: Re MS is there anyone in Auckland with megasquirt experience I can come bring all my shit to for help? got it built, got it connected to tuner studio so ports setup, db9-USB works, and tuner sees it as an ECU. tried to load up firmware, followed all the steps (jumper boot etc) it went threw all the steps and says it's loaded all the code lines into the pcb. once it's written them says download failed, and response of (boot< response: what) press any button to continue, do that and the window closes. ive now tried again and the ECU isn't powering up. I've got a board built I use for powering up PLC's for work so it's a reliable supply. power it up, LED doesn't light up for two seconds any more, and I can't connect anymore. if there's anyone with a lot of experience that can help please get in touch, I'm not far off throwing it in the bin haha 0212666684 @downtrail can probably help. but i imagine hes close his shop up over the break period Quote Link to comment Share on other sites More sharing options...
downtrail Posted January 1, 2018 Share Posted January 1, 2018 On 29/12/2017 at 22:12, Ash Kelly barr said: Re MS is there anyone in Auckland with megasquirt experience I can come bring all my shit to for help? got it built, got it connected to tuner studio so ports setup, db9-USB works, and tuner sees it as an ECU. tried to load up firmware, followed all the steps (jumper boot etc) it went threw all the steps and says it's loaded all the code lines into the pcb. once it's written them says download failed, and response of (boot< response: what) press any button to continue, do that and the window closes. ive now tried again and the ECU isn't powering up. I've got a board built I use for powering up PLC's for work so it's a reliable supply. power it up, LED doesn't light up for two seconds any more, and I can't connect anymore. if there's anyone with a lot of experience that can help please get in touch, I'm not far off throwing it in the bin haha 0212666684 Hey mate. Yes i can take a look for you if youd like. Get in touch via facebook page. Www.facebook.com/cole.customs Quote Link to comment Share on other sites More sharing options...
Ash Kelly barr Posted January 1, 2018 Share Posted January 1, 2018 57 minutes ago, downtrail said: Hey mate. Yes i can take a look for you if youd like. Get in touch via facebook page. Www.facebook.com/cole.customs Cheers dude. I spoke with jarred for MS NZ and I've ended up sending it to him to run diag and figure out what's going on. appreciated the offer though dude Quote Link to comment Share on other sites More sharing options...
h4nd Posted January 10, 2018 Share Posted January 10, 2018 @Ash Kelly barr please do let us know, I like learning what can happen with this stuff. Ta. Quote Link to comment Share on other sites More sharing options...
Ash Kelly barr Posted January 10, 2018 Share Posted January 10, 2018 7 hours ago, h4nd said: @Ash Kelly barr please do let us know, I like learning what can happen with this stuff. Ta. Sent it jarred at Megasquirt NZ. He successfully loaded up the data but has trigger input and some other issues. Time to fix it will cost money and TBH I'm pretty over it. so if anyone wants to buy it make an offer before I throw it in the bin cheers Quote Link to comment Share on other sites More sharing options...
NickJ Posted January 11, 2018 Share Posted January 11, 2018 22 hours ago, Ash Kelly barr said: Sent it jarred at Megasquirt NZ. He successfully loaded up the data but has trigger input and some other issues. Time to fix it will cost money and TBH I'm pretty over it. so if anyone wants to buy it make an offer before I throw it in the bin cheers I'd be keen to have a poke at troubleshooting it, I assume there are circuit diagrams about? Quote Link to comment Share on other sites More sharing options...
Ash Kelly barr Posted January 11, 2018 Share Posted January 11, 2018 3 hours ago, NickJ said: I'd be keen to have a poke at troubleshooting it, I assume there are circuit diagrams about? No worries. I've got in touch with another bloke for a second option so I'll see what comes of that and if nothing I'll pm you Quote Link to comment Share on other sites More sharing options...
Roman Posted January 17, 2018 Share Posted January 17, 2018 So as per arduino thread I've been building a tuning box thingy where I can adjust some knobs to optimise fuel, ign timing, vvti, and injector timing (or whatever else) One thing I have been considering though is that I've currently got a goal AFR in the lean areas of around 15.2:1, I cant remember my rationale for this but it was probably because I was too chicken to run it leaner for starters, and this was as far as I migrated from 14.7:1 at low load before getting distracted by something else. So, I might try lean it out further from here. One issue that I have considered though, is that when you run a really lean goal AFR the burn speed slows down a lot so you need more ignition timing. So that's great, except for if you now get a momentary rich region for whatever reason you're now possibly into knock territory. So what I have been thinking is that I will set a goal AFR in a few key cells in the cruising region with a 14.7:1 (or maybe slightly richer) goal AFR and optimise the ignition timing. Then I will do the same again at a 16.2:1 goal AFR. This will need a lot more ignition timing. Then I will compare the differences to build an ignition trim overlay map that has AFR reading as one of the axes. So if the car ends up running richer, it pulls the timing back out towards whatever my 14.7:1 value was, so its always safely running the optimum torque from the engine. Will be interesting to see how much timing change the car wants over this span, I might push out the extremities a bit further and use 13.5 or something like that. 2 Quote Link to comment Share on other sites More sharing options...
peteretep Posted January 17, 2018 Share Posted January 17, 2018 do you know what modern cars afr/timing tables look like? could also be a good comparison In my mind, some modern cars are running like 18:1 at cruise or even leaner. No basis as to where I got that info from though Quote Link to comment Share on other sites More sharing options...
mjrstar Posted January 17, 2018 Share Posted January 17, 2018 I ran my evo in the mid 16 afr's at low load cruise rpm (between 2600 and 3500 rpm) I believe this helped with turbo spool, but that could have been my imagination. It had 4 or 5 counts of transient knock showing on the datalog when you climbed into the throttle in 5th gear but I never lost any sleep over that. Quote Link to comment Share on other sites More sharing options...
Yowzer Posted January 17, 2018 Share Posted January 17, 2018 18 minutes ago, peteretep said: do you know what modern cars afr/timing tables look like? could also be a good comparison In my mind, some modern cars are running like 18:1 at cruise or even leaner. No basis as to where I got that info from though A lot of modern cars run stratified combustion, where they create a swirl of air/fuel in the centre of the chamber that is close to stoichiometry but out by the cylinder walls is nothing but air. Quote Link to comment Share on other sites More sharing options...
peteretep Posted January 17, 2018 Share Posted January 17, 2018 well OK then, Once @Roman gets his 3D printer up and running, im expecting to see a new head capable of this Quote Link to comment Share on other sites More sharing options...
