Ash Kelly barr
Everything posted by Ash Kelly barr
Cheers heaps dude! I'll be in touch
Fair call. But I haven't exactly finished yet have I
As cool as it looks I haven't done it this way for that reason. i would replace with steal if I had the time or skill, but I don't. That and I've got loads of carbon and epoxi so it's not a huge expense for me either. ive painted it in black epoxi weather seal on the inside to protect the westsystem resin so should last a while. Outer will be filled and sprayed when I get round to respraying the car so no one will even know it's done that way ill give the chicken wire method a google though as that sounds interesting haha
Defiantly haha id love to leave it like this if I could
Ash's 82 AA60 rina of rustic glory
Ash Kelly barr replied to Ashkellybarr's topic in Projects and Build Ups
Been away for work nearly 2 months, fly out again Wednesday. thought I'd make the most of time and fix the last narly bit of rust before it gets worse. my weldings pretty ammo and had some carbon and epoxi sitting around. might order some micro beads to fill the gap between uber and out skin. not sure what I'd need to do to prep for paint on top of that though.. will hit the inside with the black epoxi sealer I used on the inside -
No worries. I've got in touch with another bloke for a second option so I'll see what comes of that and if nothing I'll pm you
Sent it jarred at Megasquirt NZ. He successfully loaded up the data but has trigger input and some other issues. Time to fix it will cost money and TBH I'm pretty over it. so if anyone wants to buy it make an offer before I throw it in the bin cheers
Cheers dude. I spoke with jarred for MS NZ and I've ended up sending it to him to run diag and figure out what's going on. appreciated the offer though dude
To add to that ^ when powered up and led no longer comes up. I still have 5V where I should
Re MS is there anyone in Auckland with megasquirt experience I can come bring all my shit to for help? got it built, got it connected to tuner studio so ports setup, db9-USB works, and tuner sees it as an ECU. tried to load up firmware, followed all the steps (jumper boot etc) it went threw all the steps and says it's loaded all the code lines into the pcb. once it's written them says download failed, and response of (boot< response: what) press any button to continue, do that and the window closes. ive now tried again and the ECU isn't powering up. I've got a board built I use for powering up PLC's for work so it's a reliable supply. power it up, LED doesn't light up for two seconds any more, and I can't connect anymore. if there's anyone with a lot of experience that can help please get in touch, I'm not far off throwing it in the bin haha 0212666684
Not sure what bent the rod. Pre ignition and over reving maybe? couple people have said maybe it's hydro locked? it sat for a while and the head gasket was mint, there wasn't any rust or difference in surface, so dont think it was water. someone suggested a cylinder flooded with fuel witch would seem like a reasonable answer?? see how goes, if it runs and lasts a month I'll be pissing my self with laughter. 6months of daily driving, and I'll be speachless and bragging of my hori engine building ways for years to come.. -
engine front... so the el cheapo 4ageo's bottom engine looked good. full rebuild etc seemed to good to be true, so I pulled the head off to have a look. first glance one of the pistons was far lower (8mm) below deck at TDC. others sitting flush I decided to pull the rod and piston out. turns out it was bent like a banana. however the bearing looked fine, had stated wearing threw the first layer but that could be because rod twisted so rod top end wasn't bending true...? With the bottom end seeming to never be opened aside from gaskets, I decided to take a punt on it and put a spare rod in there and new bearing from some spare pack of king bearings I had sitting there. While I was there I gave the bore a quick resurface with my $30 AliExpress bore honeing tool haha head needed a clean, to remove the blue paint and years of over due oil changes. so I picked up some oven cleaner and hit the wash world on Lincoln rd. once clean, I followed the advice of some old boys, some taking the piss, and some very serious. Going this far and the motor now costing less then $150 I went for it. Sand paper on a sheet of glass... much to my surprise, it worked fucking well. Took it down from 60 grit to 340 grit. ive put my straight edge on it and can't get the feeler gauge under it at all. decided I'll take another punt and run a TRD MLS head gasket haha. ive chucked some ARP head studs in there, and if it doesn't comp test well after a heat cycle I'll pull the head and put a standard copper ring HG in there. im sure it'll run, just no idea for how long haha be a good test of how home job you can go on a cheap motor. https://youtu.be/f5r6FV2D1kw -
Brake calipers rebuilt with new pistons and flywheel skimmed and balanced with new clutch. got ADL to do the lot, $240 for the calipers, $150 for flywheel skim and balance... more then I thought, but they have done a bloody good job. Including machine and painting the calipers. rest of it on the actual car as of late it chaseing oil leaks and keeping it running as my daily. It's defiantly a test of dedication to keep it on the road and driven every day. replaced the dizzy Oring a while back. Still leaked. Pulled the fuel pump (3A is mech off the back of the cam) and made a new gasket. its now leaking FAR less, but it's still dropping oil.. so I still have gaskets to make, and holes to gasket goo.. -
Can't find anything for the ms1, only pages for ms3 on adjusting pots
MS1, v3 board, wasted spark, 36-1 crank. Only used for ign. Ok so I've been told to use the VR circuit for my cherry Hall effect sensor?
Yellow carina for 3A drag wars
Spare shoes from the states. belive it or not it worked out over $500 cheaper to get them from that states then from jap. even though their made in Japan and then shipped to the states... 15x8 +28mm 5.2kg each
Check engine light requirement on motors swaps?? im told of an OEM ecu is used the check engine light in the original dash must work with it..? my car doesn't have an ECU, however it does have a check engine light, witch I assume it is feed from a temp sensor and/or an oil pressure sender..? if I'm swapping from a 3A to 7A and staying carburettor, do I need the check engine light to work like factory? if so, if I'm using a standalone to run ign only but still staying carb. Could this be counted as not using OEM ecu?? cheers in advance
Cheers. Yup was correct. Guy sold me a 4agze one thinking it was a blacktop one. have an actual BT one now
Haha yeah true. Saw sheepers in his ra23 that same day actually seriously though, it does sound epic. Not what I expected from a beetle
Thing sounds awesome dude! Sits low as well
Would ya look at that! Looks like I have the correct flywheel now. still need to get the calipers rebuilt so if anyone can recommend a place or someone to help out it would be hugely appreciated as budget is low Atm -
Stretched its legs today. Guys in the MR2 club asked me to be their chase car with tash on the walkie talkie to the lead car. cracked a mighty one hundred and fourty five kilometres an hour! While the boosted two seaters walked away happily cracking over 200 haha was good to give it a decent couple hours of thrashing though. vented disc's with mintex pads and 5.1 worked awesome! And at one hair pin nearly threw the girls into the dash board. needs more power, RPM and wider tires also finish carpet and get it painted so I don't look like some westie axe murder -
Gearbox is t50 to so won't clear the bellhousing either
I'll get the tape measure out again but yeah I think your right
