DIY Fuel injection thread.
yoeddynz
  • Replies 2.4k
Yes the lean burn 7afe was right till mid 90s i think? One of them used a combustion pressure sensor in the block which is cool. Butttt not stratified so much as a homogenous lean mixture... which is why they ditched it because emissions were awful.
Unlike stratified which is more like a pocket of rich mixture and extra air around the perimiter that i dont think contributes to combustion/emissions in the same way.
Tuning stratified injection with just a lambda sensor sounds like a ball ache!
If you can pump in a mix of CO2 and N2 in place of actual exhaust gas for tuning purposes and then come up with an AFR offset function depending on how much "EGR" is being pumped in to adjust to the actual combustion AFR is then you might be alright.
1 hour ago, Firetruck said:
I'd love to know how you'd tune it in an aftermarket situation. Sounds like a good way of blowing out the top of the pistons.
I think MAF is the answer - if you can quantify the amount of air coming in then you can quantify the fuel, even if its not  a traditional ratio I guess.
But yeah god knows how you'd tell anything from a wideband.
Maybe EGT would earn its keep here.
Lexus and some new Toyotas switch between Otto and Atkinson cycle by keeping the intake valve open until the piston is half way up on the compression stroke. They use a air flow meter that measures air going in and out. The have electronic VVT hubs for wider range of movement.
Interesting!
I've seen that electric VVTI on the 1UR (?) V8.
Oh yeah so that leads me to another thought.
People say that you can reduce pumping losses (and so improve economy) by reducing vaccum amount.
But, you also have compression losses as well. If you have more vaccum, you have less air to compress when the piston comes back up.
I wonder what the balance is here?
Looking at BSFC maps it seems like you can very quickly move up a few isobars by staying away from that very low load area. But then very diminishing gains towards that 80%ish  throttle peak.
But also, by changing AFR or cam timing etc you are changing the shape of the BSFC map as you go. Hmm.
21 hours ago, Firetruck said:
Yup definitely direct inject voodoo, however plenty of manufactures were still achieving it prior to DI. Toyota had lean burn 4AFE and 7AFE engines in the 80s.
And without the need to have a full valve de-coke every 100,000km. I'd been reading recently about how choked up some DI engines are getting from lack of fuel cleansing. Quite amazing how bad some get.
I have a GDI Mitsi Legnum coming in tomorrow with what the owner suspects is a coil pack issue.  Hmmmmmmm. Luckily he only needs the car a while longer and will then flick it off. I'm not even going to touch the inlet.
Its common place in the UK to get your car de-coked now. They use little mirrors and dentist picks etc. How the fuck would one avoid shit dropping in ? I guess a decent vacuum and some luck? That carbon stuff doesnt compress well so it would only take a little bit to be sat on a valve and get squashed against a seat so destroying the seal?
Apparently the later gen BMW minis are terrible with this.
Ha- my dad would laugh. He used to have to do a regular de-coke on his Morris Minor.  Come full circle (except without the leaks)
The diesels are worse. I've cleared out a few 1KDs who had less than half the diameter of the intake remaining. The EGR cakes it full of carbon, and the cakes itself up with carbon, and the the whole system chokes itself. Customers have been blown away with how much power their Hilux makes when it leaves the shop
  • Sad 1
