DIY Fuel injection thread.
yoeddynz
Yup that's the main thing, them old V5s don't have the greatest resolution so tuning idle / low throttle driving gets more difficult. Ideally you want the injectors to be running around 80% at full noise, although with a better ECU you'd have more res to play with so could get away with larger injectors much more happily.
In any case, they'll still work fine.
  • Replies 2.4k
I think it's more to do with difficulty in controlling super small pulsewidths?
As in, your ECU cannot control below 2% opening time. (for example)
That might be fine for 350cc injectors as 2.5% pulsewidth gives you correct idle.
But 560cc might need 1.5%, which your ECU cant do.
Or whatever.
Had this exact problem. Think they were 720cc and was using a microtec which is shit and couldnt get it to idle. Put 370cc back in and was all good.
