63Ragtop Posted November 23, 2021 Posted November 23, 2021 It's spending other people's money the best! Haha, as much as I would like to, this thing can already out drive is terrible drum brakes. Quote
64valiant Posted October 18, 2022 Posted October 18, 2022 @63Ragtop looks like you got yourself some early bus wide fives. Slight different offset to beetle wide fives but will still work. Quote
63Ragtop Posted October 18, 2022 Posted October 18, 2022 Appear to be 5inch wide also. Thanks, actually got a set of 4 plus one other and I have my spare wheel. Quote
Nominal Posted November 17, 2022 Posted November 17, 2022 7 hours ago, 63Ragtop said: Nice if it ran!!! Thanks man. Oh bummer. Hope it's nothing serious. Quote
Lord Gruntfuttock Posted November 17, 2022 Posted November 17, 2022 I feel your despair at a new engine feeling tight, so many questions/emotions/worries. Had that with the Fairmont rotating by hand, had a certain point where it got tight to rotate. Complete anguish till I found I'd left the compression tester in one plug hole... Quote
64valiant Posted November 17, 2022 Posted November 17, 2022 Oh man! Things were looking so good. Hope it's something so small that can be easily fixed. Quote
63Ragtop Posted November 17, 2022 Posted November 17, 2022 Yeah, trying to not let it get me down, pretty ballsy thinking I could build a engine with no formal training and it would start first pop. I'm certainly learning. Quote
j.e.d. Posted November 18, 2022 Posted November 18, 2022 Doing fucking awesome man.. no matter what Quote
yetchh Posted November 18, 2022 Posted November 18, 2022 5 hours ago, 63Ragtop said: Yeah, trying to not let it get me down, pretty ballsy thinking I could build a engine with no formal training and it would start first pop. I'm certainly learning. Yeah bro, fucking nice job. Maybe something to do with your end float/flywheel/rear seal? Or oil pump? Quote
cletus Posted November 18, 2022 Posted November 18, 2022 1 hour ago, yetchh said: /rear seal? Not vw but have had a customer with an old buick? engine that had issues with the old style 'dog turd'/ rope rear main seal being tight as. It siezed when I was doing an exhaust cert on it, which gave me the shits a bit I can't remember what the fix was though so ling post, sorry Quote
tortron Posted November 18, 2022 Posted November 18, 2022 Just now, cletus said: Not vw but have had a customer with an old buick? engine that had issues with the old style 'dog turd'/ rope rear main seal being tight as. It siezed when I was doing an exhaust cert on it, which gave me the shits a bit I can't remember what the fix was though so ling post, sorry You work it in till it fits. I used a ton of oil and a few different sockets, rolling it in till it was a good fit, then new razor blade on the ends to get the correct height Quote
63Ragtop Posted November 18, 2022 Posted November 18, 2022 So far I checked the end float, seems good, 0.012mm. Double checked the pulley wasn't rubbing, checked timing, valve clearance. Strip it down this weekend if I have time, what a ballache. Quote
yetchh Posted November 18, 2022 Posted November 18, 2022 3 hours ago, 63Ragtop said: So far I checked the end float, seems good, 0.012mm. Double checked the pulley wasn't rubbing, checked timing, valve clearance. Strip it down this weekend if I have time, what a ballache. Yeah but better you find it now rather than down the track and really do damage.. Quote
63Ragtop Posted May 9, 2023 Posted May 9, 2023 Monster is fairly straight forward. I think one of these might work? https://www.trademe.co.nz/a/motors/car-parts-accessories/performance/gauges/listing/4121551413 Or this one? https://www.trademe.co.nz/a/motors/car-parts-accessories/performance/gauges/listing/4122943438 For the pressure gauge. Quote
shizzl Posted May 9, 2023 Posted May 9, 2023 Generic barrel type oil pressure sensor should do the trick for the oil pieces (2 wire type), oil temp should use a generic type temp sensor as well usually a single wire. tacho is fairly straightforward with diagrams online, usually: acc + (red) earth (black) light + (yellow) coil - (green) may be a couple of wires on that to change from 4/6/8 cylinder Quote
yoeddynz Posted May 9, 2023 Posted May 9, 2023 wow- what a fucking rollercoaster this has been ! But it's looking pretty sweet man. Quote
sluggy Posted May 10, 2023 Posted May 10, 2023 The autometer senders for the pressure and temp gauges are buried in my treasure trove of broken dreams.... Unfortunately I am over the seas so cant get them too you !! But if you wanted to call into work, I can forewarn the team and they can get you into my lockup. they will be in one of the boxes marked VW shit... Quote
