Everything posted by 64valiant
hello and welcome all. its a sunday and im at work with no trains moving so lets get into this and give you guys the update you havent been waiting nor have been asking for. it was Saturday 2nd of July and time to get some shit done, time to strip the engine and rebuild it. i got sweet bugger all photos of this process as i was on a crunch for time. new crank proceeded to clean all the parts and put it all back together with the new crank. this is as far as we got as we didn't have the balance fan back from ATL balancing. while nothing was open on the Sunday i shot out to @Geophys place and got some welding done, we cut off the heat risers on the exhaust manifold so they wouldn't protruded thought the tin wear any more, and we modified the mustache bar to now fit the new oil pump on it. geophfey been skilled this is what it looked like before hand. we cut the engine mount off as it would interfer with the oil lines and this is what it looked like with it gone this is it on, you can now see the cb performance oil in and out pump in place and the lines interfering with the 3rd engine mount so with that all done and with shops now open on the monday, i picked up the alternator fan. here is a picture of it with added weight for balancing whacked the rest of it together. got a new peace of tin wear which doesn't have the holes cut out for the heat risers as well. looks a bunch nicer not having them in there. quick start up and we are good to go. next up we wait around for my gearbox to be built / finished, ended up getting a date and got @Leebo3 to pick that up for me. smashed down to his place on friday night with @bobby1930 and spun some yarns. box back at home and lets get this done. monday comes around and we are off to the vdubshoppe to smash this back together Gearbox in at 10:30 engine in at 11:30 time to do all the small things and now to put in the remote oil filter, here is a image of the filter bracket. drilled a couple of holes in the rear wheel arch/mud guard and bolted it down got the wrong type of hose and continued on my way fitted it all up. and finished my day like that. i lost my little red isolator key so shot to burnsco and brought another one and headed back on Tuesday. checked everything over and went for a drive around the block and i was stoked. 1st time i had driven it in 6 months so it was time to leave, packed up my crap and got on the road. made it out of town and tested the new expressway new diff gears go really well, this is just over 3200 rpm and then i noticed my oil light come on so i pulled over quickly to which i found my inlet oil line into the filter had come off and my engine was just pumping oil out onto the expressway at 110kph......... a phone call later and put the hose back on and tightened the hose clamp again we were back to the vdubshoppe the hose i felt was weeping at the fitting so i bit the bullet after trying different hose clamps to get a better clamping force and went with -8 AN fittings. the reason we didnt got with these to begin with was the vduphoppe didn't have a 3/8 bsp to -8 adapter in stock. he also said id have no issue as hes done it on other engines this way and i wanted to just get the bus going. so i found some adapters locally and got back into pulling the kombi back apart. now going AN fittings the mustache bar needed more clearance as the fittings where much bigger and touch it. ended up cutting it longer than this as i needed more clearance smashed it down with a hammer like bellow and well yeah cut it longer and then blazed it up with the welder smashed it back on and i still had little clearance so i ended up putting a 45 fitting straight from the pump. you can kinda see it here in this image. time to put the fittings on the lines, this is where i found out i had put the wrong hose in general on and put breather pipe on instead of the -8 i should have. rookie mistake from myself and not knowing what i was doing and also maybe a bit of mistake from the new parts person as well. so with the new hoses made up we smashed it back together and i went on my marry way again. to get home and see it was still leaking a little bit. out with the adjustable spanners and tightened up with fittings and done them fucken tight this time. so far I've used it for the last two days and i haven't seen anything like below from underneath it so far. should check to see if its got oil now that i think of it. but other than that shes going good, need to fine tune the shifter location and maybe try the bigger spacer the linkage kit comes with now my gearbox is mint, but 10/10 happy to be out driving again. thanks for tuning in and reading my shit yarns, hopefully see you all out and about. keep safe, your stupid vw owner xx
- 47 replies
- 30
- kombi
- volkswagen
(and 2 more)
Tagged with:
Eastcapescapade #6 2022 November 11th, 12th, 13th
64valiant replied to johnnyfive's topic in Upper North Island Region
Registered. Haven't got a bike but now I've got a deadline to sort one. -
All I could think of is the air going around the radiator instead of going into it. I know a fan can suck a lot of air but by blocking the sides off you force the air to be directed into the radiator. These parts circled below. If you have a shroud may pay to put some holes in it with rubber flaps that could open at max speed to allow more air flow throu it as well.
never had any luck trying to find any local, i had no issue with amazon, paid extra to get it here faster. was legit
I'm here for the dudes tbh. -
Signed on dotted line. Leave form will be put in tonight. Excited. -
and hello again. engine and gearbox out of the kombi now. lets move houses. and man I'm lucky i lowered it. wouldn't have fit into our shed at home if it was still stock height. even with out the engine and gearbox in it i had to let the tires down and push it in. time to play with this windscreen that's been broken for some time. so a night shift and i pushed it out while i was waiting around and then the next day visited Bunnings to get some rust converter/killer. ended up going with quik rust converter/primer. masked that windscreen up and coated the hole windscreen surface with i think it was three layers of this in the end. it seeped through my masking tape which i wasn't over excited about. but ah well lest this has some coats on it. removed that masking tape as you can see and i got busy re masking it and getting it and ready to paint. shout out to uber eats and late night masking missions. shot to Bunnings and got the matching primer to the white paint i had here at home. can said dry time of an hour which was legit, quick scotch between coats and im pretty sure we ended up with about 6 layers of primer on it. filled in a few of those smaller pits from the rust eating away. time to slap some white on. and i used up the rest of my white i had in the can which was about 5 coats. got left 24 hours between coats and i was smart and painted it during the night (night shift) and it took a little bit more to dry. but im stoked to get a bunch of coats of protection on it all. time to slap a screen in. new screen and a new rubber later and we have the window in, the rubber was so dam soft. managed to rip it a couple of times which was less than ideal. but going off my previous windscreen life i will probably replace it before the end of the year. screen done and dusted and my little mate is super stoked to see her kombi out side. now I've gotta wait for my gearbox to get rebuilt and then ill rebuild my engine and put a new crank in it. till next time on adventures with Greg's crappy vws keep safe and enjoy playing with old cars bonus image of little mate looking for the engine
- 47 replies
- 33
- kombi
- volkswagen
(and 2 more)
Tagged with:
Eastcapescapade 2021 November 12th, 13th, 14th
hi. dates now please so i can apply for leave. keen to ride small dudes for three days in the dirt -
Yeah she's pretty cool, factory options for them. Haven't used it yet, hope to get out this winter and use it
- 130 replies
Problem is I had all the tools out on the bench ready to go last couple of times. Since then we have moved and I've had to put them all way. Can't be to hard. Lest I know none of them had locktight on them haha
- 130 replies
Shes been a while now since the engine has been out, hopefully it's like muscle memory when she goes back in the hole.
- 130 replies
Also you may be wondering. Yeah I did do it up tight. Used this multipler tool to tighten it to tight.
- 130 replies
back again and at work doing bugger all so lets get to the updating this thread. looks like a few days later i decided the engine needed to come out. Pretty sure i removed it this time as i was having issues with the clutch shuttering and i wanted to remove the flywheel to get it skimmed. looks like i got bored that night and got into rebuilding my steering box while i waited for tools and the fact it it was midnight after removing the engine going off the time on the photos. must have been night shifts or going into night shift. yup so must had come off or gone onto night shift. following image is from 2pm. steering box apart and the peg out ready to be replaced. usually the peg wears out from been in the center all the time and gets a flat spot which creates steering wheel wobble when you are driving along in a straight line, mine wasnt bad but i wanted it better. the peg sit on the worm drive in the box, has a bunch of little roller bearings. the peg itself is on the other side of the nut in the image itself. i was trying to find a blown up diagram on the net on how it works but shit out of luck sorry. this here it self is the peg. i struggled to find any information or videos on youtube how to do this so i thought id make a quick how to. this also might make sense of what i'm replacing here. old mate from vdubshoppe recommends grease in the box itself when you rebuild it, so packed it in there. smashed that back together and done a bunch of fine tune adjustments and i feel its definitely better but not 100% so i think ill replace the rubber steering coupler next time i remember to buy the peace. back to where i was with removing the engine. fly wheel skimmed and back, replaced the rear main seal while it was apart and slapped it all back together. turns out i am better at upholstery than a vw mechanic which is good and not good..... engine back out and replace the rear main seal as i pinch it on instillation and probably didn't use enough lube. never had to use heaps of lube before....... back in again and we are driving, had to shoot to Bunnings grab something so took Tayla for a hoon, we got 4.7kms away from home and she stopped, completely, no power at all nothing happening. had a look around done some digging and checked a few things. wasn't really having much luck but i found one of my wires going to the coil had snapped off. killing all spark. some how dodgied that together and made it to a better position and had a mate come with some new terminals and some plyers to crimp it on. so back to Bunnings we go. next up was to visit my local wheel alignment shop and annoy him cause the bus is low and he cant get the things on the wheel so have to jack up the rear. got it steering a bit better but i think im to much of a race car driver so so might need to find someone whos keen to take some time and fine tune it, wearing the out side of the tire a bit to much for my liking. wanting to change to a 15 inch rim so maybe wait till this are worn out and go to a 15" and a smaller tire and then get a better wheel alignment for race car driving. so you remember how i replaced my screen not long ago in my previous post. turns out this one didn't like been in my car and i got sprayed in stones heading over the kai mais. went for a walk the following day and come back to this. shit a brick. thankfully we got insurance. ahh well off home we go. stopped at the top of the kai mais got a photo and continued my trip home. about 7 days later it started making some horrid noises after going to get some sushi for lunch. bad enough i didnt drive it into the garage. thought it might have been my thrust bearing been i didnt replace it while the engine was out. so lets get into this. engine out time and i give you 18 mins later ermmm spinning release bearing and nothing sounds abnormal? what on earth could it be. spin it a few more times, feels a little off but not enough off to make that type of noise. ahh fuck seems like my flywheel nut has come loose. well clutch off and flywheel nut was finger loose so we undone that and lets see what kind of damage i have done. looks like the dowel pins were the only thing holding it there and they have elongated the holes in the flywheel and the crank. so looks like he's going to need some love and be off the road for a while. lets pull the gearbox out while we are here since its going to be off the road for a while. ' you may ask why am i pulling the gearbox out? well. i have a taller ring and pinion i've been wanting to get installed. you may ask why? well the factory ring and pinion is a 5.375. with the tire size i run i sit at 82kph at 3200rpm i used a website blocklayer. enterd my tire size and gear ratios and diff ratio and it does some cool calculations. we worked out what was going to be the best way about changing the ratio, be final gear or the ratio via this website and diff was the best option. so i ended up going with a 4.13 ratio ring and pinion. this will inscrease my speed from 82kph at 3200 to 107kph and at 3000rpm ill be doing 101kph which is going to be a far better cruising speed. with the old ratio id have to be doing 3900rpm and id be doing 100kph. so that's that really. kind have caught up a bit more with the thread. i think ill have a couple more quite shifts coming up where i can smash some keys and update this thread a bit more.
- 47 replies
- 27
- kombi
- volkswagen
(and 2 more)
Tagged with:
seems like some of your images aren't posting there @sluggy looking good though, thats a crazy good starter motor location on the top of the gearbox.
Gidday team, she has been a while and things have been happening. Going off the order of my images these have been the events so far. originally I built the accelerator bracket out of some thin panel steel and it was moving around so i headed out to see @Geophy and robbed some flat steel from him. made me a thicker bracket. gave that and the carb bracket a lick of black and put it all together. next up I had two 6 inch speakers and a bluetooth kicker amp laying around that were going to be used on something else but never ended up using them and i got sick of turning the UE boom on and off. so time to get busy. I really dislike having speakers in doors of kombis and classic cars so i done my best to hide them, so got cutting holes in the inner wheel tubs. these are not full tubs they don't go out to the under of the car. they have pressings in them and let a bunch of road noise through, so no loss and no gain. should be covered with something but like 90% of buses never cover them. got some clear pvc out of under the bench and drew up some templates and made some wood cards. had some black carpet under the bench and wraped them in that. installed the little amp behind the passengers seat and all the wires tucked away and into the wheel tub. shes pretty small and comes with a small hand controller, the product is kicker pxibt50.2 thats the small controller and speaker installed. goes well enough for two speakers and to listen to music. In fact here is a video. next up i needed to weld a scrape plate on my muffler cause it turns out its still to low and ive made it less round and more flat. that should hopefully make the muffler last a bit longer, i also added a fire extinguisher to the bus. here is a image of me just using the bus wof was due not long after this image and it turns out the screen wanted to crack the day before the wof, so out she came, using the most safely way of course. and hello. we found some rusty holes and she wasn't the prettiest under there. welded the rust up and quickly put some rust killer on it and chucked a new screen back in it. off to tga for a wof and catch up with a mate and a customer. ah did i mention ages ago i sneakly brought a repo clock for the dash? well i told my other half one day and then i installed that during this same time. getting into those positions that you only see your steep sister get stuck in on those videos. a fun job getting in behind the dash to remove it but we got there wof aquired time to repair some other things. got sick of the side door dropping and been a pain in the ass so i pulled the side mechanism out and and had a closer look. this u shape pin has a bunch of play in it. so it was time try put a bush in the body. a quick visit to see @Kimjon drill the bad boy out and kim machined up a bush to go in it. it was also missing a locking key thing, thanks google for supplying this image but yeah got one of them and slapped it all back together with a new block for it to slide on. and job well done. brought myself the volkswagen script that goes on the tail gate that i never had. saw dubbed had them for sale on trade me so hit him up and got that on the back of the bus. drove to tga for xmas and then up to sentras house for new years. and thought after all that driving i should probably grease the front beam, while i was there i chucked the bump stops in that i made. pretty happy with how well these turned out. and that will do for now, i think I'm going to have to go do some work so ill continue updating my silly vw activities next time.
- 47 replies
- 28
- kombi
- volkswagen
(and 2 more)
Tagged with:
your second image has dropped out @sluggy Glad you've gone to the dark side
@flyingbrick do you still own this?
bloody reble over here trying to get to @sentra daves house for new years party. bloody hoofing it as you can see, must be down hill and gusting winds behind me.
- 47 replies
- 17
- kombi
- volkswagen
(and 2 more)
Tagged with:
since we were talking about this in the weekend @Yowzer and @Evan i thought i would dig up the thread and an image while im super busy at work.
Can also agree with 10speed
Man this took some time to find. Ended up Googling it and come across it. Re oil leaks and pressure, did you find your cork gaskets always leaking? Vw mechanic who built my engine puts wheel bearing grease on both sides of the cork when putting them on. Solves leaking from that region and helps hold them when you put them on.
Images from a simpler life with out covid complications. I'll be thinking of all the great sharns and the intense scenery you guys shull enjoy this weekend. Will see you all next year, much love from the guy sad about missing out. Greg.- 474 replies
Nah just go ahead and hand stitch it back together if it isn't to badly damaged. Have done plenty repairs in my time, air bag will bust through that shit pretty fast.
Possible Facebook marketplace collect palmy
64valiant replied to chris r's topic in Lower North Island Region
@_Matt might be able to help. -
The odds looking against me coming with this covid stuff. Actually gutted. Might just have to do it when I'm aloud by myself.
