63Ragtop Posted July 10, 2020 Posted July 10, 2020 Oh the studs on the heads? Possibly, it is actually quite a distance along the system from there, if you know what I mean. The muffler part bolts on to front exhaust stud with a short hanger just visable in that photo if you look on the inside of the right 180 bend. I've have trouble with this one in the past, the thread just seemed chewed out on the other one. Something to think about though. Thanks man. Really needs a whole new system, guy on TM sells a great looking one, similar style to this but a rip off of the spendy CSP python exhausts. And finally give up on having a working heater system. Quote
Bearded Baldy Posted July 11, 2020 Posted July 11, 2020 Just had a read of your thread nice work. This is glue, very strong stuff....bahaha gotta love the blues brothers. Quote
63Ragtop Posted November 22, 2020 Posted November 22, 2020 Yeah, I'm gonna blame the different welder and materials for that, and the massive gap I had to bridge. Also helps to turn the gas back on ! Haha. Quote
Raizer Posted June 16, 2021 Posted June 16, 2021 "question is, how far do I go with this?" Dunno how far to go, but something like this would be a good start at least https://www.trademe.co.nz/a/motors/car-parts-accessories/volkswagen/new-listing/3133906103 Quote
yetchh Posted June 16, 2021 Posted June 16, 2021 In my experience, any extra pressure in the crankcase causes a myriad of oil leaks. As for the rear main, if its a fairly high kilometre engine then the bearings, especially at the back, will be slogged and letting oil out the seal. Quote
yetchh Posted June 16, 2021 Posted June 16, 2021 Like this, rear main journal, about a 90km engine. Quote
63Ragtop Posted June 17, 2021 Posted June 17, 2021 90km? 90,000miles. Sounds about right. Not really in a position to do a full rebuild right now. Will get some new seals and see how it goes. Quote
yetchh Posted June 17, 2021 Posted June 17, 2021 Yeah, cost me about 1k to have the case machined, and then I started thinking "well, while I'm there" etc etc. Quote
63Ragtop Posted June 17, 2021 Posted June 17, 2021 Yep, a very slippery slope. I do have some NOS bare factory heads stashed for the "one day" build. Plan this far is to replace oil cooler, rear seal, reseal alt stand, remove heads, maybe jugs? Hope they aren't stuffed, reseal with new pushrod tubes, install better engine breather system. Drive until it dies. Quote
yetchh Posted June 17, 2021 Posted June 17, 2021 Was just having a browse about case ventilation and found this, is pretty informative https://shoptalkforums.com/viewtopic.php?t=118958 Quote
63Ragtop Posted June 18, 2021 Posted June 18, 2021 Good page that, good info. The is the bare minimum set up is the old cast alloy empi box, connecting the oil filler and both valve covers, many many options and devices out there. This is a tidy install. Can't help but feel these are quite small? Or does that matter as the oil should be draining back down at the same time. Quote
sluggy Posted June 23, 2021 Posted June 23, 2021 Large tube of silicon sealant.... For the record, do you still have my torque multiplier thingy ? Or have I misplaced it... Quote
63Ragtop Posted June 24, 2021 Posted June 24, 2021 21 hours ago, sluggy said: Large tube of silicon sealant.... For the record, do you still have my torque multiplier thingy ? Or have I misplaced it... Tube of poo it is! Yep, I've still got the torque tool, bit embarrassing how long I've had it. You don't have a rear seal putter innera by any chance? This big washer thing. I will return the torque tool once the flywheel is back on. Quote
sluggy Posted June 27, 2021 Posted June 27, 2021 Yeah I think I do somewhere. Will have to check... All good mate, Ive moved on !! Quote
64valiant Posted November 21, 2021 Posted November 21, 2021 Man this took some time to find. Ended up Googling it and come across it. Re oil leaks and pressure, did you find your cork gaskets always leaking? Vw mechanic who built my engine puts wheel bearing grease on both sides of the cork when putting them on. Solves leaking from that region and helps hold them when you put them on. Quote
63Ragtop Posted November 21, 2021 Posted November 21, 2021 I learnt a long time ago that nothing beats good German valve covers and bale's. I once thought chrome covers looked cool, wholey puck they leaked like shit, the cork gaskets would slip off the edge inside the cover, halfway to Waihi in the middle of the night as it happened. but getting back to your question, I don't use anything on the seals, I think it's the only place that doesn't leak. Quote
63Ragtop Posted November 22, 2021 Posted November 22, 2021 Okay I guess will have to see what the expert says. I had this engine built for my 21st back in the year 2000. It's a 1600 twin oil relief case from the early 70s Quote
10Speed Posted November 22, 2021 Author Posted November 22, 2021 I dunno but those cylinders look a bit small... Quote
