Vintage Grumble Posted November 19, 2012 Share Posted November 19, 2012 If its still clear it should be A O K, if its white/milky it will be poo's. Quote Link to comment Share on other sites More sharing options...
UTERUS Posted November 19, 2012 Share Posted November 19, 2012 Thanks, you always have the best knob advice Quote Link to comment Share on other sites More sharing options...
Vintage Grumble Posted November 19, 2012 Share Posted November 19, 2012 If you eat heaps of white chocolate, you may do a white poo. True story. Quote Link to comment Share on other sites More sharing options...
KIRK Posted November 19, 2012 Share Posted November 19, 2012 like every hardware store sells methanol in 1 litre containers if you wana experiment. prob way cheaper places to get it in larger amounts tho Quote Link to comment Share on other sites More sharing options...
Vintage Grumble Posted November 19, 2012 Share Posted November 19, 2012 I used to get 16kg drums from a mobil depot, cheapest way to buy it. Quote Link to comment Share on other sites More sharing options...
sentra Posted November 20, 2012 Share Posted November 20, 2012 if your upper north, tmk packers Quote Link to comment Share on other sites More sharing options...
mark105 Posted November 23, 2012 Author Share Posted November 23, 2012 super charger? figured out i could spin the outlet so it faced the pulley like it is in the pics. this will make for easier plumbing. has a super small pulley on it and all keegan reckons i will find is pulleys the same size when it comes to cars so 1:1 drive it is as i now have pulleys. test burn with new narrower belt to fit my pulleys properly to see if i can get some power down and then time for super charger work. will make decision if i rework drive line to remove V belt after tomorrows test. Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted November 24, 2012 Share Posted November 24, 2012 my 2c, I'd try mount it on the intake side of the engine. Have it hung so that the outlet and inlet were horizontal. Have the discharge port facing the block. Then it can curve up, and into the intake port. and mount the intake curved around to the side of the upright of the frame, and hang the carby there. The pitfall I see with where you have the charger hung there is that the charge will have to travel so far, that there's a greatly increased opportunity for the fuel droplets to fall out of suspention. (Thats why I got mine mounted so high that it pokes through the bonnet) Quote Link to comment Share on other sites More sharing options...
mark105 Posted November 25, 2012 Author Share Posted November 25, 2012 i rolled with your 2c Mr Bart. had a bit more of a closer look at the super charger today. im presuming these spin anti clockwise normally which from what i can tell makes the outlet the left pipe in the pic above and the inlet the right pipe which seemed a bit weird as all the additional fittings are on the outlet side of the super charger does this sound right? also after droming yesterday i have decided to rebuild the entire drive line. hence why it is now all off. the V belt is complete fail for this much torque and im going to do some kind of multi rib slippable belt clutch system as this needs to be pretty much a drag bike now. Quote Link to comment Share on other sites More sharing options...
UTERUS Posted November 25, 2012 Share Posted November 25, 2012 I like the sound of this big block drag bike bizniz. Quote Link to comment Share on other sites More sharing options...
Vintage Grumble Posted November 25, 2012 Share Posted November 25, 2012 OMG, i'm so excited about this. I hope your going to run 3" belts, haha. Quote Link to comment Share on other sites More sharing options...
Steelies Posted November 25, 2012 Share Posted November 25, 2012 OMG, i'm so excited about this. I hope your going to strip 3" belts, haha. Quote Link to comment Share on other sites More sharing options...
Rookie Posted November 25, 2012 Share Posted November 25, 2012 I too am watching with intrepid excitement! Quote Link to comment Share on other sites More sharing options...
Corbie Posted November 26, 2012 Share Posted November 26, 2012 Found that boost gauge. will get it down to you hopefully Wednesday. Quote Link to comment Share on other sites More sharing options...
mark105 Posted November 26, 2012 Author Share Posted November 26, 2012 shit yes. legend. that will be awesomely handy. Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted November 27, 2012 Share Posted November 27, 2012 I couldn't tell you which way your huffer is intended to turn sorry mate. But if you spin it, you should feel air come out the outlet. The beauty is that you can turn it over pretty easy. This bike is going to be a fully lethal bit of kit. Quote Link to comment Share on other sites More sharing options...
mark105 Posted November 27, 2012 Author Share Posted November 27, 2012 can spin it in either direction and it pumps air so that didnt help not knowing which way it went. cant see it spinning any other way bu counter clockwise so just going to roll with that. Quote Link to comment Share on other sites More sharing options...
mikuni Posted November 27, 2012 Share Posted November 27, 2012 Is it an SC12? What about just seeing what it does on a 4A-GZE? The above suggests there is no direction change on the belts, and it runs straight from the crank pulley. Meaning engine goes clockwise, SC goes clockwise (when looking at the front of the pulley). Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted November 27, 2012 Share Posted November 27, 2012 I don't believe it's an SC12, but if it's anything like one, the teeth on the gears are helical and are designed to mesh together in one direction. However I have seen SC1*'s in various installs running either direction without any mention of concerns. Quote Link to comment Share on other sites More sharing options...
Truenotch Posted November 27, 2012 Share Posted November 27, 2012 Won't matter which way it goes. See Eke_Jase's lotus 7 for a reference. Quote Link to comment Share on other sites More sharing options...
