  • Replies 501
A radiator repair place will possibly have a big ol cleaning tank to dip your sack/tank into for a jolly good clean out.
I did this once with a scum filled tank and i was all wowee that's clean.
I have a 1L catch can, its just the smell comes into the car, so I thought if I took the filter vent thing off and plumbed a hose running under the car, it may stop the stink? If the can fills, it will dump oil into the engine bay anyways, so dont think it will be a problem.
I could do that, but may be more trouble that its worth due to the quads. A very fine film of oil spray/scum comes out of it also, so kinda wanted to keep it away from my pretty filter, haha. (I understand its going to be full of dust anyways) I should feed it into chassis rails as an anti rust device.
I thought a PCV valve was just a one way valve, but obviously is lets shit out of the engine, and must let air in if its best to be filtered? So what does the valve do?
Guess I could tap it into the back of the filter base plate, in between the center quads, dont really want all the scum going down one intake.
mine aims at the airfilter, for no good reason.  but it does make for a self oiling air filter when it does the 4age trick.     used to have a hose as you suggested.  mostly oiling the rust.   but plumbing it into the base plate  is probably the best idea.   (long as you keep an eye on the oil level in the can)  only use a pcv if its on the engine side of throttles.
where did you get your itg filter from?
I've just started changing lots of stuff around in the engine bay, trying to make it all a bit tidier, so the catch can will now be behind the head light/infront of the air filter, so will see if the engine sucks in the stank, mite not have to plumb it in after all.
I got the filter from this place/guy, he's the NZ agent. He does motorsporty stuff on the side (has another day chob) real nice chap to deal with.
www.motorsportbitz.co.nz
More dort is on the way! You would be surprised at how much dort the fiberglass plenum stole.
Filter dude failed to mention the price he told me twice, was +GST, so the itg filters aint much cheaper than a pipercross ones.
