Fuuuuu
You have 1 of those RD244xxx wut wut mufflers
Dems be an excellent muffler,ripco lists them as a performance part for a 4L falcon hah
  • Replies 501
My first ae101 had four 2 1/2" resonators, and was loud as all buggery, so I was quite surprised. According to my phone it's around 90 dec under free revving, still quieter than the intake, haha.
What is the legal limit anyways?
Why thank you Tom. I did do it a tiny bit too low under the diff, should have been about 20mm higher up, but still has plenny of road clearance, and diff hardly moves/no suspension travel so it seems to be alllllll G.
Think I will put a tip on it tho, as I think i'm detecting a very slight rasp. I hate rasp.
I tried a few, just made it understeer more? Maybe not going fast enough for it to work? If my hand brake did anything at all, it would have been a lot easier too. Will have semi's on the front next time.
Get more aggressive, it'l work. but soon as you back out of it, will understeer again without plenty of grip up front.   Good e-brake probably more useful for autocross, than beating down on your clutch.  Just ain't no 4age vid without some clutch kicks.
Your TPS is at the back and your throttle linkage on the bottom of the ITB's... excuse my ignorance but are they simply flipped upside down? Having it all tidy like that is relevant to my interest.
+1 for upside down throttles.
lack of rear end grip will make it easy to slide around. everything will happen slower. leave it in 2nd and let the wrath of 4age torque do the work for you.  fun, but you'll come last.   More towards neutral and heaps of grip on both ends, will be way faster, but will have to drive more aggressive and quick on the wheel to make it work.
only difference between my grip and drift/low speed skid around setup on kp, is tyres.  t1r's all round for grip.  then something the same size but with less grip on rear for skidding around.  just to make it oversteer a touch.  don't be tempted to run skinnys on the rear, learnt that the hard way.  still grippy in straight line but no cornering grip.  which is almost more annoying that understeer
looks heaps of fun anyway, jealous because i haven't been to the track for ages
