6 minutes ago, KKtrips said:
I have had this question before and the answer is yes you can have a bi-modal exhaust, but one side has to be quiet, and the other side has to be more quiet.  ie: you cannot have quiet and loud modes.
So effectively exactly what you and Cletus have said.
Great, will look to go that way then I think, a boost referenced valve that is as loud (flowey) as legally poss when open, and quiet as possible when closed
  • Replies 10k
How would a WOF etc test this? Not like they can run it up on a dyno, get it on boost and then volume test it. Its a good idea, im just curious myself.
Or more likely, would they just require you to have it in the "open" setting during testing, and fail you if you cant/dont?
The decibel test is done with the engine not 'loaded'  ie in neutral, take it up to the test rpm, start the meter reading, then let it drop back to idle
So I've got my spacer to put the rod end at the right height. I've got my "beefy washer" at the bottom to prevent pull through. I've got a Grade 8.8 bolt and the shank goes all the way through all the bits(the extra spacer at the top allows me to tighten the nut).
But that beefy washer and bolt head are now REALLY close to the wheel. I had to space the wheel out with some 3mm washers. So now I have 3mm clearance.
How much clearance is enough clearance?
I can space the wheels out further...
You might be able to give yourself a bit more clearance with an Allen head bolt
There isn't a set minimum but I'd aim for at least 5mm . If you have to run spacers anyway it's not a big deal to space it out a bit more
Question regarding steering setups for my 720/Safari mashup.
I have the NZCCM, and it has this section:
Essentially my question is: The pair of UJs (1 either side of the intermediate shaft) would be supported at the firewall, and the steering box. Is that what it's asking for, or some sort of inline bearing on the intermediate shaft?
Probably an obvious answer but I wasn't sure.
If the answer is a support on the intermediate shaft, then do I need to incorporate some degree of movement (i.e. rubber mounting) as it is a cab on frame and there will be a degree of flex? Or is that negligible and it can just be hard mounted?
 Thanks in advance.
On a macpherson strut type suspenion - is there a minimum amount of thread that needs to extend past the end of a nut on the two bolts securing the shock to the hub(knuckle/carrier)?
EDIT: 'Two threads clear'
I've read conflicting information, is it acceptable to modify/shorten/weld half shafts?
EDIT: Looking into it, I don't think welding is an option but shortening and resplining could work.
We get Hilux's and Bounty's in at work all the time with them failed, it's amazing how happily they lock the rears with even the lightest of brake pressure. Scary as fuck in the wet haha
1 hour ago, Ashkellybarr said:
If a vehicle come with lspv as per pic. Can I remove it when certing for other mods?
i.e longer rear break line for lift and remove it all together
cherers
yep as long as the brake bias is ok, ie lock it in the right position, or fit an adjustable bias valve
 Thanks in advance.
if you just have 2x ujoints, you wont need another support, the steering column (if its got a bush/bearing in the bottom) will support one, steering box will support the other
if the body is rubber mounted you will need some sort of flex in the system to allow for body movement on the chassis- either a rubber rag joint, or ujoints and a sliding shaft
correct, 2 threads past the nut
what application?
59 minutes ago, cletus said:
what application?
A few options for a motorbike engined car
1. Either an MX5 rear subframe narrowed (but keeping stock suspension components/dimensions) and using mx5 diff converted to sprocket drive (mid engine chain drive) and shortened half shafts (hoping to just cut and respline if possible)
2. The same subframe using an IRS holden diff (normal prop shaft to front) and modified half shafts to mx5 rear brakes (maybe respline would work, maybe weld...dont like idea of welding) .
3. Civic diff and brakes converted to sprocket using in fwd format but need to shorten shafts.
If that makes sense?
Noob question on CoFs: Working on a friends camper, and we've gutted it. Can we CoF it with no interior, and then do the camper related stuff later? Figure it's better/easier doing that while empty and repairable. From what I picked up on the Civil-ian thread that's the way to go.
