AALAWS Posted September 15, 2018 Share Posted September 15, 2018 Toyota themselves didn't have anything on file, but my friend used used their name and accreditation to get some info for me so I have a good starting point with previous rego history Quote Link to comment Share on other sites More sharing options...
kyteler Posted September 17, 2018 Share Posted September 17, 2018 @cletus my good fellow. I'm debating with myself on buying some adjustable suspension from Japanese tuner Star Road, whilst I am here. What's the likelihood of getting the rear coilover platforms as per the kit certed in the flapping rear trailing arm suspension of the 110? Quote Link to comment Share on other sites More sharing options...
cletus Posted September 17, 2018 Share Posted September 17, 2018 The rear will be reasonably easy, camber will probably be your biggest issue there. If they are the ones on the pic though, the front ones wouldn't be able to be certed due to the strut tube being welded to the cast/forged bit at the bottom. 1 Quote Link to comment Share on other sites More sharing options...
cletus Posted September 17, 2018 Share Posted September 17, 2018 On 13/09/2018 at 22:19, smokin'joe said: @cletus does a winch bar need cert ? did search on here, but no result. fanx Not according to this- go to exterior projections https://lvvta.org.nz/documents/suplementary_information/LVVTA_LVV_Cert_Threshold.pdf Quote Link to comment Share on other sites More sharing options...
cletus Posted September 17, 2018 Share Posted September 17, 2018 On 12/09/2018 at 23:35, kpr said: when welding to the strut tube, does the weld have to be a certain distance away from the cast part? I created a sweet weak point, when i done some rangi mods on my paddock car. it wasn't welded to the cast part. (is now..) The rules say no welding within 10mm of the cast part 1 Quote Link to comment Share on other sites More sharing options...
smokin'joe Posted September 17, 2018 Share Posted September 17, 2018 1 hour ago, cletus said: Not according to this- go to exterior projections https://lvvta.org.nz/documents/suplementary_information/LVVTA_LVV_Cert_Threshold.pdf cheers, found that last nite, and i guess if everything is mounted as close to original bumper line, it should be ok. some of the ones i have seen, leave a lot to be desired Quote Link to comment Share on other sites More sharing options...
kyteler Posted September 17, 2018 Share Posted September 17, 2018 2 hours ago, cletus said: The rear will be reasonably easy, camber will probably be your biggest issue there. If they are the ones on the pic though, the front ones wouldn't be able to be certed due to the strut tube being welded to the cast/forged bit at the bottom. Thank you, sir. 1 Quote Link to comment Share on other sites More sharing options...
Toddy415 Posted September 17, 2018 Share Posted September 17, 2018 23 minutes ago, kyteler said: Thank you, sir. Edit: Never mind ignore me Quote Link to comment Share on other sites More sharing options...
KKtrips Posted September 20, 2018 Share Posted September 20, 2018 On 12/09/2018 at 23:35, kpr said: when welding to the strut tube, does the weld have to be a certain distance away from the cast part? I created a sweet weak point, when i done some rangi mods on my paddock car. it wasn't welded to the cast part. (is now..) Can I steal this photo for educational purposes please? 1 Quote Link to comment Share on other sites More sharing options...
kpr Posted September 20, 2018 Share Posted September 20, 2018 consider it stolen 1 Quote Link to comment Share on other sites More sharing options...
Bling Posted September 25, 2018 Share Posted September 25, 2018 Have read the flow chart on LVVTA, but before I start chopping, is a CAT required on a pre 90 car at cert? Chart appears to show anything pre 90 does not required a CAT. Cheers Asking as I recall this rule has changed in the past. Engine is stock FWIW. Quote Link to comment Share on other sites More sharing options...
cletus Posted September 25, 2018 Share Posted September 25, 2018 Nah if it's registered prior to 2010 it doesn't need a cat. 2 Quote Link to comment Share on other sites More sharing options...
kws Posted September 25, 2018 Share Posted September 25, 2018 On a similar topic, and I haven't searched because it's just come to me, if you built a scratch built car, And registered it now as new, does it need a cat fitted? Quote Link to comment Share on other sites More sharing options...
cletus Posted September 25, 2018 Share Posted September 25, 2018 Yes, unless it meets the criteria in the standard for not having to have one. https://lvvta.org.nz/documents/standards/LVVTA_STD_Exhaust_Gas_Emissions.pdf Quote Link to comment Share on other sites More sharing options...
Nominal Posted September 25, 2018 Share Posted September 25, 2018 15 minutes ago, cletus said: Yes, unless it meets the criteria in the standard for not having to have one. https://lvvta.org.nz/documents/standards/LVVTA_STD_Exhaust_Gas_Emissions.pdf That's a bit of a dick around! Quote Link to comment Share on other sites More sharing options...
Testament Posted September 25, 2018 Share Posted September 25, 2018 fit everything with side exhausts? 1 Quote Link to comment Share on other sites More sharing options...
Nominal Posted September 25, 2018 Share Posted September 25, 2018 15 minutes ago, Testament said: fit everything with side exhausts? Tempted. Quote Link to comment Share on other sites More sharing options...
sheepers Posted September 26, 2018 Share Posted September 26, 2018 This isn’t exactly about certing but I thought the celebrated Mr turnip might have some relevant info on this topic. So my MS75 needs re-complying because its de-reg. parts on it like the brake master cylinder are fucked and the only replacement master I can get for it is a bolt on affair for the car but looks completely different to the original one and it has a modern looking reservoir. Same goes for the proportioning valve. What the story with complying a car with these things on it? Its not modified, its just replacing fucked bits with the only parts you can get. Are they going to knock it back? Quote Link to comment Share on other sites More sharing options...
Popular Post cletus Posted September 26, 2018 Popular Post Share Posted September 26, 2018 Technically, yes it would need cert if it's not a catalogued replacement for that model vehicle. A scallywag would possibly do something devious like try and obtain a wof and probably succeed if it bolts on with no mods, and works correctly, as you would need to be a big toyota crown nerd to know what the oe one looks like, and I only know one of those nerds and he doesn't work at a compliance center. You will need a cert for the 186 swap anyway so I dunno why you are asking silly questions David. 6 4 Quote Link to comment Share on other sites More sharing options...
sheepers Posted September 26, 2018 Share Posted September 26, 2018 hang on, how would i obtain a wof if it needs re-complying?????????? also 186die Quote Link to comment Share on other sites More sharing options...
