Popular Post Valiant Posted May 30, 2022 Popular Post Share Posted May 30, 2022 Leave the engine in place, pull the sump off and sneak a set of big end bearings into it. If it hasn't run a bearing It's a legitimate fix. It'll solve your problem for a couple of hundred dollars and a few hours work. 10 Quote Link to comment Share on other sites More sharing options...
locost_bryan Posted May 31, 2022 Share Posted May 31, 2022 Drop in a factory 2 litre? There's one being parted on FB 2 Quote Link to comment Share on other sites More sharing options...
Popular Post kws Posted May 31, 2022 Author Popular Post Share Posted May 31, 2022 Its a shame i didn't buy that car for parts earlier, they were asking $300 for it. Its a shit body and engine, but had some good parts on it. I asked how much they want for the bumpers; $450 for the pair. I have declined the sellers kind offer of a very conditional refund, and im walking away. Im going to make this the best damn SD1 I can, just to spite the old bastard. 12 2 Quote Link to comment Share on other sites More sharing options...
kws Posted May 31, 2022 Author Share Posted May 31, 2022 7 hours ago, Valiant said: Leave the engine in place, pull the sump off and sneak a set of big end bearings into it. If it hasn't run a bearing It's a legitimate fix. It'll solve your problem for a couple of hundred dollars and a few hours work. It might help the oil pressure issue but im betting the clattering from the top end is due to the cam and lifters being toast. Its not worth spending time or money on this particular engine. Im going to try a couple of additives to see if i can shut the clatter up a bit, and ill live with the low oil pressure until i can afford a 3.9 swap. I want to see if i can get it through a WOF. 8 Quote Link to comment Share on other sites More sharing options...
locost_bryan Posted May 31, 2022 Share Posted May 31, 2022 Good, that's the fighting British bulldog spirit. Good excuse to get a Disco V8 and see if the ZF auto will fit in the hole. 5 Quote Link to comment Share on other sites More sharing options...
Valiant Posted May 31, 2022 Share Posted May 31, 2022 @kws it will help your oil pressure issue. Engines loose pressure due to excessive clearance. Top end noise is probably the lifters bleeding down due to low oil pressure. I'd give it a try if it was mine. Thankfully it's yours though. Edit. Fair enough though if you want to upside. It's the perfect excuse. 2 Quote Link to comment Share on other sites More sharing options...
kirk28 Posted May 31, 2022 Share Posted May 31, 2022 Yep cars do things like this.. you’ve made the right decision keep it and fix.. at least you will have a properly sorted car at the end of the day.. just keep it in the shed and acquire bits over time will make you feel better about it taking some time to get back on the road if you need to wait for funds… the seller sounds like a git so avoid anymore shit from him.. if the budget has blown out on it… simply means ya gotta keep it forever lol… also you’ll never get cads that you like out of your system and you’ll only end up buying another one later on anyway that will probably need the same amount of work. Go hard… old cars that aren’t super pricey bring us so much enjoyment… and also frustration but what can ya do. 9 Quote Link to comment Share on other sites More sharing options...
kws Posted May 31, 2022 Author Share Posted May 31, 2022 On 30/05/2022 at 23:00, cletus said: If you like the car otherwise, would it be worthwhile asking him for some $$ towards a replacement engine? Instead of dealing with the ballache of sending it back and risking him screwing you further Oh i forgot to reply to this one. When enquiring about a partial refund as compensation for misrepresenting the car, I got told to "return the car or get lost". Some people 2 Quote Link to comment Share on other sites More sharing options...
kirk28 Posted June 4, 2022 Share Posted June 4, 2022 https://www.trademe.co.nz/a/motors/cars/rover/3500/listing/3620623706 LPG baby! Quote Link to comment Share on other sites More sharing options...
kws Posted June 4, 2022 Author Share Posted June 4, 2022 2 minutes ago, kirk28 said: https://www.trademe.co.nz/a/motors/cars/rover/3500/listing/3620623706 LPG baby! I dont even know where you get LPG these days. used to be pumps at most stations but they've all disappeared now. Quote Link to comment Share on other sites More sharing options...
kirk28 Posted June 4, 2022 Share Posted June 4, 2022 3 minutes ago, kws said: I dont even know where you get LPG these days. used to be pumps at most stations but they've all disappeared now. They still have it here in taranaki but yeah they should get that network going again. 1 Quote Link to comment Share on other sites More sharing options...
dr.wylde Posted June 5, 2022 Share Posted June 5, 2022 Have you considered the Leyland 4.4 V8? Just make up some 19mm spacers for the efi manifold and enjoy an extra 900cc Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted June 5, 2022 Share Posted June 5, 2022 Ld28+t 2 Quote Link to comment Share on other sites More sharing options...
Muncie Posted June 6, 2022 Share Posted June 6, 2022 Go fundme page for a bulk purchase of BW35's To be dumped on sellers doorstep? 2 3 Quote Link to comment Share on other sites More sharing options...
Goat Posted June 6, 2022 Share Posted June 6, 2022 Sad to see the misery you've been through (other than subjecting yourself to another British vehicle). But glad to see you've got a bit of a second wind. Looking forward to seeing this go from its current state to back on the road! Hoping you rebuild the original engine. Keen to see that process with your high level of documentation. 5 Quote Link to comment Share on other sites More sharing options...
Sunbeam Posted June 6, 2022 Share Posted June 6, 2022 Are you going to be able to get your hands on the O.G. high compression engine or have you severed all comms with the seller? 1 Quote Link to comment Share on other sites More sharing options...
kws Posted June 6, 2022 Author Share Posted June 6, 2022 4 minutes ago, Sunbeam said: Are you going to be able to get your hands on the O.G. high compression engine or have you severed all comms with the seller? It's not really worth having. The block is the same as all 3.5s, but the pistons and heads are ment to be better (that's where the CR increase comes from). This one is in bits scattered in boxes, having suffered a serious failure. I'd only want it if I were interested in keeping it all original and numbers matching, which I'm not. 2 Quote Link to comment Share on other sites More sharing options...
Muncie Posted June 7, 2022 Share Posted June 7, 2022 Would recommend replacing the lifters if its clattering make sure you prime them with oil first. Rovers have shit oil pressure so once your lifters are a bit tired the valvetrain will get noisy. I went through same thing with my VDP bought for $500 because it sounded terminal and was gutless, you can check the cam out at same time as these engines eat cam lobes(hopefully yours is good) Once I sorted the lifters it was a beautiful machine again that could break diffs at the drop of a hat. 2 Quote Link to comment Share on other sites More sharing options...
shrike Posted June 7, 2022 Share Posted June 7, 2022 So are you going to make a claim via the Contract and Commercial Law Act 2017? Sounds like the guy is just scum and took advantage of the current car market, highly doubt anyone in the UK would have paid what he was saying he could get etc if they would surely he would have already jumped on it Quote Link to comment Share on other sites More sharing options...
Toucan Posted June 7, 2022 Share Posted June 7, 2022 Damn that black vitesse looked the business/less yuck than the others. Hopefully some abandoned Land Rover with a great engine but parked in a field for 7 years due to trivial issue that boggled the owner but you can fix in a jiffy comes up for sale cheap in your future 4 Quote Link to comment Share on other sites More sharing options...
