yoeddynz Posted January 13 Author Report Share Posted January 13 3 hours ago, mjrstar said: You are most likely all over this, I didn't see a photo of the back side of the HRB, but one thing I learnt the hard way in a retrofit of a very similar looking Saab HRB into the mx5, is that the back side of the unit needs a solid base. As the rear cover where you gain access to service the hydraulics is a crimped in disc. This will not withstand hydraulic pressure without being sandwiched so it can't move. Yeah I've got that covered. I had looked at that and thought much the same. So the feet that support the main base it are quite big and solid as. Im also sticking with this older model that has a bleed nipple because I've read that quite alot of pissing about bleeding the later ones when retro fitted. 1 Quote Link to comment Share on other sites More sharing options...
anglia4 Posted January 17 Report Share Posted January 17 The tilton one in our race car has a long tube for the bleed, tis plumbed to the top of the firewall so you can bleed it without jacking up the car. 2 Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted January 18 Author Report Share Posted January 18 Good idea for RWD applications if its under the tunnel! This one however will be pretty easy to get to because I'm going to keep a removable cover on the parcel shelf, what is currently covered by the fiberglass box that goes over the Datsun engine. 3 Quote Link to comment Share on other sites More sharing options...
kws Posted January 18 Report Share Posted January 18 11 hours ago, anglia4 said: The tilton one in our race car has a long tube for the bleed, tis plumbed to the top of the firewall so you can bleed it without jacking up the car. The Morris Ital had this from factory, those forward thinking engineers 1 1 Quote Link to comment Share on other sites More sharing options...
anglia4 Posted January 18 Report Share Posted January 18 12 hours ago, yoeddynz said: Good idea for RWD applications if its under the tunnel! This one however will be pretty easy to get to because I'm going to keep a removable cover on the parcel shelf, what is currently covered by the fiberglass box that goes over the Datsun engine. I thought that might be the case! Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted March 21 Report Share Posted March 21 So good, wish you had a YouTube series. 1 Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted March 21 Author Report Share Posted March 21 It would end up filled with cat content. 2 2 Quote Link to comment Share on other sites More sharing options...
Raizer Posted March 21 Report Share Posted March 21 12 minutes ago, yoeddynz said: It would end up filled with cat content. Now I really wish you had a YouTube series. 3 4 Quote Link to comment Share on other sites More sharing options...
Popular Post yoeddynz Posted May 13 Author Popular Post Report Share Posted May 13 I recently popped up some recent photos of the flat six on the Hillman Imp Facebook group. Lots of enthusiasm for it but I was waiting for a Barry to quip in... 10 Quote Link to comment Share on other sites More sharing options...
Popular Post yoeddynz Posted May 13 Author Popular Post Report Share Posted May 13 My response was.. 14 4 Quote Link to comment Share on other sites More sharing options...
tortron Posted May 13 Report Share Posted May 13 The engine only feels so smooth due to the precise routing of the throttle cable 1 1 Quote Link to comment Share on other sites More sharing options...
Popular Post yoeddynz Posted May 13 Author Popular Post Report Share Posted May 13 And then this... 11 Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted May 13 Author Report Share Posted May 13 Barry's back... 3 1 Quote Link to comment Share on other sites More sharing options...
Popular Post ThePog Posted May 13 Popular Post Report Share Posted May 13 He is clearly of the "throw money at it until it works" rather than "throw scrap and talent at it until it works" school of thought. Does he not know that the calipers will be sourced from some shitbox, the rotors from another unrelated shitbox, the master cylinder from a tractor and that it only needs those $45 worth of parts and 47 hours and you will have a brembo equivalent? Fucking amateur. 7 2 9 Quote Link to comment Share on other sites More sharing options...
Toucan Posted May 13 Report Share Posted May 13 Oh man, imaging having to open the engine internals, walk in the park after this level of clever custom fabrication work 1 Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted May 13 Author Report Share Posted May 13 I told my brothers about this Facebook expert and my brother said this.. 1 Quote Link to comment Share on other sites More sharing options...
tortron Posted May 13 Report Share Posted May 13 Missing the points! Why would you get rid of a perfectly reliable ignition system. You better carry it in the frunk for rapid change over then the transistors burn out leaving you stranded 6 Quote Link to comment Share on other sites More sharing options...
cubastreet Posted May 17 Report Share Posted May 17 Looks awesome! Did imps have climax engines or am I thinking of something else? Quote Link to comment Share on other sites More sharing options...
anglia4 Posted May 17 Report Share Posted May 17 This one does... If you're picking up what I'm putting down 2 5 Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted May 18 Author Report Share Posted May 18 1 hour ago, cubastreet said: Looks awesome! Did imps have climax engines or am I thinking of something else? Yeah. I hear about that fact quite often when the barries start swarming. "it's a fire pump engine don't you know" Usually stated alongside the fact that they handle much better with a sack of concrete in the front 2 4 Quote Link to comment Share on other sites More sharing options...
