Alfashark Posted May 12, 2016 Report Share Posted May 12, 2016 Correct, and the 4wd ones aren't in 4wd while being driven on the road - when in 4wd High and Low, it locks the rear diff and center diff... I'm sure through a combination of button stabbing it can be disabled. On the odd occasion I've borrowed one of the rep's ones for the day, I can drop the consumption down to 2wd flat-deck levels by simply not driving it like I stole it - By default our reps seem to use all of the revs and frequently forget that there is also a 5th and 6th gear... Quote Link to comment Share on other sites More sharing options...
NickJ Posted May 12, 2016 Report Share Posted May 12, 2016 My Lada being full time 4wd drinks like a sailor but when I had to remove the front driveshaft to replace a UJ it felt much happier about moving along. How much energy is lost in a diff, I know unlocking hubs makes a big difference, but is there really that much drag? Also found this: http://www.aliexpress.com/item/High-quality-micro-hall-fuel-flow-sensor-meter-for-diesel-gasoline/32605337509.html?spm=2114.01010208.3.58.pik0R1&ws_ab_test=searchweb201556_10,searchweb201602_5_10017_10034_10021_507_10022_10020_10018_10019,searchweb201603_9&btsid=d8b836e9-aea2-4055-bbfc-2dc734523970 Although I wonder if it could handle petrol without melting! 1 Quote Link to comment Share on other sites More sharing options...
Roman Posted May 12, 2016 Author Report Share Posted May 12, 2016 Does your carb have a return line though? Quote Link to comment Share on other sites More sharing options...
NickJ Posted May 12, 2016 Report Share Posted May 12, 2016 Does your carb have a return line though? Nah, I planned one for the carbs but it somehow runs without so never went any further Quote Link to comment Share on other sites More sharing options...
SOHC Posted May 12, 2016 Report Share Posted May 12, 2016 When I bought my Vanguard it ran 10 psi oil pressure at start up and nothing at all when it got warm. as long as it shows something at some stage it should be ok Quote Link to comment Share on other sites More sharing options...
SOHC Posted May 12, 2016 Report Share Posted May 12, 2016 I had a 1994 Subaru and I did the trick of bridging the connection so there was no drive to the rear and there was a big fuel saving Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted May 12, 2016 Report Share Posted May 12, 2016 My Lada being full time 4wd drinks like a sailor but when I had to remove the front driveshaft to replace a UJ it felt much happier about moving along. How much energy is lost in a diff, I know unlocking hubs makes a big difference, but is there really that much drag? Also found this: http://www.aliexpress.com/item/High-quality-micro-hall-fuel-flow-sensor-meter-for-diesel-gasoline/32605337509.html?spm=2114.01010208.3.58.pik0R1&ws_ab_test=searchweb201556_10,searchweb201602_5_10017_10034_10021_507_10022_10020_10018_10019,searchweb201603_9&btsid=d8b836e9-aea2-4055-bbfc-2dc734523970 Although I wonder if it could handle petrol without melting! Does the lada have a center diff? I don't see how free wheeling hubs could work on a full time 4wd as you'd lose all drive to the rear too? ( Because the front can spin freely in the hubs) Confused! Quote Link to comment Share on other sites More sharing options...
Roman Posted May 12, 2016 Author Report Share Posted May 12, 2016 One for Flying Brick. http://www.equipmentworld.com/dont-lower-your-tailgate-gm-details-aerodynamic-design-of-2014-silverado-and-sierra-2500-debunks-myths/ 1 Quote Link to comment Share on other sites More sharing options...
NickJ Posted May 12, 2016 Report Share Posted May 12, 2016 Does the lada have a center diff? I don't see how free wheeling hubs could work on a full time 4wd as you'd lose all drive to the rear too? ( Because the front can spin freely in the hubs) Confused! Yeah, Niva's have a center diff and center diff lock, remove driveshaft and engage the diff lock, game on! I've had it in both rear and front wheel drive on occasions, rwd really lightens the steering and makes them much nicer to drive on road, really wish the ruskies worked out a 2wd option when they built them. There is a eastern euro company that make a bolt on adapter that gives 2wd functionality but i'd never pay it off in fuel use because of freight charges! 2 Quote Link to comment Share on other sites More sharing options...
johnnyfive Posted May 12, 2016 Report Share Posted May 12, 2016 So it turns out the hilariously boxy looking Subaru XT is actually some genius aerodynamic masterpiece that spent countless hours in the wind tunnel during it's design. Clocks in with a very surprising c.d. of 0.29 Pretty impressive for something that looks like its design was based on a tupperware container https://en.wikipedia.org/wiki/Subaru_XT#Aerodynamics I struggled not to mention these when you started calculating aero for your car. Also, Vortex not so fuel efficient. 1 Quote Link to comment Share on other sites More sharing options...
gettinroundtuit Posted May 13, 2016 Report Share Posted May 13, 2016 Back in my mini days was in Nelson for holidays & ended up having only enough money for two tanks of fuel to get back to Invers. 1000km. only @ 5 gal tank (22.5 L) 40+ psi in the tyres & cruising @ 70- 80ks where possible,@ 100ks when needing to- til Balclutha then sunk the boot in coz I'd worked out had more than enough to get home from there. 2 Quote Link to comment Share on other sites More sharing options...
Roman Posted May 15, 2016 Author Report Share Posted May 15, 2016 I have been maintaing the just under/over 4l per 100km on each trip in the daily. Based on 45l tank, if I can maintain this I should be able to go 1100km before next refill. (?!)Auckland to Christchurch on a tank of gas... Which is nearly 5 weeks of driving to work and back, West Harbour to Penrose. It'll be interesting to see how the OBD2 compares to the fuel top up + check kms method though. I have started using fuelly so time will tell at next fill up... in a few weeks. It's taken hilariously long to go through just under 1/4 of a tank.On my other car, there are a few plastic underbody panels etc that have been off the car that I'm refitting to see if it helps at all. Some look to just be stone gaurds, but I think some of the other bits would contribute in a useful sort of way towards reducing drag a little. 2 Quote Link to comment Share on other sites More sharing options...
JoKer Posted May 15, 2016 Report Share Posted May 15, 2016 Clean your car too (not aimed at anyone) a waxed car will go further than your dust & grime covered daily 1 Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted May 15, 2016 Report Share Posted May 15, 2016 Since people are bragging about their figures, with the caravan on the back, one of my dads vals will cut a 68litre tank of avgas in 168kms. He has to bring loads of extra fuel to go anywhere. 4 Quote Link to comment Share on other sites More sharing options...
Roman Posted May 16, 2016 Author Report Share Posted May 16, 2016 40 litres per 100km Hahaha that is quite impressive. So from my house to Christchurch, assuming using 98 instead of Avgas would cost.... $870 each way for gas alone. 2 Quote Link to comment Share on other sites More sharing options...
JoKer Posted May 16, 2016 Report Share Posted May 16, 2016 guidelines for this pulse & glide? theories / methods, subscribed just for this now Quote Link to comment Share on other sites More sharing options...
Roman Posted May 16, 2016 Author Report Share Posted May 16, 2016 I'll accellerate slow-ish up to say 95-100kph Then put car in neutral and coast down to say 80-85. then accellerate again, rinse repeat. You only end up with foot on the gas for about 1/4 of the time or less because it actually takes quite a while to scrub off your speed. What I find is that I am generally travelling at the same speed as traffic around me anyway (Most of my trip to work is 80kph zone) but using 20-30% less gas. 1 Quote Link to comment Share on other sites More sharing options...
Muncie Posted May 16, 2016 Report Share Posted May 16, 2016 Logged an average of 6.8l per 100 from huntly to warkworth return in my commodore last weekend. I consider that frugal for a 3.8 supercharged lump. I got my 1400ks out of a tank in my triumph before with some wacky tuning. 1 Quote Link to comment Share on other sites More sharing options...
Snoozin Posted May 16, 2016 Report Share Posted May 16, 2016 Christ you talk some horseshit at times Muncie but that takes the cake. A Triumph 2000 or 2500 of any variety getting 4.1 litres per 100km is simply pipe dreams, pure and simple. 7 Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted May 16, 2016 Report Share Posted May 16, 2016 Those SU carbs are Pretty Good on gas. But those numbers do seem somewhat optimistic..... Quote Link to comment Share on other sites More sharing options...
