RUNAMUCK Posted July 4, 2023 Share Posted July 4, 2023 I'm going to be running two pumps. A low pressure lift pump feeding the surge tank, and an EFI pump feeding the engine. Theres a bit of nutting out required as to how it all needs to go. Quote Link to comment Share on other sites More sharing options...
87creepin Posted July 6, 2023 Share Posted July 6, 2023 How easy is it to install a car alarm/keyless entry? the car in question has central locking already. Just thought it would be nice to have keyless entry rather than use the key all the time. what wires go where etc? As I’ll probably be purchasing a cheap unit that may not have instructions. Quote Link to comment Share on other sites More sharing options...
NickJ Posted July 7, 2023 Share Posted July 7, 2023 On 06/07/2023 at 15:29, 87creepin said: How easy is it to install a car alarm/keyless entry? the car in question has central locking already. Just thought it would be nice to have keyless entry rather than use the key all the time. what wires go where etc? As I’ll probably be purchasing a cheap unit that may not have instructions. Mid 90s car, easy as, beyond that it comes down to the individual vehicle due to mind numbing complex methods used to make a lever move up and down, the information is usually out there as to what wire is hidden where. Quote Link to comment Share on other sites More sharing options...
shizzl Posted July 8, 2023 Share Posted July 8, 2023 4 link bushings. have found a nice kit close to home but uses heim joints. another one is an extra $200 and probably 3 weeks shipping, but uses poly bushes. are the heim joints a terrible idea to use on a road car? I’ve only used them in Stockcar’s, theyr naturally noisey so couldn’t really tell. Quote Link to comment Share on other sites More sharing options...
RXFORD Posted July 8, 2023 Share Posted July 8, 2023 1 hour ago, shizzl said: 4 link bushings. have found a nice kit close to home but uses heim joints. another one is an extra $200 and probably 3 weeks shipping, but uses poly bushes. are the heim joints a terrible idea to use on a road car? I’ve only used them in Stockcar’s, theyr naturally noisey so couldn’t really tell. Heims are used fairly often in the minitruck world. As are polybushes. You'll generally get more articulation with heims, but also more 'road noise'. Heims need to be teflon lined to meet lvv requirements. Polybushes dont flex as much and can wear out quick if you overstress them, but are a bit more comfortable if you use the right ones. Some of the cheap chassistech ones are shitty hard urethane and don't last. A combo of heims/polys is common too. I generally do this. Just make sure you use the chart in the car construction manual to get the size vs weight correct for cert. 1 Quote Link to comment Share on other sites More sharing options...
shizzl Posted July 8, 2023 Share Posted July 8, 2023 Perfect info, btw just sent you a pm Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted July 9, 2023 Share Posted July 9, 2023 99% sure you must run a rubber bush at one end of each arm for cert. Something about the give they offer meaning they wont bind. Make sure any rose joints you use are rated for motorsport use. 1 Quote Link to comment Share on other sites More sharing options...
h4nd Posted July 9, 2023 Share Posted July 9, 2023 Oooh, punchcard auto phone dialler! https://mastodon.nz/@dan@discuss.systems/110681574669887729 2 Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted July 13, 2023 Share Posted July 13, 2023 Why is it/isnt it a good idea to run a fuel filter on the suction side of a low pressure fuel pump? A dead fuel pump = a bad time. So surely keeping any shit from the tank out has to be a good idea to promote longevity? Quote Link to comment Share on other sites More sharing options...
Nominal Posted July 13, 2023 Share Posted July 13, 2023 You only really have atmospheric pressure to work with on the suction side, so a restrictive filter could drop the flow quite a bit. Possibly someone makes a low restriction filter for this sort of thing, or even a brass screen sort of thing would help. I guess this is why factory systems have the sock thing on the inlet side in the tank. Quote Link to comment Share on other sites More sharing options...
JustHarry Posted July 13, 2023 Share Posted July 13, 2023 Cant say I've had a problem running a filter before a low pressure pump. If the filter is affecting flow that much either the filter is to small or the pump is to small. Personally I'd rather keep any grit out of the pump 5 Quote Link to comment Share on other sites More sharing options...
shizzl Posted July 13, 2023 Share Posted July 13, 2023 That reminds me to put a filter in the hunter. Doesn’t have one yet. Sorry pump and injectors 1 Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted July 13, 2023 Share Posted July 13, 2023 The inside of 50 year old steel gas tanks can be nasty too. Quote Link to comment Share on other sites More sharing options...
ajg193 Posted July 13, 2023 Share Posted July 13, 2023 Toyota used filter before the pump, never any problems. Just do it. Also means the filter is less likely to pop Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted July 13, 2023 Share Posted July 13, 2023 I need to find one with an inbuilt mounting clip. Quote Link to comment Share on other sites More sharing options...
ajg193 Posted July 13, 2023 Share Posted July 13, 2023 https://www.amayama.com/en/part/toyota/9092901041 https://www.amayama.com/en/part/toyota/2330025020 Quote Link to comment Share on other sites More sharing options...
kws Posted July 13, 2023 Share Posted July 13, 2023 My fuelflow pump actually recommends having a filter before the pump 2 Quote Link to comment Share on other sites More sharing options...
shizzl Posted July 14, 2023 Share Posted July 14, 2023 8 hours ago, RUNAMUCK said: The inside of 50 year old steel gas tanks can be nasty too. Luckily the hunters tank is pretty spotless Quote Link to comment Share on other sites More sharing options...
h4nd Posted July 20, 2023 Share Posted July 20, 2023 Algodoo to was fun 2D physics modeller/game/ kids edu program, but awkward to edit objects after creation, and no parameterization. FreeCad physics seems to be about static FEM analysis. Suggestions on what to use to make a Dino skeleton out of rods and pivots and springs please ? Meccano? (There's a new CAD input package for Blender, but it looks rather Beta) Quote Link to comment Share on other sites More sharing options...
HighLUX Posted July 21, 2023 Share Posted July 21, 2023 Would a 13b turbo rx7 radiator be sufficient for cooling a boosted 2L engine. I'm limited for space with my engine swap but a 3 core alloy FC radiator looks like it will fit in my limited area and I know dorito motors like to run hot Quote Link to comment Share on other sites More sharing options...
