Nominal Posted May 12, 2019 Share Posted May 12, 2019 17 minutes ago, tortron said: Is that in the club mag? Maybe il inject my 1276 and go full Barry in the diyinjection thread Also welded aluminium to the intake manifold. Wat Originated from the ChCh club I think. Quote Link to comment Share on other sites More sharing options...
Nominal Posted May 12, 2019 Share Posted May 12, 2019 3 Quote Link to comment Share on other sites More sharing options...
tortron Posted May 12, 2019 Share Posted May 12, 2019 1 minute ago, Yowzer said: Hell yeah. You better be running it off an Arduino, using components raided from old DVD players and the likes I think you could use a single injector and screw it in where the jet goes underneath the SU Maybe I should make a few for the guys that don't want to use a sidedraught style hidden injector Quote Link to comment Share on other sites More sharing options...
tortron Posted May 12, 2019 Share Posted May 12, 2019 1 minute ago, Nominal said: This is so good. But it's Gona add a few months to my build Quote Link to comment Share on other sites More sharing options...
Nominal Posted May 12, 2019 Share Posted May 12, 2019 1 minute ago, tortron said: This is so good. But it's Gona add a few years to my build Happy to help! 1 Quote Link to comment Share on other sites More sharing options...
Yowzer Posted May 12, 2019 Share Posted May 12, 2019 I like how he still Barrytuned it without a widebane Quote Link to comment Share on other sites More sharing options...
kicker Posted May 12, 2019 Share Posted May 12, 2019 Half deaf... Tunes by ear 3 Quote Link to comment Share on other sites More sharing options...
kicker Posted May 12, 2019 Share Posted May 12, 2019 Half blind... Just eyes up measurements 2 Quote Link to comment Share on other sites More sharing options...
Mof Posted May 12, 2019 Share Posted May 12, 2019 Barry manifold injection starter kit 4 2 Quote Link to comment Share on other sites More sharing options...
tortron Posted May 12, 2019 Share Posted May 12, 2019 3 minutes ago, Mof said: Barry manifold injection starter kit I have something similar connected to a screen washer pump to mist my radiator on hot days 4 1 Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted May 12, 2019 Share Posted May 12, 2019 Just needs boost. Test out the quality british steel in those conrods. Quote Link to comment Share on other sites More sharing options...
Nominal Posted May 12, 2019 Share Posted May 12, 2019 11 minutes ago, RUNAMUCK said: Just needs boost. Test out the quality british steel in those conrods. 9 Quote Link to comment Share on other sites More sharing options...
ajg193 Posted May 12, 2019 Share Posted May 12, 2019 Here's some important reading for you morrie owning barries http://morrisminor.nz/nzmmf-judging-rules.htm Quote Link to comment Share on other sites More sharing options...
Nominal Posted May 13, 2019 Share Posted May 13, 2019 2 hours ago, ajg193 said: Here's some important reading for you morrie owning barries http://morrisminor.nz/nzmmf-judging-rules.htm Mayte, I've signed off convention entry forms to confirm that the entered vehicle is in the correct class. 1 Quote Link to comment Share on other sites More sharing options...
tortron Posted May 15, 2019 Share Posted May 15, 2019 How strong is an average trampoline spring? would one hold 5kg? Quote Link to comment Share on other sites More sharing options...
UTERUS Posted May 15, 2019 Share Posted May 15, 2019 Yep Quote Link to comment Share on other sites More sharing options...
tortron Posted May 17, 2019 Share Posted May 17, 2019 @Snoozin Quote Link to comment Share on other sites More sharing options...
kws Posted May 29, 2019 Share Posted May 29, 2019 I need to test the fuel pressure on my BMW to see if the FPR is working properly, but getting to the fuel hoses at the rail is a real pain. Is there anything stopping me from testing the fuel pressure down at the fuel filter under the car? Quote Link to comment Share on other sites More sharing options...
tortron Posted May 29, 2019 Share Posted May 29, 2019 So I messed around with that kick press a few pages back. 2mm seems a bit too much for it (without bolting it to the floor and kicking the crap out of it) but 1mm was passable probably the kick wasn't originally mounted that low and was bolted direct to the holes in the frame. Might get a full length male die plate made and cut it to fingers. 800mm might take a few kicks 1 Quote Link to comment Share on other sites More sharing options...
Yowzer Posted May 29, 2019 Share Posted May 29, 2019 3 hours ago, kws said: I need to test the fuel pressure on my BMW to see if the FPR is working properly, but getting to the fuel hoses at the rail is a real pain. Is there anything stopping me from testing the fuel pressure down at the fuel filter under the car? Should be fine. Don't they have a screw fitting on the rail for hooking a gauge up? Quote Link to comment Share on other sites More sharing options...
