ajg193 Posted October 28, 2018 Share Posted October 28, 2018 A bit of googling seems to indicate a fair few manufacturers are making transmissions that are extremely difficult to drain these days 2 Quote Link to comment Share on other sites More sharing options...
Alfashark Posted October 28, 2018 Share Posted October 28, 2018 Probably from the same voices in his head that tell him that anything less than max factory height is a mortal sin. Wet-clutch DSG units require a fluid change every 60,000km and have a very clearly documented drain/refill setup. Dry-clutch DSGs were designed as a filled for life unit, but received the wrong oil from the factory - global recall and refill via the drain and refill ports... Quote Link to comment Share on other sites More sharing options...
kws Posted October 28, 2018 Share Posted October 28, 2018 Stupidly, the ZF box in my BMW is meant to be serviced, ZF say, and it has drain and fill ports and ZF makes instructions on how to do it. BMW deemed they knew better, and marked it as "lifetime filled". My diff doesn't have a drain hole, once again because lifetime fluid. Quote Link to comment Share on other sites More sharing options...
mjrstar Posted October 28, 2018 Share Posted October 28, 2018 Zf in falcon has no drain plug either so you get covered in oil when you remove the pan.. does at least have fill plug though. 1 Quote Link to comment Share on other sites More sharing options...
M.H. Posted October 28, 2018 Share Posted October 28, 2018 Even the old 4 speed btr in the falcons didn't have drain bungs, was a messy job when I did the oil in mine Alot of new cars don't have a drain bung on the sump, oil gets sucked out Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted October 28, 2018 Share Posted October 28, 2018 BMW do that. Suck the oil out through the dip tube. The stories I hear from a mate at a BMW stealership they're ready for scrap before long anyway. Quote Link to comment Share on other sites More sharing options...
tortron Posted October 28, 2018 Share Posted October 28, 2018 700r4 no drain plug. Get the apprentice to do it I added a drain bung to mine. Do try it 4 Quote Link to comment Share on other sites More sharing options...
kws Posted October 29, 2018 Share Posted October 29, 2018 4 hours ago, 00quattro00 said: Even the old 4 speed btr in the falcons didn't have drain bungs, was a messy job when I did the oil in mine Alot of new cars don't have a drain bung on the sump, oil gets sucked out My Rover GM 3spd auto didn't have a drain bung. Very messy. Mercedes sucks the oil out at the dealership, but they still have drain bungs. Probably quicker to suck it out than to remove all the bloody under trays. Quote Link to comment Share on other sites More sharing options...
Ranter Posted October 29, 2018 Share Posted October 29, 2018 4 hours ago, RUNAMUCK said: BMW do that. Suck the oil out through the dip tube. The stories I hear from a mate at a BMW stealership they're ready for scrap before long anyway. Bmw's have no dip stick tube? Neither do their over rated oil leaking engines. Anyway drained a litre out of my transmission and it is mint. I understand the filters don't require replacing but its a filter I can change so I will, I do it to all my customers' cars to preserve a possible huge expense at the magic transmission specialist. (most of the transmissions we've had doomed by specialists that are still driving around many years later is suspicious) Also this one was the first I've seen with an internal fabric filter like an air filter, was perfectly clean but that's the point, making it stay that way. 7 Quote Link to comment Share on other sites More sharing options...
SOHC Posted November 1, 2018 Share Posted November 1, 2018 http://www.autodepoca8.com/files/2015/01/13/2483-tabelle_auto_inglesi.pdf?t=1421146662249 This might be of some use when trying to find out what oils to use, Quote Link to comment Share on other sites More sharing options...
ajg193 Posted November 1, 2018 Share Posted November 1, 2018 Seeing how that is pretty much all for shit british shit cars, shouldn't it just say "Any oil is better than no oil"? 1 Quote Link to comment Share on other sites More sharing options...
a.craw4d Posted November 15, 2018 Share Posted November 15, 2018 Can anyone recommend a brake caliper slide grease please? Have read I needs to be silicon base as oil base doesn't like the rubber boots. Have only found little sachets of it at supercheap. Quote Link to comment Share on other sites More sharing options...
SOHC Posted November 21, 2018 Share Posted November 21, 2018 On 15/11/2018 at 22:02, a.craw4d said: Can anyone recommend a brake caliper slide grease please? Have read I needs to be silicon base as oil base doesn't like the rubber boots. Have only found little sachets of it at supercheap. I would just use normal high temp grease as alot of things with grease in them have rubber seals. Quote Link to comment Share on other sites More sharing options...
SOHC Posted November 21, 2018 Share Posted November 21, 2018 Would vauxhall 2.6 extractors fit the vauxhall cresta pa 2.2 motor? Quote Link to comment Share on other sites More sharing options...
Yowzer Posted November 21, 2018 Share Posted November 21, 2018 3 hours ago, SOHC said: I would just use normal high temp grease as alot of things with grease in them have rubber seals. Different kind of rubbers. The seals in brake calipers will expand and deform with regular grease. BNT does a bottle of caliper grease, can't recall what it's called but it's in a green and white pot. Otherwise synthetic rubber grease like Fuchs works fine too. 2 Quote Link to comment Share on other sites More sharing options...
Yowzer Posted November 21, 2018 Share Posted November 21, 2018 Oh it's the same as what's in that tiny packet. Just in a 250ml pot. This one is probably what you're after. BNT should be able to get it https://www.permatex.com/products/lubricants/specialty-lubricants-brakes/permatex-silicone-ceramic-extreme-brake-parts-lubricant/ Quote Link to comment Share on other sites More sharing options...
tortron Posted November 21, 2018 Share Posted November 21, 2018 Who supplies non tridon thermostats for commo 3.8s? Current rather new one seems to be sticking closed Quote Link to comment Share on other sites More sharing options...
AllTorque Posted November 21, 2018 Share Posted November 21, 2018 Have you tried Holden? 1 Quote Link to comment Share on other sites More sharing options...
tortron Posted November 21, 2018 Share Posted November 21, 2018 What's your vin number sir? Probably will end up there, but hoping for a chain store that's just up the rd Quote Link to comment Share on other sites More sharing options...
SOHC Posted November 21, 2018 Share Posted November 21, 2018 1 hour ago, tortron said: Who supplies non tridon thermostats for commo 3.8s? Current rather new one seems to be sticking closed I just got a new tridon thermostat for a guy and it didnt work at all 1 Quote Link to comment Share on other sites More sharing options...
