Yowzer Posted January 6, 2018 Share Posted January 6, 2018 A Repco charger I got for work will charge a zero volt battery. It tests for resistance to determine if a battery is connected and has done a decent job of saving batteries that aren't too far gone. 1 Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted January 6, 2018 Share Posted January 6, 2018 I've had batteries that were so dead the charger wouldn't start charging. I put a good battery beside it, and bridged the tern in also with large ring spanners. Once it began to charge it was legit as. @SOHC What are Epsom salts, and where can I buy some? 1 Quote Link to comment Share on other sites More sharing options...
Alfashark Posted January 6, 2018 Share Posted January 6, 2018 Magnesium Sulphate, garden center or farm supply outfit. 25kg bag should be about $12-$15 at your local Farmsource/CRT/Wrightsons. Quote Link to comment Share on other sites More sharing options...
Carsnz123 Posted January 6, 2018 Share Posted January 6, 2018 you can get it from the supermarket but it's 3 times the price Quote Link to comment Share on other sites More sharing options...
igor Posted January 6, 2018 Share Posted January 6, 2018 But you'll only need a small bag for a couple of batteries. A 25 would last you years. Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted January 6, 2018 Share Posted January 6, 2018 The last thing I need is bag of some shit like that hanging around for years. Quote Link to comment Share on other sites More sharing options...
Alfashark Posted January 6, 2018 Share Posted January 6, 2018 Use it in the bath then, when you've rooted yourself/run out of talent on your bike. Quote Link to comment Share on other sites More sharing options...
SOHC Posted January 7, 2018 Share Posted January 7, 2018 23 hours ago, RUNAMUCK said: I've had batteries that were so dead the charger wouldn't start charging. I put a good battery beside it, and bridged the tern in also with large ring spanners. Once it began to charge it was legit as. @SOHC What are Epsom salts, and where can I buy some? Epsom salts = magnesium sulfate, you can get it from the supermarket and I think garden shops. Quote Link to comment Share on other sites More sharing options...
SOHC Posted January 7, 2018 Share Posted January 7, 2018 Where is a cheep place I could get my single cylinder tractor motor rebored and honed and crank reground? I use to go to one place that was around $30 to get a bore and hone on a single cylinder but its gone now. Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted January 7, 2018 Share Posted January 7, 2018 Given you haven't stated where you are even at im going to say India Quote Link to comment Share on other sites More sharing options...
oldrx Posted January 9, 2018 Share Posted January 9, 2018 On 1/7/2018 at 21:21, SOHC said: I use to go to one place that was around $30 to get a bore and hone on a single cylinder but its gone now. I wonder why!? 1 2 Quote Link to comment Share on other sites More sharing options...
SOHC Posted January 9, 2018 Share Posted January 9, 2018 53 minutes ago, oldrx said: I wonder why!? It was an old guy working from home who had a recondition shop, his wife became a total bitch and put an end to him working in the shed after he had hart trobble wile working on a home made aroplane 1 Quote Link to comment Share on other sites More sharing options...
igor Posted January 9, 2018 Share Posted January 9, 2018 Thereby ensuring that he died sooner than he should have. Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted January 19, 2018 Share Posted January 19, 2018 Tech spam query Does a clutch cover/pressure plate require and form of lube to work properly? Obviously not like add a quart of oil every three months. But do the fingers require anything to aid their operation? I ask because I've got one that is both rusty, and has generous amounts of black grot on it. I was thinking of banging it through a turbo wash before trying Seedy Al's trick with the citric acid. @Seedy Al What was that citric acid called at the supermarket? And what ratio did you mix it at? Quote Link to comment Share on other sites More sharing options...
AllTorque Posted January 19, 2018 Share Posted January 19, 2018 Sounds like time for a new clutch Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted January 19, 2018 Share Posted January 19, 2018 This is me saving coin by reusing a second hand unit which is less fucked than an end of life unit in the vehicle now. It would be stupid to spend one quarter of the vehicles value on a new one when I'm only going to sell it. The used one I have was known to not slip when last in service. I may have overstated how grot it is. Most of the.black grot will be clutch dust. I figure a turbo washing/decontamination will improve the derusting capability of the solution. I might well.swap out the rear main seal while I'm. Under there. (Depending on how $$ it is) Being able to drop a skid instead of slipping up a storm will go a long way to.improve salability of the car. Quote Link to comment Share on other sites More sharing options...
AllTorque Posted January 19, 2018 Share Posted January 19, 2018 How easy will it be to sell with a clutch shudder? Quote Link to comment Share on other sites More sharing options...
Transom Posted January 19, 2018 Share Posted January 19, 2018 2 hours ago, RUNAMUCK said: What was that citric acid called at the supermarket? And what ratio did you mix it at? It's called citric acid at the supermarket usually next to the tartaric acid and baking powder and spices and stuff 1 Quote Link to comment Share on other sites More sharing options...
Adoom Posted January 19, 2018 Share Posted January 19, 2018 Electrolysis ing. Seeing how it does with the rusty bits on the bottom of the door. I've not bothered cleaning anything first. Unfortunately, I didn't remember the measurements of the doors and the longer front doors are about 30mm longer than the planter box. 3 Quote Link to comment Share on other sites More sharing options...
Carsnz123 Posted January 20, 2018 Share Posted January 20, 2018 Testing out @SOHC's Epsom salt in battery sharn. Will report back with results when battery is charged. 3 Quote Link to comment Share on other sites More sharing options...
