Roman
  • Replies 6.2k
23 hours ago, RUNAMUCK said:
I've had batteries that were so dead the charger wouldn't start charging. I put a good battery beside it, and bridged the tern in also with large ring spanners. Once it began to charge it was legit as.
@SOHC
What are Epsom salts, and where can I buy some?
Epsom salts = magnesium sulfate, you can get it from the supermarket and I think garden shops.
Where is a cheep place I could get my single cylinder tractor motor rebored and honed and crank reground?
I use to go to one place that was around $30 to get a bore and hone on a single cylinder but its gone now.
53 minutes ago, oldrx said:
I wonder why!?
It was an old guy working from home who had a recondition shop, his wife became a total bitch and put an end to him working in the shed after he had hart trobble wile working on a home made aroplane
  • Sad 1
Tech spam query
Does a clutch cover/pressure plate require and form of lube to work properly?  Obviously not like add a quart of oil every three months. But do the fingers require anything to aid their operation?
I ask because I've got one that is both rusty, and has generous amounts of black grot on it. I was thinking of banging it through a turbo wash before trying Seedy Al's trick with the citric acid.
@Seedy Al
What was that citric acid called at the supermarket? And what ratio did you mix it at?
This is me saving coin by reusing a second hand unit which is less fucked than an end of life unit in the vehicle now. It would be stupid to spend one quarter of the vehicles value on a new one when I'm only going to sell it. The used one I have was known to not slip when last in service.  I may have overstated how grot it is.  Most of the.black grot will be clutch dust. I figure a turbo washing/decontamination will improve the derusting capability of the solution.
I might well.swap out the rear main seal while I'm. Under there. (Depending on how $$ it is)
Being able to drop a skid instead of slipping up a storm will go a long way to.improve salability of the car.
Electrolysis ing.
Seeing how it does with the rusty bits on the bottom of the door. I've not bothered cleaning anything first.
Unfortunately, I didn't remember the measurements of the doors and the longer front doors are about 30mm longer than the planter box.
