Roman
The old man did his Val axles. Welded up all the stud holes, and made a vee'd edge plug for the access holes which he fizzed in. Machined it all smooth in the lathe and redrilled in the new 114.3×5.
Legit? Ask Clint.
Once it's done, who would know? Oh yeah, he redrilled the access hole too. And put a ring around the outside to increase the flange diameter to gain more meat outboard of the new stud holes.
  • Replies 6.2k
Get some brake hose clamps. Put one on each hose. See if you get a firm pedal. If so, get a friend to release the clamps one by one. If the pedal drops you know where the problem is.
If you don't get a firm pedal with clamps on the problem is before the hoses.
Another ABS question/oddity.
I've had my van's brake pedal try and kick back a few times, weird hard pulse in the pedal and the brakes seem to pulse with it, the harder you try and push the pedal to stop the harder it kicks and the brakes lose power.
Only seems to happen when either I've got a shitload of grass in the trailer of I've got no weight but I'm going downhill and have to brake hard/downhill in the wet.
Thinking it's possibly related to the proportioning valve I assume it has in the rear.
