RUNAMUCK Posted April 11, 2017 Share Posted April 11, 2017 The old man did his Val axles. Welded up all the stud holes, and made a vee'd edge plug for the access holes which he fizzed in. Machined it all smooth in the lathe and redrilled in the new 114.3×5. Legit? Ask Clint. Once it's done, who would know? Oh yeah, he redrilled the access hole too. And put a ring around the outside to increase the flange diameter to gain more meat outboard of the new stud holes. 1 Quote Link to comment Share on other sites More sharing options...
SOHC Posted April 11, 2017 Share Posted April 11, 2017 2005 ssangyong musso has a low brake peddle, the owner took it to a mechanic who had it for a month and couldn't find the problem. Anyone have an idea? Quote Link to comment Share on other sites More sharing options...
tortron Posted April 11, 2017 Share Posted April 11, 2017 bent pedal/bracket 1 Quote Link to comment Share on other sites More sharing options...
SOHC Posted April 11, 2017 Share Posted April 11, 2017 4 hours ago, tortron said: bent pedal/bracket It feels like air in the system, the shop spent days trying to bleed it, it has ABS to Quote Link to comment Share on other sites More sharing options...
tortron Posted April 11, 2017 Share Posted April 11, 2017 Gravity bleed it Quote Link to comment Share on other sites More sharing options...
SOHC Posted April 11, 2017 Share Posted April 11, 2017 I reckon its tapered brake rotors, as it happend after he put in new pads would a faulty ABS system cause a sinking low peddle? Quote Link to comment Share on other sites More sharing options...
AllTorque Posted April 11, 2017 Share Posted April 11, 2017 So get the rotors skimmed Quote Link to comment Share on other sites More sharing options...
SOHC Posted April 11, 2017 Share Posted April 11, 2017 4 minutes ago, AllTorque said: So get the rotors skimmed I was thinking more about brazing them up and grinding them back 1 Quote Link to comment Share on other sites More sharing options...
governorsam Posted April 11, 2017 Share Posted April 11, 2017 Soft brake hoses, can flex/expand. Grab the hose and get someone to stomp on the pedal. If you can feel it, its fucked. Happens a lot on old bikes, old cars. And shitty lines. 1 Quote Link to comment Share on other sites More sharing options...
AllTorque Posted April 11, 2017 Share Posted April 11, 2017 9 minutes ago, SOHC said: I was thinking more about brazing them up and grinding them back Man, I hope you're joking. 4 Quote Link to comment Share on other sites More sharing options...
AllTorque Posted April 11, 2017 Share Posted April 11, 2017 Get some brake hose clamps. Put one on each hose. See if you get a firm pedal. If so, get a friend to release the clamps one by one. If the pedal drops you know where the problem is. If you don't get a firm pedal with clamps on the problem is before the hoses. 3 Quote Link to comment Share on other sites More sharing options...
Transom Posted April 11, 2017 Share Posted April 11, 2017 How many abs systems have to be plugged into a dealer computer to cycle the abs system while bleeding ? A few I have heard of Quote Link to comment Share on other sites More sharing options...
SOHC Posted April 11, 2017 Share Posted April 11, 2017 I am not sure what the shop did but they had it for over 3 weeks and couldn't fix it, We will try clamping off different parts of the system, but yes It may need some factory equipment for bleeding Quote Link to comment Share on other sites More sharing options...
governorsam Posted April 11, 2017 Share Posted April 11, 2017 Clamping can fuck hoses. If you go too tight. Just enough to stop the pressure. Like having to stop mid stream while having a piss to write your name in the snow. Too much clamping will do damage. 2 Quote Link to comment Share on other sites More sharing options...
Raizer Posted April 11, 2017 Share Posted April 11, 2017 Another ABS question/oddity. I've had my van's brake pedal try and kick back a few times, weird hard pulse in the pedal and the brakes seem to pulse with it, the harder you try and push the pedal to stop the harder it kicks and the brakes lose power. Only seems to happen when either I've got a shitload of grass in the trailer of I've got no weight but I'm going downhill and have to brake hard/downhill in the wet. Thinking it's possibly related to the proportioning valve I assume it has in the rear. Quote Link to comment Share on other sites More sharing options...
Mof Posted April 11, 2017 Share Posted April 11, 2017 Sounds normal Especially with no weight in the back, would be easy for a back wheel to lose traction Quote Link to comment Share on other sites More sharing options...
Mof Posted April 11, 2017 Share Posted April 11, 2017 If you tweaked the proportioning valve to give more brakes to the back, I bet it would get worse/more often Quote Link to comment Share on other sites More sharing options...
Raizer Posted April 11, 2017 Share Posted April 11, 2017 Mint, have only had one other car with ABS and I don't think the Altezza has any sort of proportioning valve lol. Normal it may be, but shit it can give you a fright! Quote Link to comment Share on other sites More sharing options...
Mof Posted April 11, 2017 Share Posted April 11, 2017 And I'm assuming you mean a load sensing type valve Quote Link to comment Share on other sites More sharing options...
Raizer Posted April 11, 2017 Share Posted April 11, 2017 Yeah I'm assuming Toyota stuck one under Super Customs like they did with trade spec HiAces, just haven't actually had a look yet Quote Link to comment Share on other sites More sharing options...
