Yowzer Posted January 25, 2016 Share Posted January 25, 2016 Pop it off and check the brushes. I bet they're nothing more than stumps Quote Link to comment Share on other sites More sharing options...
Rookie Posted January 25, 2016 Share Posted January 25, 2016 What yowser said. Quote Link to comment Share on other sites More sharing options...
Mr Vapour Posted January 26, 2016 Share Posted January 26, 2016 Check that the power is making it over the terminals in the solinoid? If the solinoid is clicking but not turning, chances are it's the brushes or contacts in the solinoid. If you tap the end cap with a hammer and it starts it's the brushes, the tap is often enough to move the brushes enough to make contact on the com. If the tap is not making a difference Chuck a test light in the cable that goes between the solinod and the starter if it's weak or nonexistent on crank, the power is not making it through the terminals in the solinoid cap. Quote Link to comment Share on other sites More sharing options...
Sparkle Posted January 30, 2016 Share Posted January 30, 2016 Stalled it in the driveway on fri after coming home, wouldn't start. Banged starter motor with wheel brace, bang, starts. Guess thats the problem! Why the hell would have jump starting made it work though? Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted January 30, 2016 Share Posted January 30, 2016 My coon was the same when I had a bad connection on solenoid. Always assumed it was extra volts managing to make a connection through the crud Quote Link to comment Share on other sites More sharing options...
Yowzer Posted January 31, 2016 Share Posted January 31, 2016 Conveniently placed coincidence. It's not pulling any power if the brushes aren't contacting so supplying additional power won't make any difference. 14V at the solenoid could have maybe caused it to smack closed just that little bit harder though, shaking the offending brush into place. Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted January 31, 2016 Share Posted January 31, 2016 Although this has never happened to me before, is there any reason I should have got a zap from the dizzy body of Nikis Austin while adjusting the timing? I didn't touch the leads, I'm not an idiot lol. Cap is newish, leads seem good and are fairly newish also. Engine developed a miss on test drive tho....... I had got the zap before the test drive. Chances of spark earthing out inside the dizzy? Earth wires seem complete but you never know with old BMC stuff lol. Quote Link to comment Share on other sites More sharing options...
AllTorque Posted January 31, 2016 Share Posted January 31, 2016 Assuming you had the key on at the time. Spark could be tracking down the rotor. Quote Link to comment Share on other sites More sharing options...
NickJ Posted January 31, 2016 Share Posted January 31, 2016 Dust and gunk on/in the cap, had it happen to me like that, not fun! run the car at night, you might see the leak  Also could be a shitty earth from the points back to the block if thats dirty Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted January 31, 2016 Share Posted January 31, 2016 ignition was on, as the car was running to set timing lol. Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted January 31, 2016 Share Posted January 31, 2016 rotor is also newish lol Quote Link to comment Share on other sites More sharing options...
AllTorque Posted January 31, 2016 Share Posted January 31, 2016 ignition was on, as the car was running to set timing lol.Ah fuck. Brain fart. Quote Link to comment Share on other sites More sharing options...
AllTorque Posted January 31, 2016 Share Posted January 31, 2016 Sounds like spark is tracking somewhere. No water in dizzy post steam clean? Quote Link to comment Share on other sites More sharing options...
UTERUS Posted January 31, 2016 Share Posted January 31, 2016 For a fun night time activity, grab a bit o wire and connect one end to ground and grasp the other with your digits. Go poking around the distributor and see if you can get any arcs. 3 Quote Link to comment Share on other sites More sharing options...
Yowzer Posted January 31, 2016 Share Posted January 31, 2016 I had a mitsi that had a fuckered HT lead, and the spark would intermittently escape from under the boot and doort down the side of the cap. Could be that if your HT leads are too high resistance, adding your hand to the equation makes the jump from cap to base all that much easier. Quote Link to comment Share on other sites More sharing options...
Ghostchips Posted January 31, 2016 Share Posted January 31, 2016 Although this has never happened to me before, is there any reason I should have got a zap from the dizzy body of Nikis Austin while adjusting the timing? I didn't touch the leads, I'm not an idiot lol. Cap is newish, leads seem good and are fairly newish also. Engine developed a miss on test drive tho....... I had got the zap before the test drive. Chances of spark earthing out inside the dizzy? Earth wires seem complete but you never know with old BMC stuff lol. how big a spark? If it was low tension side just need to clean around the dizzy or add am extra wire for earthing. Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted January 31, 2016 Share Posted January 31, 2016 it occurred to me while doing the dishes this had started happening on the way up to Napier before the crank broke in half..... hmmm...... ok, few things to try. Might swap over with dizzy from spare engine with new hardware in it and see if there is an improvement 2 Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted January 31, 2016 Share Posted January 31, 2016 I'd suggest buying a dishwasher. More time to work on cars...... 1 Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted January 31, 2016 Share Posted January 31, 2016 gotta clean my hands somehow 4 Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted February 1, 2016 Share Posted February 1, 2016 This page reminds me of lingling when he had a crack in his dizzy (or something) and electricity was escaping Quote Link to comment Share on other sites More sharing options...
