Yowzer 33,976 Posted April 28, 2019 Report Share Posted April 28, 2019 Hell yeah, launching off the top of the dunes when the others couldn't even make it up is pretty boss 2 Quote Link to post Share on other sites
kpr 6,427 Posted April 28, 2019 Report Share Posted April 28, 2019 It does pretty well against safaris and the likes in the mud/dirt. but not really night and day difference like in the sand. The lower tyre pressure, power and less weight combo makes it work on the sand. sits on the top and arab spec it on the limiter. plus can just send it over any bumps with the coilovers and hydro bumps 3 Quote Link to post Share on other sites
NickJ 3,919 Posted April 28, 2019 Report Share Posted April 28, 2019 The lack of bounce landing off those dunes is really impressive! Whats the ride like in the cab? Quote Link to post Share on other sites
KP_wag 751 Posted April 28, 2019 Report Share Posted April 28, 2019 44 minutes ago, kpr said: It does pretty well against safaris and the likes in the mud/dirt. but not really night and day difference like in the sand. The lower tyre pressure, power and less weight combo makes it work on the sand. sits on the top and arab spec it on the limiter. plus can just send it over any bumps with the coilovers and hydro bumps Yeah, have to admit when you told me you were building this (ie 4age turbs) I bit my tongue as didn't think it was gonna work, I suppose if rock crawling or other technical stuff the slow torquey trucks would win but sure owns the mud/sand/rev it terrain Quote Link to post Share on other sites
KP_wag 751 Posted April 28, 2019 Report Share Posted April 28, 2019 P.s. Nice jump, you got like 3 foot of air that time 1 Quote Link to post Share on other sites
kpr 6,427 Posted April 28, 2019 Report Share Posted April 28, 2019 its got 4.7 crawler gears in the transfer case, so does the slow stuff all good. most of the stuff in that vid i was in 1st high range. 5th in low range is about same as 1st high range. something between 1st and 2nd high would be good 1 hour ago, NickJ said: The lack of bounce landing off those dunes is really impressive! Whats the ride like in the cab? when its in the middle ground it works sweet. shocks valved pretty hard with light spring rates. so over the little stuff like washboards on a gravel road its pretty bumpy. the harder you drive it the smoother it gets, until run out of suspension travel. Its really limited by bad front /rear weight balance, nose dives and makes tuning the rear suspension a pain. Not bottoming out but close to no travel left on those jumps. landing still feels ok in cab. much more would be a bad day. Quote Link to post Share on other sites
KP_wag 751 Posted April 29, 2019 Report Share Posted April 29, 2019 How do you think it would crawling through a rock field, do you have the throttle control to keep it in its powerband and still under control at very low speed? This is where I'd expect it could get tricky compared to a low revving big flywheel 8 for eg. I imagine the 4-links would carve up the rocks tho Quote Link to post Share on other sites
kpr 6,427 Posted April 29, 2019 Report Share Posted April 29, 2019 just hit it at speed. its super horrible at low revs at the moment, due to the big plenum and cam timing im running. stalls out real easy. but have a fix planned when makes it to the top of the list... its not as bad as it sounds, since what little low rev torque it has is multiplied so many times. but yep something diesel would destroy it with same gearing. Not really that interested in rock crawling. so happy with the compromise As far as usable powerband goes its actually better than most engines. since goes to 9 can get wheel speed up without changing gears. 2 Quote Link to post Share on other sites
niswhale 113 Posted April 29, 2019 Report Share Posted April 29, 2019 Need to experience this thing to fully believe it. Only down side so far, is it has the turning circle of a container ship and is shit house at snatching a Safari bogged to the door handles. 2 Quote Link to post Share on other sites
Mof 13,358 Posted April 29, 2019 Report Share Posted April 29, 2019 Let's be honest, a safari bogged to the door handles is as heavy as a container ship. 2 Quote Link to post Share on other sites
UTERUS 18,595 Posted April 29, 2019 Report Share Posted April 29, 2019 Lol why would you even bother bringing up rock crawling, there's fuck all of that in the North. This thing is dope for what terrain we have, mud and sand. 1 Quote Link to post Share on other sites
MACKAZ 3,075 Posted April 30, 2019 Report Share Posted April 30, 2019 I lol heartily at these 1jz comments dropkick posts. Don't even sound like a six. 3 1 Quote Link to post Share on other sites
KP_wag 751 Posted April 30, 2019 Report Share Posted April 30, 2019 8 hours ago, UTERUS said: This thing is dope for what terrain we have, mud and sand. Because of this ^. It seems to own all other trucks everywhere so wondering how it'd go in the rocks. Not that I've seen/done much of it but rock crawling is pretty fun, something about an adrenaline rush at 2kmh... 2 Quote Link to post Share on other sites
Ashkellybarr 1,030 Posted May 2, 2019 Report Share Posted May 2, 2019 I think offroad regardless of terrain is weight and ratios. you have all seen how slow my old thing is, dunes and not so mudy bush tracks it keeps up with anything. just needs a fucking good run up for sand hills cause it’s go no torque once momentum is lost, nothing more power can’t fix but it weighs 1400kg. Mates 07 rodeo with steps and bullbar is 2100, and safs get over 3t easily. thats a lot of weight pushing tires down into mud, or trying to lift the front wheel over a rock. a lot of those top crawlers are pretty much tube frame chassis, couldn’t imagine many would be over a ton 1 Quote Link to post Share on other sites
Ashkellybarr 1,030 Posted May 2, 2019 Report Share Posted May 2, 2019 Kris’ lux pulls hard to! And it’s actually not that bad in the cab at all. far cry from my leafs all round haha 1 Quote Link to post Share on other sites
dave 183 Posted May 8, 2019 Report Share Posted May 8, 2019 Cool truck krisp pity it can't crawl through rocks thou 1 2 Quote Link to post Share on other sites
AllTorque 41,759 Posted May 8, 2019 Report Share Posted May 8, 2019 Great vid. 1 Quote Link to post Share on other sites
UTERUS 18,595 Posted May 8, 2019 Report Share Posted May 8, 2019 @kpr that was amazing, see you at ultra4? 1 Quote Link to post Share on other sites
puddles 186 Posted May 10, 2019 Report Share Posted May 10, 2019 Love this truck mate, thanks for the vids Quote Link to post Share on other sites
Hurmeez 1,079 Posted July 10, 2019 Report Share Posted July 10, 2019 I really like what you've done with the trumpets on the itbs. How are you sealing/fixing them to the inlet of the throttle body? I've been thinking about welding a modified off the shelf trumpets to some heavy wall ally tube with a shoulder machined into it and running with an o-ring to make them snap into place but I'm curious to hear about how you went about it. Quote Link to post Share on other sites
