kpr 6,491 Posted July 11, 2019 Report Share Posted July 11, 2019 just using short silicone hose on my na setup, works fine. will do the same on this missing the hose clamps in this pic 4 Quote Link to post Share on other sites
WhangareiKE70 586 Posted September 3, 2019 Report Share Posted September 3, 2019 @kpr, Have recently been thinking about how to do the fuel setup in my 4WD Datsun 720 with an RB25DET. The chassis is from a GQ/Y60 Patrol/Safari wagon so the tank is in the rear. Will likely be running an Aux tank as well in the further forward section, but that will just pump into the main tank. Seeing you used one of the Holley hydramats, you said you used it because you couldnt put a drop sump into the tank in the right area. Would you still recommend it if I could just do that? Essentially, I was thinking a drop sump, plus this: https://www.trademe.co.nz/Browse/Listing.aspx?id=2294404954 In the standard tank, running 2x Bosch 044s. It may be overkill, as I am only aiming for 3-400hp initially (probably toward the lower side of that for reliabilities sake) initially. But I want to future-proof and allow for potentially using E85 in future which would require a lot more flow. Any thoughts around whether a hydramat is a better option than the drop sump or necessary/thoughts in general? TIA. Quote Link to post Share on other sites
kpr 6,491 Posted September 3, 2019 Report Share Posted September 3, 2019 The hydramat seems to work amazing. But wouldn't bother doing both, either just run a hydramat in stock tank, maybe with some fuel foam. or do a good drop section or surge tank. which ever is cheapest / easiest. The hydramats are pretty pricey, but worth looking at if it makes your life easier 2 Quote Link to post Share on other sites
Ashkellybarr 1,030 Posted September 9, 2019 Report Share Posted September 9, 2019 1 Quote Link to post Share on other sites
KP_wag 758 Posted October 27, 2019 Report Share Posted October 27, 2019 Is the transfer case mounted handbrake factory on these? I have the same (factory) on the BJ and look forward to one day ridding myself of it Quote Link to post Share on other sites
kpr 6,491 Posted October 27, 2019 Report Share Posted October 27, 2019 Handbrake is on rear drums factory. transfer case one that come off is a trailgear setup. will likely redo the rear brakes with calipers that have internal hand brake. run a normal style handbrake leaver between seats Quote Link to post Share on other sites
~Slideways~ 2,173 Posted November 10, 2019 Report Share Posted November 10, 2019 Enjoying all the fabrication work on this thing. Out of interest what fuel line are you using? 1 Quote Link to post Share on other sites
kpr 6,491 Posted November 10, 2019 Report Share Posted November 10, 2019 just nzkw 450 series. stuff at tank end been on there almost 2 years, seems fine Quote Link to post Share on other sites
~Slideways~ 2,173 Posted November 10, 2019 Report Share Posted November 10, 2019 15 hours ago, kpr said: just nzkw 450 series. stuff at tank end been on there almost 2 years, seems fine Cheers good to know. Quote Link to post Share on other sites
Dudley 214 Posted November 11, 2019 Report Share Posted November 11, 2019 Dude that's a nice looking nardi ya got there. 1 Quote Link to post Share on other sites
kpr 6,491 Posted November 11, 2019 Report Share Posted November 11, 2019 Yeh not bad aye. pity this shitcunt called @dave ripped me off Quote Link to post Share on other sites
Dudley 214 Posted November 12, 2019 Report Share Posted November 12, 2019 Luckily that shitcunt @dave is a good cunt and super like amazing or otherwise fuck that dude aye Quote Link to post Share on other sites
Stu 1,090 Posted November 24, 2019 Author Report Share Posted November 24, 2019 You love wiring 1 Quote Link to post Share on other sites
Roman 14,361 Posted November 25, 2019 Report Share Posted November 25, 2019 It would be awesome if writing @dave tagged every single David on the forum. Which is essentially everyone 2 2 Quote Link to post Share on other sites
kpr 6,491 Posted November 25, 2019 Report Share Posted November 25, 2019 The OG @dave was an impostor. Thats why he got banned aye @Dudley Quote Link to post Share on other sites
Dudley 214 Posted November 25, 2019 Report Share Posted November 25, 2019 Some krispy guy narked on him from memory. But his presence is always felt in ya build threads 1 Quote Link to post Share on other sites
Dudley 214 Posted December 22, 2019 Report Share Posted December 22, 2019 Wow fantastic crimping on the battery cable 1 Quote Link to post Share on other sites
kpr 6,491 Posted December 22, 2019 Report Share Posted December 22, 2019 Key is to put a size smaller die in the crimper and just fucken send it. then all the glue heat shrink so no one can see the abortion you just made. 1 2 1 Quote Link to post Share on other sites
1vaknd 380 Posted December 24, 2019 Report Share Posted December 24, 2019 ive got a spare set of fc calipers if you need them 1 Quote Link to post Share on other sites
kpr 6,491 Posted December 24, 2019 Report Share Posted December 24, 2019 sweet, will pm you Quote Link to post Share on other sites
