Everything posted by 1vaknd
1vaknd replied to h4nd's topic in Other Projects
not sure what it was for, my mate has the same one on his subaru brumby, so who knows -
the shell its mint its just the valance and bonnet that are rotten which I have spares, container has vents on the doors (facing the prevailing wind) and a whirly bird on the back end of the roof -
Organising long term projects and parts Got a lucky streak as @AE25 knew a guy that worked for a company that needed to clear out their old shelving. It's amazing how much stuff you can fit in a 40ft high cube -
Long time no update, unemployed life has got me busier than ever. I’ll start where we left off and chuck up what little photos I took along the way finished the sump, no photos of rubber flappy baffles bat it’s all in there. Ended up with an extra 200ml of volume and a sump that’s above the crossmember so a bash plate can be fitted(yet to make) Before the engine got thrown back in I tidied up the wheel tubs and the recessed firewall Had to do the clutch as dual mass flywheels aren’t ideal. Let alone when there is 30°-40° of slack in the stock flywheel. Aftermarket single mass setup was a fuck around as the flywheel didn’t seat on the crank properly. Anyway sorted that out and fired the engine in the hole. Mocked up the rear of the headers. Before sending it down to Stu at Precision Wiring Solutions. let’s just say, he’s an absolute wizard and worth every penny. Factory ecu and speedo cluster were reverse engineered to make everything work. Only thing we couldn’t do was the fuel guage so just used a vdo sender and guage. We got the engine fired up while it was there and checked everything over. sorted the fuel tank to run the factory pump in a surge tank setup which it a part of the main tank to minimise lines used, and just a high flow low pressure vdo lift pump feeding the main pump got the rear wheel tubs all welded in and tidied up I managed to talk mike Shaw into knocking out an n2 kit so that was promptly fitted moments after getting home from collecting it And then there is the plethora of other jobs required to get the the car to the point where the car can be “safely” Driven . Having the power company cut the power to replace poles from 9am-3pm the day before you’re meant to be on track puts a spanner in the works, none the less. My ambitious nature got there in the end! Tux chucked a vid together as we managed a bit of an Oldschool takeover at the cjc jerkfest day all in all the car went bloody well for a first outing. So much fun to drive and so snappy. Need to get the brakes working better, hydro actually working and new coils to hopefully fix the random hesitation from the motor that seems to happen at the sketchiest of times. plans? Well getting my life sorted out after taking redundancy from fonterra. Get all my stuff (shit) into a container to clear the workshop ready for fabrication and customer work. It will be on the back burner for a while until business is up and running, then I can sort the odds and sodds on this and give it a lick of paint!
So I’ve been chipping away over the past weeks. So much done but still so much to do! Managed to get the whole rear end dialed Just need to cap the upper arm boxes (can’t decide if I should make removable or just weld them on) Caliper brackets made and calipers mounted Made a start on the sump as the factory lower pan would have sat 40mm lower than the crossmember made an intake pipe by stretching a 3” tube over a 3”-5” sch40 reducer. Bit of grease and the press did the job Trying to decide header layout also Fixing up some back yard rust repairs, it’s only a seat time car but you gott make it look good atleast once So I’m getting there slowly. Going to try get fuel tank/lines in and dump done by next week as the loom should be ready to put in then. Will be good to fire it up. with only 5 days left of regular employment, the aim is to get this completed before my nomadic stint in the bush over summer
length of steering arm will only adjust the speed the wheels turn vs input (which also changes force applied to turn the wheels, longer =easier, shorter = harder) ackerman is based on drawing imaginary parallel lines down the sides of you "vehicle" intersecting the lower pivot of your king pin angle. moving the steering mount location, inboard or outboard of this will change your ackerman being front rack you want to move the mounts outwards so that the steering mount intersects the lower king ping piviot and aims towards the centre of the rear axle for optimal turning
also, most of the rare spares parts dont come close to fitting so track down originals if you can, still quite alot of ke3#/ke5# parts in aus
they were built with alot of aussie parts, brake calipers are girlock aswell. thas chrome sill trim is an aus spec thing also. you will find that the roof kin is roller pinch welded like how fuel tanks are made vs jap assembled spot welds. if you ever have to pull the axles out make sure you order a seal/bearing kit as they tend to leak if you dont replace the seal
Yay for Milty! -
nice. i love the aus spec interior with ashtrays in the rear passenger cards, looks tidy for the price
car colours are actual legends, i deal with with them often
that is some beautifully tight radius bends for the shock hoops! who did you go through to get them bent up?
not at the moment. but i can get some. ke3# mounts are the easiest to use as they are a smaller bracket than all others ie;AE86,KE70
i jsut want to have fun, thats all.it may not be built with a big fancy turbo and all the e-fame attachments, but i have alot more fab skills and knowledge these days so heres to a good laugh and many grassroots motorsport days to come. also working in the garage,garden is the only way my brain isnt in engaged in overdrive, its my own kind of therapy i guess.
i takes a certain quality in someone to be hated by the masses, crashing at hamptons while out on a hotlap in a completely untested car. then trying to sue the track is a good way to fire up the hate train
Was funny to scroll through this looking back at how dumb I was. Well let’s keep the trend going then shall we
- 29 replies
- 23
So I took a week or so off work going into level 3 lock down. Yay, get heaps done! Well nah, a lack of motivation turned up, kicked me in the dick and wasted most of my time off staring blankly at all of the things in the garage and around the house that needed attention. anyway I managed to get some things done all be it at a snails pace Up on stands so I can get all the rear end fab done. Will probably make rear section of the exhaust while I’m there and get the fuel tank made and installed. back to work tonight so I’ll bugger around and get the laser cutting drawings sent off to hopefully collect in around a weeks time. Hopefully it all goes together quickly. wiring man is happy to use stock ecu and engine loom so this will keep costs down. also scored bucket seats and harnesses for a steal so stoked about that
the process you mentioned for deoxidine is correct except ive only ever used water not metho, the protective layer is minimal and wont hold up if the car is left outside overnight. if the deoxidine goes powdery you havent washed it off enough before drying. if the manel gets a rusty orange haze you havent dried it fast enough, you are after a rainbow haze over the bare steel best to strip, send to blasters. get it home. spend a whole day with a vacuum and an air gun. then deoxidine, then lay some quality etch yourself
lockdown has kept me busy. Transferred all the suspension from 1vaknd Kp across to the hack rack pushed foward 24mm, drivers mount moved in to better accommodate the 3s engine mounts (solid) Ke70 rack and pinion fitted to the Kp housing and trimmed the rack side flanges for boot clearance need to re build inner tubs for clearance building clearance for max low and can adjust height according to spring rates and travel Waiting for laser cutters to open up so I can get the upper link mounts cut and finalise the driveshaft tunnel So many wires, sorting loom arrangement so it can be all sent away and made to work, gearbox tunnel and firewall waiting on sheet metal to complete
Hmmm, back with a Oldschool project. It's driving starlets sideways that got me into drifting, there has been a lot of starlet shenanigans going on of late so the proverbial bullet has be bitten When this kp61 sprint rolling body popped up for cheap. I had a couple of motor options in mind and within the week I found Chris EURON8 had a complete set up from an altezza that needed moving on. So no Hesitation, in it went! Hack the tunnel and firewall Shove it in Cowl all in place Had some cultures come in at work so took the dry ice home and chipped out the sound deadner the more I look through my parts the more I realise I don't need to buy. Should be a rather cheap and cheerful build
BBQ Build - Attempt to build a reverse flow offset smoker
1vaknd replied to Taistorm's topic in Other Projects
bunnings has finally got around to stocking the fire rope (also the flat stuff) so could try sealing the doors a little more or your chimney is rather tall so id say you a drawing too much cool air through any small gaps you have, try closing the chimney damper until you get some smoke seeping from the cracks around the door and your temp should rise -
the headlight wiring on ms65's broke me. negative triggered relay with no fuse. atleast on my aussie assembled one that i used to own
ive got a spare set of fc calipers if you need them
