Pushiepirate
Local Area
Outside NZ
634 profile views
Pushiepirate's Achievements
Advanced Member (3/5)
429
Brief clip of her rolling under pedal power.
After a long stint, over a year, of not being motivated she is back, went for red oxide primer, may get a top coat may get a patina look, will leave her as is for now and see what grows on me? Decided the tray was too high so chopped the top rung off also lowered the door to the same height, end result much lower look. Have plans for some form of cover for the tray and cockpit area, more soon….. Hopefully?…………
Changed the look of my bike again, she's changed more than the weather.
This is a cool a mini V8 with a blower!
Added a carrier made up from a push bike carrier and an old army bag.
Bit more progress, made up some panels for the front and a rear end tray made fairly light to so not so much usable, more for looks, paint next. Ploddin along with this build, replaced the ply side panels for the body with coroplast plastic sheets, easy to work with and more importantly light weight. Suicide doors of course.
1vaknd that's what I was after, need to move where the tie rod connects outside the line of where the wheel pivots, great diagram, thanks for your help.
Bit more done, apart from tuning the drive train added a few more bits top get the Volksrod look happening. Lowered the bonnet, the head lights that turn with the front wheels, wheel covers with VW hub caps. Added a smaller nerf bar and used the same fold down windscreens from the buggy, see above. Finally would be most grateful for some assistance from those with a little steering geometry knowledge? I am trying to get Akermann’s sorted with the steering, as in getting the inside wheel to turn a tighter circle than the outside wheel at full lock. Have mountied the outer tie rod in a few positions and can’t for the life of me get this sorted, see below where the outer tie rod is mounted, thank you.
Have a daughter who's talented, she did a nice pic of my bike.
After a couple of big sessions we have a drive train and it works! As I have stated have been concerned about the weight with the buggy body. Story within itself scored a bonnet locally in great condition, so now we have a Volksrod! Also had concerns about the gearing and brakes, no worries with the gearing plenty low enough to get going and cruise, if anything will probably have to gear her up a couple of cogs. Brakes are better than expected as well, all four rear wheels have brakes which helps, operated from a lever mounted outside the seats, emergency braking Fred Flinstone style! Plan to run her without the front bar maybe rig up a small nurf bar, pretty happy with where she’s at, looks like a Volksrod?!
- 9 replies
Whooohooo we have some progress, control as in steering in, also revisited the front end. Was going to have a rigid front end but thought what the heck, had the bits so went with suspension, see how she goes, if work out couple of bolts and she goes back to a solid set up! So you can steer her how about propulsion, mocked up the pedal position, the way things are looking they will sit lower. As I said up the top want to keep the VW theme rolling, so first VW bit a Ratty 60’s steering wheel. I live very isolated so you often fix and build things with what you have. Also as with most things I’m on a budget so best thing about this build so far what I’ve spent. Only items I’ve laid out cash on, some welding rods, the tyres, some spring washers and the steering wheel, all the rest scrounged from local tip, gotta be happy with that!
- 9 replies
To fairing or not to fairing that is my question? Boss lady not so keen, I'm a bit undecided, what do you think?
Been a Veedub fan since my teens, collection stuff that lived in a box for ages, found a bird cage stand and re purposed it as a shrine to the VW. Couple of semi rare items, the red 50/50s one year only Australia and Italy, also some Snowflakes up the top. VW lounge light, used a big valve for the stand, actually casts a VW emblem on the roof above.
So after a couple of big days finally got the rear end sorted, originally had the drive wheels out beyond the body. Revised this they now sit nicely in the space where the VW engine would have sat. So in a sense have the motor where it should be! Next sort out the chain drive, plan is to have two idlers up to the pedals. The outer wheels take some of the load, hoping most of the weight comes onto the middle drive wheels, all four have suspension, outers leaf springs, inners coils. Scored the outers off a children’s pram, the inners off an old school suspension mountain bike. After the drive system is sorted front end and steering, long way to go but getting there! Any tips criticism gratefully accepted.................?
- 9 replies
I remember seeing that, about an insect they thought was extinct, the Phasmid, believed to have been around since the dinosaurs!
