Bigger is better. Less exhaust pressure. Better spool.  Less manifold pressure, less heat build up and less likely to knock.
Not saying 2.5 wont work. But i would be going 3"
  • Replies 518
On 07/10/2019 at 13:17, Ashkellybarr said:
Think 2.5” would be to small for a 2.4L turbo with 10:1 comp and high rpm?
TBH with that setup id even be looking at 3.5"  for at least the front section
does depend how much hps and rpms you are talking though. and how much you value the free hps  and quicker spool less backpressure nets you.
Sweet I’ve got 3” straight of the turbo for the down pipe, reduces into 2.5 just past the bottom of the fire wall. Hard case fuel and brake lines are on the inside of that chassis rail.
might need to relocate them while its all a part..
The table on the previous page has peaked my interest, my pos racecar runs a stock b18cr which when new was probably good to a touch under 200 flywheel hp. It currently has a thin walled 2 1/4 stainless exhaust system... I could go and make a new system but it would be heavier and I'm 50:50 as to whether there would be any benefit. (based on 185hp listed for me 2 1/4 system)
Ideally a quick dyno session of a 3 inch side pipe vs the current full system would answer my question i guess. But i'm not really excited about spending monies on this thing.
I think its basically a fact that all hondas go harder with a 3" zaust? Just have to put up with the noise.
You can probably dig through the dead forums and find a million dynos on honda shit (with dead pic links :pale:). You definitely can for K20/24 every combo of parts has been tested if you look.
Looks like the baffle is broken in my starlet's muffler. I pulled the back half of the exhaust off of the car because it sounded like there was a stone rattling around in the rear muffler. It seems to be something similar in length to the muffler itself, so I guess it is the baffle.
What should I do? (It's a stainless exhaust system if that influences any opinions.. I also want the car to be quiet)
Stainless? That's not stock.
Put a mild steel muffler in.  It'll be fine.
What pipe dimensions, etc? Three quarter inch for the massive powerhouse K-series?
Been wondering how much weight difference there is for different pipe dias.
So from 2.5" OD (63mm) to a 3" (76) with the thicker walls theres about 2kg difference
In order for 2kg to pay itself off in terms of power/weight you only need to gain the tiniest fraction of power, like, 1hp and it's worth it
Grab new muffler from Autobend, zap it on and good to go.
OD: 76mm    Wall 2mm       2.5m  =  3.14kg  pir2
halve your weight  double your power and   prepare to weld it back together when it falls apart   :  Aluminium
  • Haha 1
3AU 1500cc. I had a front pipe bent up a while back in 1.5" to carry on from the existing 1.5" pipe. Charts say 80HP would be max for that size (I won't make that I don't imagine). Am I better off starting the lot again and upsizing the pipe, or will 1.5" be sweet? Looking to buy a combo bend setup, reso and muffler, some straight pipe, prices of which won't vary much between diameters I don't imagine. Easier to stick with 1.5", but if that will be shooting myself in the foot a bit, i'll upsize it. TIA
Certainly won't be doing that haha. Sweet thanks for that, will add on to what I have then, don't want loud noises. Just not keen on keeping the current system and finding out after five minutes of running it's full of holes.
I will be going down this route again soon on my 3.3 Commy.
I had a pair of 2" but was a bit too much bark so will do a single 2.5 soon. The current setup up sounds ok but the primaries are too small as I made a set of 202 headers fit my 12-port 3.3. The 202 headers sound much nicer IMO than the EFI as they take the front 3 into and 1 and rear 3 into 1 with a longish runner before collecting which gives it a nice rumble.
I would like to make a custom set with bigger pipe all the way through. I find when the exhaust is slightly smaller it tends to give it the desired rumble in the car but can sound a bit squeezed out the rear. I hope this makes sense?
Does this sound any good or do I just go big and loud??
