Spencer Posted September 12, 2013 Author Posted September 12, 2013 I probably have another one, giz a minute. Quote
Spencer Posted September 12, 2013 Author Posted September 12, 2013 Bolt holes must be the same though as people have done some ghetto manifold swaps in the past. Quote
ryanfels Posted September 12, 2013 Posted September 12, 2013 Im pretty sure the bolt patterns are the same, just the ports are a different size Quote
Steelies Posted September 12, 2013 Posted September 12, 2013 ah cool, i'll fire up solidworks later and check it out. thanks chaps Quote
ryanfels Posted September 12, 2013 Posted September 12, 2013 Actually T3 sell an adapter to run a rwd intake on a smallport so that must mean they definatly are the same bolt pattern https://technotoytuning.com/toyota/16v4age/4ag-big-port-small-port-adapter Quote
Simon Posted September 12, 2013 Posted September 12, 2013 Yeap bolt holes are same. Â 20v onto 16 valve you need to modify the two holes either end. Quote
ryanfels Posted September 12, 2013 Posted September 12, 2013 Yeap bolt holes are same. Â 20v onto 16 valve you need to modify the two holes either end. Â On the intake? Quote
Simon Posted September 13, 2013 Posted September 13, 2013 My bad. On the exhaust. Â I can draw something up if you have the measurements. Quote
AE25 Posted October 17, 2013 Posted October 17, 2013 Looking for a CAD file for blacktop ITB trumpet flanges. Ive found one that makes all 4 out of 1 piece but i want to make 4 seperate ones I've got these drawn up. even an injection mould tool to make straight trumpets in different lengths using neoprene (like the BT trumpets) and various other flanges like dcoe. future project Quote
bobdylan Posted October 20, 2013 Posted October 20, 2013 I've got these drawn up. even an injection mould tool to make straight trumpets in different lengths using neoprene (like the BT trumpets) and various other flanges like dcoe. future project  Can you make a 100mm trumpets for my silvertop? Quote
flyingbrick Posted October 20, 2013 Posted October 20, 2013 I reckon easiest way would be to lathe up a plug and mould trumpets with cf or fiberglass. I have no experience with injection molding but surely it's an expensive process? Quote
AE25 Posted October 21, 2013 Posted October 21, 2013 yeah the tooling is expensive. could produce a trumpet for like $1 ea. but when the cost of tooling is added in, be looking at retail price round $8-10ea. still hell of a lot cheaper than any metal equivalent. wont be this year bobdylan Quote
MKD Posted November 21, 2013 Posted November 21, 2013 if anyone needs a CAD program that's pretty much an exact copy of a few versions older autocad - Draftsight is free and apparently pretty good.  http://www.3ds.com/products-services/draftsight/  or if anyones a student, you can get student versions of prettymuch any autodesk product (the makers of autocad) for free if you can prove youre enrolled at a uni etc, its all on their website too www.autodesk.com  Quote
My name is Russell Posted December 5, 2013 Posted December 5, 2013 Anyone know of any software that will convert a silhouette image cleanly into DWG? I can clean up myself, but looking for something to save some effort. Ones i have used so far are rubbish unless an original CAD exported PDF file that still has the points embedded in file or however it works. Â Quote
ryanfels Posted December 5, 2013 Posted December 5, 2013 Anyone got a 4age itb flange? Â Im pretty sure there is one in here http://www.streetracing.co.za/forum/viewtopic.php?f=13&t=4819 Quote
peteretep Posted December 5, 2013 Posted December 5, 2013 low n slow, best way to do it is just by manually measuring everything and maybe comparing to a photocopy, it shouldnt take you more than 30 mins Quote
eke_zetec_RWD Posted December 5, 2013 Posted December 5, 2013 Anyone know of any software that will convert a silhouette image cleanly into DWG? I can clean up myself, but looking for something to save some effort. Ones i have used so far are rubbish unless an original CAD exported PDF file that still has the points embedded in file or however it works. Just scan it as a jiff, open it as a sketch picture in solid works and scale it off the size of paper you used when scanning it. Then either auto trace it or manual sketch over too of it. Works pretty sweet Quote
