  • Replies 271
Having it in DXF is a better idea as it is a universal file format, so can be opened/edited/viewed in pretty much all decent CAD programs. Laser/water cutters etc may not accept solidworks files if people want to send files directly to the cutters.
Yeah dxf's are much better for what we are doing here and the file size is much more acceptable. I can convert solidworks files to drawings/ dxf if anyone wants/needs
Did you know Photoshop can also open up dxf's
Need some solidworks help please!
I have a box with drafted sides
and i want to get a stainless shield cut that fits nicely inside this box, and i want it say 5mm from the top. How do i get solidworks to basically let me make a sketch that follows the faces where the plane i want to draw on intersect the model?
I have done one before, but i didnt like the way i did it. What i did was roll back to before all the fillets etc and create a new sketch and do a convert entities of the bottom of the box. Then extruded that up to the height i wanted with the 1deg draft on it, created another sketch on top of that with a convert entities of the top face, deleted the silly extrusion i made and just fixed all the lines on the remaining sketch.
Not the best way to do it, but it worked. Whats the correct way? surely solidworks has a feature where it draws a sketch of where a plane intersects a body?
I'm not sure if I'm interpreting what you want to do properly, but have you tried making a new plane offset 5mm from the top face (click on top face, reference geometry, plane, change offset).
Then create a new sketch on your plane, select the edges you want to sketch (hold down control, click on each edge), then either convert entities or offset entities. I would probably recommend offset entities so there is a 1mm gap.
ah, cool. I didnt realise i could do that. Cant do an offset entity though from the faces, but if i select the faces, convert entities, delete the crap i dont need and then offset those and set the original ones to construction, it should work.
Cheers :)
so, that doesnt actually work that way BTW...
If i convert entities of a drafted face, it will just give me both extremes, not where it intersects with my plane/sketch
i ended up using the intersect curve thing, but thats a 3d sketch so just drew a 2D sketch over the top and it was happy as larry
cheers. I thought that option wasnt available inside the sketch before, but it is.
I normally wouldnt care but it has to be pretty close to stop people from poking things at the 250V DC underneath it
