Mitch.W Posted October 18, 2014 Posted October 18, 2014 anyone have the dxf file for the silver top quad throttle flange? can't seem to find it in the library Quote
peteretep Posted October 18, 2014 Posted October 18, 2014 there are a few 4age throttle body flanges in there, what does it look like? Quote
peteretep Posted October 30, 2014 Posted October 30, 2014 hey yeah I had a look, could find anything. Best bet is to find a flange, get some verniers and download draftsight to draw it up, there is a guy on here that can watercut it for you once its drawn up Quote
My name is Russell Posted October 30, 2014 Posted October 30, 2014 Anyone got any CA18Det files? For anyfung Quote
Mitch.W Posted November 1, 2014 Posted November 1, 2014 hey yeah I had a look, could find anything. Best bet is to find a flange, get some verniers and download draftsight to draw it up, there is a guy on here that can watercut it for you once its drawn up Sweet, was just being lazy. i have solidworks so i will draw it up on there and upload it Quote
Vintage Grumble Posted January 7, 2015 Posted January 7, 2015 Hi guys, I need to open some DXF files, just to look at them, I don't need to muck about with them or anything, is there a simple/free program I can D/L so that I can view them? CHEERS! Quote
peteretep Posted January 7, 2015 Posted January 7, 2015 Draftsight will allow you to open and edit them. Although you dont need the editing ability it is the best program for the job. You will be able to measure things if needed too http://www.3ds.com/products-services/draftsight-cad-software/free-download/#xtor=AD-508-[swfreetools]-[middle]-[intext]-[www.solidworks.com] Quote
ruff kunt automotive Posted June 22, 2015 Posted June 22, 2015 has anyone got a cad for a 12a exhaust ? Quote
My name is Russell Posted November 2, 2015 Posted November 2, 2015 Hi Oldschool Does anyone have a SR20 sump DWG or Gasket i can trace? Want to get a ring cut so that I can weld it to my steel sump and bolt one of these up to it for a winged sump. I guess i could purchase the wing and throw it under a scanner Ok thanks. Quote
peteretep Posted November 2, 2015 Posted November 2, 2015 Surely buying a gasket would be the cheapest most reliable option? Quote
My name is Russell Posted November 2, 2015 Posted November 2, 2015 Nup nup, I'm making one of these gated SR20 wings fit to the bottom of a CA sump by geting a 10mm plate cut to the flange shape, then welding to the underside, plane flat after warp-age etc. Probably could just fold up a box but thought i would give this a go. hoping the gates will be better than a Russell special with bunnings style door hinges Should be ok for DWG now as I have ordered sump so will hopefully just fit under scanner at work. Quote
flyingbrick Posted April 9, 2016 Posted April 9, 2016 hey guys. Just tried uploading a file and have got an error. Has it been shut down for new uploads? Quote
peteretep Posted April 10, 2016 Posted April 10, 2016 where did you get the error? there is a file size limit that might be worth looking at, 2mb Quote
flyingbrick Posted April 11, 2016 Posted April 11, 2016 I'll try again tonight. I tried sending the page full of files/description etc and it just gave me a pretty non descript error. I'll try again tonight Quote
evil_si Posted January 4, 2017 Posted January 4, 2017 Ive got a shit load of dxf files manifold flanges, turbo flanges oil feed drains etc, sump profiles Also got 20v itb file needs slight tweaking on inside hole on each itb mount I'm on the h u nt for 1jzgte and 1600 mx5 exhaust flange profiles if anyone can help Quote
sidewaysickness Posted January 4, 2017 Posted January 4, 2017 12 hours ago, evil_si said: Ive got a shit load of dxf files manifold flanges, turbo flanges oil feed drains etc, sump profiles Also got 20v itb file needs slight tweaking on inside hole on each itb mount I'm on the h u nt for 1jzgte and 1600 mx5 exhaust flange profiles if anyone can help Do you happen to have the sump profile for a Bmw M50 engine? Quote
peteretep Posted January 4, 2017 Posted January 4, 2017 evil_si, you can upload all of the files into the CAD library yourself. Alternatively, if you think they are a mess, then you could send them to me as a zip file and I can clean them up a bit and upload them edit: there is a 1jz exhaust flange uploaded already. It is ready to be cut but if you have some time then it could probably do with a few mods to make it look nicer Quote
