Raizer Posted April 18, 2012 Share Posted April 18, 2012 But I think they'd pick up ISUZU on the rocker cover before they realised it didn't come with disc brakes.... maybe. Who knows, will see how it goes. Re the brakes, SL90 trim level came with discs, so if you can get the brakes looking like they have been there a while I doubt many WOF guys would bother trying to prove its not one. /tail lights would be an instant give away to anyone that does know HA's though lol Quote Link to comment Share on other sites More sharing options...
Jase Posted April 18, 2012 Share Posted April 18, 2012 before you get too excited about bike carbs the heads on these 1256's are a bit different, they're siamesed between the pots 1-2,3-4 and run two balance ports as well as being a top entry inlet. manifold would be tricky to make Quote Link to comment Share on other sites More sharing options...
zep Posted April 18, 2012 Author Share Posted April 18, 2012 Yeah, I have seen that. Surely I could just make a manifold similar to what they use for DCOE webers? I need to re-read that post Gordo made about tweaking the 1256 too, he mentioned something about the balance ports, etc. I'll have a yarn to Tony on the weekend and see what he recommends. Cool, top gauge it is! Quote Link to comment Share on other sites More sharing options...
Abarth Posted April 18, 2012 Share Posted April 18, 2012 Sweet car man, drive it over and take me for a ride! Leave the motor and just roll as is. 1.3 is still going to be slow as shit anyways even with big carbs and extractors. I would spend the money on lowering it properly, new bushes, fluids etc.. And painting the Gem. edit: Ive got a spare set of 40's from the Strada if you want to give them a go. Quote Link to comment Share on other sites More sharing options...
Jase Posted April 18, 2012 Share Posted April 18, 2012 go efi i reckon it'd be frickin amazing on gas, have some 1.6-1 ratio ecotec rockers with a roller centre bearing and tip that might smooth out the valvetrain you can have, cam would just need regrind to suit. Quote Link to comment Share on other sites More sharing options...
KKtrips Posted April 18, 2012 Share Posted April 18, 2012 If you went 1256 - it would be awes to see a small IDA bolted onto this with a sweeeeeet downport manifold.. Tunnel ram effect to the max! Quote Link to comment Share on other sites More sharing options...
zep Posted April 18, 2012 Author Share Posted April 18, 2012 Abarth, I can literally add 50% more horsepower by doing minor mods to a 1256. Also, a single 40 might be good, they are Dellortos? Quote Link to comment Share on other sites More sharing options...
77magnum13hundy Posted April 18, 2012 Share Posted April 18, 2012 get the big guys in da back even! does 80, choice as. just my opinion.... engine wise, stick with it stock, when your fed up with it, vectra sohc block, and 2l twin cam head, commy gbox, etc. anything in between that will be lack of power to cost ratio. Quote Link to comment Share on other sites More sharing options...
Snoozin Posted April 18, 2012 Share Posted April 18, 2012 DRLA Dellorto's can be had quite cheaply off Alfa 1700's too... just on the downdraft theme. Quote Link to comment Share on other sites More sharing options...
zep Posted April 18, 2012 Author Share Posted April 18, 2012 Hrm, I'll bet a 36 DRLA would be good on the 1256. Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted April 19, 2012 Share Posted April 19, 2012 I loved following this after waiouru. Looked so dinky on the road and I just wanted to pick it up and play with it. Hannah took some photos. I'll post em soon. I think just run the engine into the ground and enjoy cheap fun motoring. Then swap in an easy to get hold of 1256. Cheap engines and they go fine for what is expected of this car. I have owned and driven plenty and in a lightweight chevette they are fine and fucking thrifty on the gas. It'll never be a rocket ship unless you spend some coin and even with the standard engine it seemed much better up those hills than I expected it would fare. Check out the vauxhall viva forum as Paul bottomly on there has spent loads of time getting with his HA and knows a fair bit of stuff about them. Top bloke and bloody helpful! Quote Link to comment Share on other sites More sharing options...
Abarth Posted April 19, 2012 Share Posted April 19, 2012 Abarth, I can literally add 50% more horsepower by doing minor mods to a 1256. Also, a single 40 might be good, they are Dellortos? Haha, Ive heard that before. They are solex's but they still run fine and bolt up to a weber DCOE manifold. One should work in theory there as they are jetted for 130hp so using one should be good for 65 horse. Go to pick a part and get a single point fuel injection system off the Fiat Uno / Punto as those engines at 1000cc - 1300cc. They look identical to a carb purched up on the inlet manifold. I would roll with standard engine and get the handling and brakes sorted first. Those ball joints and bushes must be stuffed by now. tbh when I first saw this my initial thought was 2jz and that Oke20 corolla and powercruise. Then read the part about mounts Quote Link to comment Share on other sites More sharing options...
durty Posted April 19, 2012 Share Posted April 19, 2012 less talk about engine more talk about this sort of stz Quote Link to comment Share on other sites More sharing options...
zep Posted April 20, 2012 Author Share Posted April 20, 2012 Worst photoshop ever! Quote Link to comment Share on other sites More sharing options...
Toucan Posted April 20, 2012 Share Posted April 20, 2012 Bandwagon Quote Link to comment Share on other sites More sharing options...
KKtrips Posted April 20, 2012 Share Posted April 20, 2012 How much room under the seats? I had great results with a pair of 6x9's in boxes facing forward under the seats of my Austin - front staging sounded so bloody choice weirdly.. Quote Link to comment Share on other sites More sharing options...
zep Posted April 20, 2012 Author Share Posted April 20, 2012 Nah, not enough room aye, not at all. Might try and hide the speakers facing downwards under the dash. Quote Link to comment Share on other sites More sharing options...
Beaver Posted April 20, 2012 Share Posted April 20, 2012 how about a false panel under the dash with speakers mounted on it, them some type of fine cloth over it so you cant see the speaker. would just look like a black/colored panel Quote Link to comment Share on other sites More sharing options...
xsspeed Posted April 20, 2012 Share Posted April 20, 2012 do you want lush sound, or just sound? I got away in my old shitty corolla for years with just a pair of 4" speakers up front - never going to set the world alight but good enough for singing along to Katy Perry etc....wait, wat? /she wasn't making music back then but I digress. Quote Link to comment Share on other sites More sharing options...
zep Posted April 20, 2012 Author Share Posted April 20, 2012 how about a false panel under the dash with speakers mounted on it, them some type of fine cloth over it so you cant see the speaker. would just look like a black/colored panel Good idea. Maybe I can get some oldschool cloth from an old radio or something, would look pretty cool! Quote Link to comment Share on other sites More sharing options...
