kiwi808 Posted February 16, 2013 Share Posted February 16, 2013 Yes please *grins* Quote Link to comment Share on other sites More sharing options...
Evan Posted February 16, 2013 Author Share Posted February 16, 2013 LH 8871-59-760 RH 8871-58-760 the foxed.ca site has rx3 parts catalogues, you might as well grab some numbers from them and try those first you never know.... otherwise use those numbers. Quote Link to comment Share on other sites More sharing options...
kiwi808 Posted February 16, 2013 Share Posted February 16, 2013 the foxed.ca site has rx3 parts catalogues, you might as well grab some numbers from them and try those first you never know.... otherwise use those numbers. The parts numbers for the RX-3 stuff are no longer valid. Tried them a while ago with no joy, but will try my luck with the RX-7 ones. Thanks a heap for posting the numbers up! Quote Link to comment Share on other sites More sharing options...
Cullen Posted February 18, 2013 Share Posted February 18, 2013 what did that pile of rubbers cost? (if you don't mind me asking) Quote Link to comment Share on other sites More sharing options...
kiwi808 Posted February 23, 2013 Share Posted February 23, 2013 Awesome new engine set up. What are your plans for it? 1 Quote Link to comment Share on other sites More sharing options...
fryup Posted February 23, 2013 Share Posted February 23, 2013 Excellent engine choice. Lots of polishing to do! Quote Link to comment Share on other sites More sharing options...
Evan Posted February 24, 2013 Author Share Posted February 24, 2013 Awesome new engine set up. What are your plans for it? Will pull it apart to check everything/replace waterseals. Will be converted over to S5 single turbo. I was trying to avoid force fed engines buuuut fail haha. Should work out ok. Excellent engine choice. Lots of polishing to do! Na I'll be painting it all black haha, not a fan of the polished look. Quote Link to comment Share on other sites More sharing options...
Archetype Posted February 26, 2013 Share Posted February 26, 2013 It looks like you've been making pretty good progress in the last few months. What's putting you off from finishing it (I saw your comment in spam thread)? Quote Link to comment Share on other sites More sharing options...
Evan Posted February 26, 2013 Author Share Posted February 26, 2013 I can understand why you don't want it to end up like mine. Maybe keep it a bit simpler than what you're planning for it? Your 13B turbo and FC subframe isn't going to be cheap or easy. Its cheaper and easier than you probably realise. Ive crunched numbers and weighed options and its roughly the same cost as keeping it with the original subframe (rebuilding that) and a front mounted 12a.whats putting me off is its becoming a bit of a pain, that and $$.Im on the fence at the moment. Quote Link to comment Share on other sites More sharing options...
sr1600 Posted February 26, 2013 Share Posted February 26, 2013 Good choice of powerplant you can always swap back to a na motor but who wants to go slower I like where this car is going should be an oldschool trackday weapon Hell if you decide you dont like it ill swap you my whole NA setup Quote Link to comment Share on other sites More sharing options...
kiwi808 Posted February 26, 2013 Share Posted February 26, 2013 I like the 13b turbs plan best. You can easily get big horsey numbers with the right computer/intake setup/exhaust combo but still make it nice to drive. How much work is involved on the subframe swap and are you going to be doing all the work yourself? Quote Link to comment Share on other sites More sharing options...
SHGWAG Posted February 26, 2013 Share Posted February 26, 2013 JC Cosmo = Best block for forced induction applications. Massive intake ports factory. Slap on a S5 Turbo. Aftermarket computer. 200kw + at the wheels and you won't be stressing the engine. If you need any engine parts, hit up Fairview Motors on Te Rapa Straight, I got quite a few bits from there, my contact left but last time I went in a guy called Bevan? hooked me up with a pretty hefty discount (IIRC it was better than trade). Quote Link to comment Share on other sites More sharing options...
fruitwasp Posted September 12, 2013 Share Posted September 12, 2013 Hey Evan. I am most enjoying following you on this project. I also have a S1 RX7. Do you have anymore update & photos? Quote Link to comment Share on other sites More sharing options...
KKtrips Posted September 12, 2013 Share Posted September 12, 2013 Yeah Bevan - update your build thread. 1 Quote Link to comment Share on other sites More sharing options...
Evan Posted September 14, 2013 Author Share Posted September 14, 2013 oh Hi!. na nothings changed been busy with other stuff the last few months, will get back to it over summer hopefully. Â You should put up a build thread with some pics of yours Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted May 17, 2014 Share Posted May 17, 2014 Hey how's this going? Quote Link to comment Share on other sites More sharing options...
danger Posted May 17, 2014 Share Posted May 17, 2014 Do a skid Quote Link to comment Share on other sites More sharing options...
Evan Posted May 17, 2014 Author Share Posted May 17, 2014 hold on, there should be an update in a couple of days if everything that's being worked on right now goes to plan... 3 Quote Link to comment Share on other sites More sharing options...
64valiant Posted May 22, 2014 Share Posted May 22, 2014 Quick or I will update it with my purchase of parts for your car. 1 Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted May 24, 2014 Share Posted May 24, 2014 Hey man. So you did all that so you wouldn't have to drill and weld on the game rails? Quote Link to comment Share on other sites More sharing options...
