danger Posted July 4, 2012 Share Posted July 4, 2012 Oh and I think the only other thing you need going through your firewall is in the top left corner for the water squirter motor and possibly brake fluid level. I ran those through thre original hole for the loom which I'll weld up if I get around to painting the car. Quote Link to comment Share on other sites More sharing options...
Evan Posted July 4, 2012 Author Share Posted July 4, 2012 yea I follow ya. cheers for that. Quote Link to comment Share on other sites More sharing options...
danger Posted July 4, 2012 Share Posted July 4, 2012 Quote Link to comment Share on other sites More sharing options...
Evan Posted July 4, 2012 Author Share Posted July 4, 2012 bingo... pretty much how i pictured it being run. got a pic under the left fender? Quote Link to comment Share on other sites More sharing options...
danger Posted July 4, 2012 Share Posted July 4, 2012 No sorry, But it was just 2 wires down the inside of the chassis leg and out at the coil holes for coil power and the feed to the tacho Quote Link to comment Share on other sites More sharing options...
Evan Posted July 4, 2012 Author Share Posted July 4, 2012 sweet as, thanks again. Quote Link to comment Share on other sites More sharing options...
Evan Posted August 3, 2012 Author Share Posted August 3, 2012 danger if/when you see this, did you chop out the hot start relay? Quote Link to comment Share on other sites More sharing options...
danger Posted August 3, 2012 Share Posted August 3, 2012 Sure did. Cant really remember what it does but it was irrelevant when I'm running a 12a 4barrel with no eletrics or choke. Quote Link to comment Share on other sites More sharing options...
Evan Posted August 4, 2012 Author Share Posted August 4, 2012 Tis what I was thinking. (learning as I go) chur for confirmation Quote Link to comment Share on other sites More sharing options...
kyteler Posted August 27, 2012 Share Posted August 27, 2012 Camber adjust, problem solved? Quote Link to comment Share on other sites More sharing options...
Evan Posted August 27, 2012 Author Share Posted August 27, 2012 yea or that. will double check what the legal window of opportunity is seeing as they changed it. Quote Link to comment Share on other sites More sharing options...
kyteler Posted August 27, 2012 Share Posted August 27, 2012 Definitely worth investigating, a shame it's soooooo close yet so far. Quote Link to comment Share on other sites More sharing options...
Evan Posted August 27, 2012 Author Share Posted August 27, 2012 yea it is. the back is probably going to be a bigger prick,live axle and all, need to get the diff in and try the rims on for size. Quote Link to comment Share on other sites More sharing options...
kyteler Posted August 27, 2012 Share Posted August 27, 2012 I used to have some 15x6.5's (I think) I sold them to FLWLES's"S'"S'S's's''s brother up Hamilton ways. You might be able to do a swap with a pair of his if they're different. I'm sure he wouldn't mind a pair of slightly wider/less offset ones. That said, they look pretty fucking close to how mine were. Quote Link to comment Share on other sites More sharing options...
Evan Posted August 27, 2012 Author Share Posted August 27, 2012 oh yea, not really keen on going higher offset as it looks increasingly dumb. its all part of the struggle. may enquire about them though. cheers for the info. Quote Link to comment Share on other sites More sharing options...
kiwi808 Posted January 14, 2013 Share Posted January 14, 2013 Looking good mate, lol'd and the space saver tyre! *off topic* where did you get your wheel trolly's(sp) for your car? I have been after some for my garage for an age and never found any/ripco-supercrap don't sell them.. Quote Link to comment Share on other sites More sharing options...
Evan Posted January 14, 2013 Author Share Posted January 14, 2013 haha the spacesavers (theres 3) were/are a stop gap for the different PCD of the series 3 rear end. ah the dolly things are home made. just some box tubing cut up and welded into a square with trademe caster wheels put on each corner. you can get them from supercheap I've seen them there but these ones were made for less than half what supercheap want for them. Quote Link to comment Share on other sites More sharing options...
kiwi808 Posted January 14, 2013 Share Posted January 14, 2013 Awesomeness. I was going to make my own but my design was wood based (I'm a builder) but I like yours better. Didn't think to check trade me for casters, will look at some now. Quote Link to comment Share on other sites More sharing options...
kiwi808 Posted February 16, 2013 Share Posted February 16, 2013 hi mate, don't suppose you have the parts numbers for the door seals/rubbers do you? I have been trying to get some door rubbers for my 808 coupe, and according to the interweb (which never lies obviously) all the repro ones are poos but you can use early (series 1,2 & 3) RX-7 door rubbers and trim to suit. Also RX-7's are cool. Quote Link to comment Share on other sites More sharing options...
Evan Posted February 16, 2013 Author Share Posted February 16, 2013 You talking about the ones that run all the way around the door sealing between the door and the rest of the car? Quote Link to comment Share on other sites More sharing options...
