CaMpylobacter Posted April 7, 2014 Share Posted April 7, 2014 do people still fully pipe up with rubber air hose? Quote Link to comment Share on other sites More sharing options...
JasonK Posted April 7, 2014 Share Posted April 7, 2014 I used pvc air brake line for my setup Quote Link to comment Share on other sites More sharing options...
Spencer Posted April 7, 2014 Share Posted April 7, 2014 Yea PVC is the go. Sheepers rolls ridetech for self levelling, not cheap but good stuff. Quote Link to comment Share on other sites More sharing options...
sheepers Posted April 7, 2014 Share Posted April 7, 2014 yea mine is ridetech. cant rate those guys highly enough for the quality of the product and their support. real good to deal with. Quote Link to comment Share on other sites More sharing options...
Nominal Posted April 16, 2014 Share Posted April 16, 2014 Big 'ol detroit spring - 9.5kg. Hmm, what goes here? OK, so I'm tempted by the accuair valve block system, so it would make sense to use their controller too. Anyone used one? Quote Link to comment Share on other sites More sharing options...
Nominal Posted April 16, 2014 Share Posted April 16, 2014 Oh yes, the slippery slope is looking dangerous. Probably a good time to work out some front discs to share cert costs. Upper ball joint rubber is knackered, so might as well replace that. Power steering is leaking as usual. Argh! Quote Link to comment Share on other sites More sharing options...
AllTorque Posted April 16, 2014 Share Posted April 16, 2014 Chuck in some drop spindles for good measure. 1 Quote Link to comment Share on other sites More sharing options...
square Posted April 25, 2014 Share Posted April 25, 2014 I Can't work the internet Quote Link to comment Share on other sites More sharing options...
square Posted April 25, 2014 Share Posted April 25, 2014 OK, so I'm tempted by the accuair valve block system, so it would make sense to use their controller too. Anyone used one? Yep, got one in the current one and had one for 4 years in the last one. I think everyone I know running air systems has them. Small, quiet, slow, simple. Pulled the last one apart as it was getting slow, took an hour to clean and sort after 3 years of use. I just run mine with switches but I know guys that use the e-level thing and rate it. Quote Link to comment Share on other sites More sharing options...
Leebo3 Posted April 25, 2014 Share Posted April 25, 2014 Another here In this This the control you were talking about? Have you had a look on ridetech website Nominal? They do a few kits for 60s cars, would yours be the same as a galaxie pretty much? Quote Link to comment Share on other sites More sharing options...
Nominal Posted April 26, 2014 Share Posted April 26, 2014 Yeah, I had a look at the bolt-in kits, but I really prefer to roll my own. Some of the engineering doesn't look too hot, and the prices are high. I visiting Mark Bouzaid at MB Minitrucks in J'ville last week. Had a good chat. Need to get some $$$ together and start ordering parts. Anyone have a good suggestion for a factory rubber bushing for 4-bars? I thought of HQ Holden, but they have a kind of stepped design to suit the Holden arms. I want rubber, not urethane. Will have to go for a wrecking yard crawl I guess. Quote Link to comment Share on other sites More sharing options...
cletus Posted April 26, 2014 Share Posted April 26, 2014 i made a 4-link for a previous project, i used spring shackle bushes from a navara or something common that were easy and cheap to get. 1 Quote Link to comment Share on other sites More sharing options...
crownin round Posted September 14, 2014 Share Posted September 14, 2014 how do you size bags for your front and rear suspension ie is there a calculation ie bellow count x psi x area etc etc ie i looking for a set to lift a wagon rear end moderately quick and the front quick with a decent lump of engine ie v8 in it. or is speed all based on port size. also it has wish bone front and coil rear Quote Link to comment Share on other sites More sharing options...
Bangbug Posted September 14, 2014 Share Posted September 14, 2014 Excellent, I look forward to browsing this thread.Well done chaps. And cr, I think there are some spring rate calculations online and you pick a height and spring rate to suit what height you want your regular ride to be at. Then if you're going up or down you'll have a firmer ride higher and softer ride lower.... well not really, go lower and you'll hit something and it'll become very firm again If you have a retailer in mind, drop them a line and share their wisdom with us too Quote Link to comment Share on other sites More sharing options...
Nominal Posted September 15, 2014 Share Posted September 15, 2014 It all seems a bit random. There are specs available for the firestone bags so you can do calcs if you know the original spring rates, weights etc. I haven't seen any detailed specifications for the SS bags though. After a fair bit of google bashing (El Polacko on the HAMB is good), I've punted on SS7's for the front of the Merc. Takes ~70psi to get to ride height I think, so hope that works out OK. Quote Link to comment Share on other sites More sharing options...
Spencer Posted September 15, 2014 Share Posted September 15, 2014 Basically the biggest diameter bag that will work with your suspension. It's all pretty straight forward, get a bag that fits and put some air in it and see what's up. Rolling super slammed is always going to have lower pressure and not ride so well unless you can engineer shit around slam but then you probably won't get fuck all "up". The slam specialties bags cost a bit more but are the ones most people seem to swear by these days. Quote Link to comment Share on other sites More sharing options...
Nominal Posted September 15, 2014 Share Posted September 15, 2014 I'm not going any lower than the stock bump limits. Travel is actually restricted by the shock location and available stroke. At the end of the day, I doubt either setup will be worse than the stock suspension. It's not like yank tanks for old Toyota wagons are corner carvers Quote Link to comment Share on other sites More sharing options...
Leebo3 Posted September 15, 2014 Share Posted September 15, 2014 Do you know what you are going to do for the rear of yours nominal? 4 link? Rangi up air over leaf che cuz? Quote Link to comment Share on other sites More sharing options...
MRWEST Posted September 15, 2014 Share Posted September 15, 2014 got me an accuair kit with elevel for the 64. havent put in yet but stoked with the quality of the gear shes good stuff. Cool vid about accuair and how it started etc. 1 Quote Link to comment Share on other sites More sharing options...
Nominal Posted September 15, 2014 Share Posted September 15, 2014 Do you know what you are going to do for the rear of yours nominal? 4 link? Rangi up air over leaf che cuz? I'm planning triangulated 4-link. Haven't started that end yet. Got the same accuair controls - I agree sweet looking gear. I just have the rocker switch though (going cheap for now). Quote Link to comment Share on other sites More sharing options...
