If you go for electric pump - see if there are any vane type compressors available - they will be so so so much quieter - the thump of the piston as it reaches TDC is where a all the noise/vibration comes from in an electric pump....
  • Replies 400
also the bridgestone/firestone guy hasn't rung my back
rage
that 70-2000 number isn't relevant to anyone but that 'customs' outfit.
i spoke to the guy in nz and he said they don't do that stuff anymore, and they sold all their stock and pass all enquiries for light airbags on to http://www.airbagman.com.au/lightvehicle.html#
talked to them. they said to go further they need required measurements and shit. lewl.
Load is definitely related to pressure, in the front of your car because of the engine you usually will run allot more pressure than the rear to compensate. I was running maybe 30-40 more psi in the front
There are many controllers on the market, the most basic uses pressure senders. You will have predetermined ride-heights which relate to certain pressures you have setup. Problem with this is when you load up the car these pressures will now not relate to the ride height you want, as you now need more pressure to raise the car up.
To compensate the higher end controllers use simple potentiometers on suspension arms to determine ride height and compensate for load with these. You would have to be on a level surface for this to work of course
This is a more common (and expensive) controller, notice the level sensors are just variable resistors with arms you can mount to suspension components
http://www.ridetech.com/store/suspension-components/components-hardware/compressor-system-components/ridepro-e3-and-levelpro-components/ridepro-e3-control-system.html
Surely even the cheaper pressure sensor ones would be:
A. A whole step above in terms of ease of use to a conventional switch arrangement &
B. Still a viable option if the controller had a number of pressure settings, IE have an extra setting for the rear when laden with boes/bishes, little bit to setup to start but surely better than having to press switches and watch the gauges to get it right.
Oh shit yea they are fine! with 2 people or something in the back of the century you can just chuck a few more psi in the back and be done. Full auto levelling is just a nice option if you want to spend abit more
i don't see any were in there you can't have switchs and to lock out the system last time i ask the cert guy all i needed to do was run the earth for my switchs to the handbrake switch the one that makes the light come on, on the dash.
EDIT: just saw on the side note that you can't use park break switch
also make sure you make your hoses the same length
Im NOT keen on digital pressure gauges as i brought one and it was nothing but trouble it never sits on a reading like it shows in the pic every time someone or somthing moves in the car it put pressure on the bag witch makes the reading change so no point looking at it well driving as every bump you hit makes it go up and down
Pretty much, I want this
But different controller.
What's the go with shipping K-K-K-K-KOMBO BREAKER? Do you have hookups for ex USA stz?
Edit another post made by KK you sly dawg.
They're only place I've seen with the bags that go over strut tubes/not looking properly.
Priced up stz from Grants Kustoms too which seemed quite cheap on a lot of things.
I've looked HEAAAAPS for like 6 months and they all seem to refer back to this place - or if a website doesn't directly refer back to UA they sell bags branded by UA..
I am going to buy just the bags myself - I'll get the rest of it over here through Cam or someone like that.. LOL
