mkcortina Posted March 2, 2010 Share Posted March 2, 2010 most ppl just use a hole saw. I havnt seen any of these in NZ yet http://vansantent.com/sheet_metal_machines/punch_flare_tools_aircraft.htm I'm going to try and get a 2inch 1. frost in the uk has a 1inch 1 http://www.frost.co.uk/item_Detail.asp?productID=9120&frostProductName=Hole%20Flare%20(1in.)&catID=&frostCat=&frostSubCat=&subCatID= Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted March 2, 2010 Share Posted March 2, 2010 How do you get the curve with a holesaw? Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted March 2, 2010 Share Posted March 2, 2010 ball pein hammer Quote Link to comment Share on other sites More sharing options...
Truenotch Posted March 2, 2010 Share Posted March 2, 2010 Should be able to get Chassis punch & flare kits in NZ easy enough.... Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted March 2, 2010 Author Share Posted March 2, 2010 i just hole sawed the ones in my van Quote Link to comment Share on other sites More sharing options...
Leebo3 Posted March 2, 2010 Share Posted March 2, 2010 Just make sure you measure that shiz out 12 times. WTF anyway russell, you are tutored by the king of holes down there, old UJ. Quote Link to comment Share on other sites More sharing options...
Mk1Mad Posted March 3, 2010 Share Posted March 3, 2010 Expensive, but you can get them.... http://www.tradetools.co.nz/dbsweb/TTLWLCCL.pgm?VRID=1fy1X6gp0BTTvmbae4TwA6MGz6134701&MODE=*LIST&CLASS=NNN Nick Quote Link to comment Share on other sites More sharing options...
Mk1Mad Posted March 3, 2010 Share Posted March 3, 2010 Once you get the holes cut the size you want get UJ to turn up a flare. Wouldn't be much work, just two halves. Quote Link to comment Share on other sites More sharing options...
Unclejake Posted March 3, 2010 Share Posted March 3, 2010 I think you really want the correct tool for this job and as far as I can tell a Chassis Punch is the correct tool. Keep asking. Someone will have one you can rent or borrow. Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted March 3, 2010 Share Posted March 3, 2010 I think you really want the correct tool for this job and as far as I can tell a Chassis Punch is the correct tool.Keep asking. Someone will have one you can rent or borrow. Yeah i agree keen on a punch to pop em out properly 1st go, as i realised last night how little air flow im going to get to my radiator. Quote Link to comment Share on other sites More sharing options...
Gaz Posted March 3, 2010 Share Posted March 3, 2010 A normal punch wont do asit will warp the steel andwont cut circle once warped. I did my 50mm one in dash and it did this so I can only assume larger would be worse. If you still want to try I can get you one from Dads work. Gaz Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted March 3, 2010 Share Posted March 3, 2010 im after a special one i dont know what its called it may even be a two stage process that punches the hole and puts a curve on the panel steel edge. Quote Link to comment Share on other sites More sharing options...
Unclejake Posted March 3, 2010 Share Posted March 3, 2010 I would do a search on Punch and Flare Tool tool Quote Link to comment Share on other sites More sharing options...
Truenotch Posted March 13, 2010 Share Posted March 13, 2010 Ginormous bubbles!!!! I wouldn't recommend Federals from experience. They may have changed, but used to be slippery as sin! Also, 175 is way too soft. I run 450lb in the front of my car which is about 8kg. I think you should be aiming for the same. 200mm X 65id is a standard sized spring - they're normally worth about $80 each new for a king/dobi etc. Quote Link to comment Share on other sites More sharing options...
Gaz Posted March 13, 2010 Share Posted March 13, 2010 Dont get Federal. You are going to need to spend good $$$ on tyres, youve built the rest if the car to race so why go for shit tyres? If you doI bet you will buy new ones after the first test day! The dunlop direzza Dz101 are a mint tyres,id go with them as they are cheap and mint. Or the bridgestone equivilent. I also think 195 is way toskinny for the rear. At LEAST 205s Car looks good, will be mean to see running soon! Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted March 13, 2010 Share Posted March 13, 2010 Ginormous bubbles!!!! I wouldn't recommend Federals from experience. They may have changed, but used to be slippery as sin! Also, 175 is way too soft. I run 450lb in the front of my car which is about 8kg. I think you should be aiming for the same. 200mm X 65id is a standard sized spring - they're normally worth about $80 each new for a king/dobi etc. cool cheers boe will try find out what all the ones i have are Quote Link to comment Share on other sites More sharing options...
spanners Posted March 13, 2010 Share Posted March 13, 2010 Federals are shit x3 When I was working at tyre shops people would always come in saying how shit they were and then would proceed to have them removed.... Try TOYO R888's or something similar. Lots of stick, not as pricey as you would think. If you are racing on a track you would struggle on normal road tyres I would think. Fuck those arches look like a lot of work. This cars gonna be sicker than Fidel Castro Quote Link to comment Share on other sites More sharing options...
kyteler Posted March 13, 2010 Share Posted March 13, 2010 Why road tyres? The statement of "for SS2000" followed by Federal road tyres = confusion Quote Link to comment Share on other sites More sharing options...
Brock-Lee Posted March 13, 2010 Share Posted March 13, 2010 two of the springs I sold you( the red ones) are 8kg(~450lb) and two are 6kg(~335lb) Hope that helps haha. Quote Link to comment Share on other sites More sharing options...
xsspeed Posted March 13, 2010 Share Posted March 13, 2010 Hey bo, I checked for that handbrake cable - I only have one spare and plan to keep it for now incase something happens during my drum-disc conversion. As far as I can tell the hand brake cable is identical between the drums and discs models. Hard to measure as one set is on the car - but it looks like both have the same cable end bits (whatever they are called), and length must be almost the same if not exactly. Quote Link to comment Share on other sites More sharing options...
