low n slows mk1 2door
d.p.n.s
  • Replies 1.4k
Fuck me what a failure of a night, got absolutely nothing done just spent the hole night looking for stuff and being frustrated with nothing working.
Where can i get two large grommets that i can run about 60mm (to get plugs through) in diameter worth of wires through?
Need one for inside guard for mk2 loom and one in engine bay for engine loom.
do you want a heatshrink cable gland? exspensive but i may be able to find one. :lol: just heat it down when you finished , and they have thread n nut on one end if you eva have to take the loom out.
These are quite choice
http://www.electrex.co.nz/cable-glands.html
going to try get pair of the largest ones that open too 44mm and close down to 30mm should work or ill make em.
im talkin ones like these. fully water proof. 8)
and as for the relay question with your earths, only if your ecu will let you, you could try but my ca18 one uses earths from the ecu for some reason. get a wiring diagram for your ecu and go from there, cant go wrong :)
