low n slows mk1 2door
d.p.n.s
  • Replies 1.4k
These are some escort suspension setups I got photos of from the manfield meet just been
Note in this picture how the mount between diff and tramp rod is quite far from the housing to give good leverage ... iv been told idealy i want to get the eyelet about 160mm away from the housing (probably wont be able to achieve this due to ride height) and the bar at a 16 degree angle away from the housing.
The White Mk2 cossworth that was EXTREMELY quick with 300hp.
Could a sway bar be an alternative for a panhard rod.
Allan Man replica .... I think i will do my panhard rod the same as his .... Note the tube that travels across the back of the body providing support for were the rod mounts to the body (a difficult part to get a ridged mount too) and as a brace.
And a lotus escort thats "Been raced since factory"
nice :mrgreen:
just a few qustions mate if you can help
1 how wide is your diff from disc to disc?
2 what size wheels are on it ? and what off set?
3 are you front coil over set up alloy? just sitting on a steel ring.
cheers
dan
1. 1460mm however that was lying under the car trying to measure it myself. I may have the diff out tonight so will update with accurate measurements latter on.
2. 8" wide with 0 offset
3. Yup alloy sitting on steel seat that Jason turned up for me.
Just purchased oil cooler kit, now looking for oil catch tank and spacer kit.
http://www.trademe.co.nz/Trade-Me-Motor ... 078179.htm
http://www.trademe.co.nz/Browse/Listing ... =254311989
thanks for that mate
im going to shorten my diff housing by 70mm
that shout take it down to 1470 so that will be mint.
and i was wanting to build a coilover front end
and all ive seen is the alloy kits and for some
reason never thought of sitting them on a steel
ring and then grub screwing the lol.
thanks again
dan
thanks again
dan
If you can make these work could be a cheap set of coilovers! don't know there diameter or anything.
http://www.trademe.co.nz/Trade-Me-Motor ... 077450.htm
thanks again
dan
come grab this sway bar you can have a nosey at mine there steel weld on ones
nice :mrgreen:
cheers
dan
If its a early model hilux 1460 is correct
