eke_zetec_RWD Posted November 22, 2009 Share Posted November 22, 2009 yea nah they both need to be horisontal if you r only running rubber bushes Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted November 22, 2009 Share Posted November 22, 2009 Oh really .... FUCK FUCK FUCK IT WOULD TOO arrrrrr dumbass Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted November 22, 2009 Share Posted November 22, 2009 lol lucky its only tacked on...... i hope Quote Link to comment Share on other sites More sharing options...
fuel Posted November 22, 2009 Share Posted November 22, 2009 no cause the mount on the diff needs to pivot on the other axis - it's only going to deform so much as the rubber bush will allow it to and then it will either be bent panhard rod or torn off mount. *edit* whoops beaten to it haha Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted November 22, 2009 Share Posted November 22, 2009 What will happen if i leave it as is ... it wont pivot will it dow ok Bugger had it in there a nice tight fit n everything Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted November 22, 2009 Share Posted November 22, 2009 Haha cheers guys back to the drawing board Yup only tacked Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted November 22, 2009 Share Posted November 22, 2009 What will happen if i leave it as is ... it wont pivot will it dow ok Bugger had it in there a nice tight fit n everything argh like that you may as well not have a panhard rod, once they flex or bend while cornering they are pretty much useless. Quote Link to comment Share on other sites More sharing options...
Simon Posted November 22, 2009 Share Posted November 22, 2009 There must be a way to make that work if it fits well? Another bolt on the right hand side with axis parallel to car / driveshaft? Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted November 22, 2009 Share Posted November 22, 2009 rose joint i guess? Or i will just re arange the slot to vertical somehow, its only taked in place so not the end of the world, sums up my day well Had a picture of this in my head; And just presumed it would rotate at body mount/didn't think it through all that well Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted November 22, 2009 Share Posted November 22, 2009 just cleaning out my inbox boe, remembered you were wanting these still want them? sORRY FORGOT TO REPLY TO THIS .... NA ALL GOOD NOW MAN CHEERS ANYWAYS. Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted November 22, 2009 Share Posted November 22, 2009 cHEERS FOR ADVICE ON GAUGES d.p.n.s The tacho and speedo turned up thismorning both with steeper motors... they instalation instructions look a little hard to work out Look like choice little units Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted November 23, 2009 Share Posted November 23, 2009 d.p.n.s ... question time The wire i have running between the two gauges "Daisy Chain" is this correct? so i can have the "power wire harness" going into one of the gauges and the use the "Daisy Chain" to take power across to they gauge next door? Just going to have a read of the 'link' manual to check speed o and tach can be taken from it ... i hopeso. Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted November 23, 2009 Author Share Posted November 23, 2009 from what i was told when i was looking at them yes thats the way to do it but i ended up getting a completly differant tacho as he didnt have the one you have (and i wanted) and i couldnt be fucked waiting for him to get them in lol Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted November 23, 2009 Share Posted November 23, 2009 Sweet cheers man will post pics in a second ... they look choice side by side! I'm probably being doy but it doesn't seem to state clearly that you can do it. Dont wont to break them they are to expensive But seems like you can. Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted November 23, 2009 Share Posted November 23, 2009 those fit sweet a!! wish i couldget my factory revcounter to work with the link lol Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted November 23, 2009 Share Posted November 23, 2009 Like a glove! absolutely perfect fit, and they are variable for adjustment. and they are only like 50 odd mm deep so you can even put the housing all back together to protect them etc. Happy as ... just have no idea of how to make them go Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted November 23, 2009 Author Share Posted November 23, 2009 they are pretty easy to work just conect all the wires and i left the dash unscrewed and went for a drive with a gps system just stoped every now and then to fine tune them. i also got my van up to 235 kph would do more but it didnt feel very stable lol Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted November 23, 2009 Share Posted November 23, 2009 Wow really! scarry! my escort feels dodgy at 160 with bump steer etc. The guy who originally tuned my settup and is an authorised seller of link computers said; "That speedo will need a aftermarket ecu like a g3 minimum to work they wont work directly off a electronic speed sensor it needs a interface a g3 or g4 can do this" eeek what alternatives do i have? How did you get yours to run d.p.n.s Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted November 23, 2009 Author Share Posted November 23, 2009 took me a while to get mine set up i had to make sure that all wires from the speed sensor and ecu were hooked up. i just followed the wiring diagram for my motor and put the speedo in where i thought it should go and after fucking with some wires while i had the rear on axle stands and the motor running with it in gear i got a signal and just went from there.. probly easyer to take to a auto elec lol dan Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted November 23, 2009 Share Posted November 23, 2009 Oh ok ... this guy is saying my ECU doesnt have the correct output for it i think? eek the G3's and G4's are super duper expensive! Quote Link to comment Share on other sites More sharing options...
