cletus Posted September 30, 2012 Share Posted September 30, 2012 Sticker here, which is why i thought i could get away with it as its before the bend if it was me id just cut them off before the bend Quote Link to comment Share on other sites More sharing options...
cletus Posted September 30, 2012 Share Posted September 30, 2012 I've had to cut a section out of the stock crossmember to clear the front of the engine I'm swapping in. The crossmember no longer is used to support the engine. I was going to box this up with 3mm plate is that legit? yep thats probably fine The original steel is around 1.5mm thick. Stitch weld or continuous?continuous Also what dimensions should I make the trans mount plates I weld to the floor? Stitch weld sweet? if you are going to bolt the x member straight to the floor, id make it 100mm wide, and along the flat part of the floor and up the side of the tunnel, on the top side of the floor, then stitch weld it in. needs to be solid enough that the floor doesnt flex -and end up cracking Thanks cletus; legend. Quote Link to comment Share on other sites More sharing options...
TTONEFOURTWO Posted September 30, 2012 Share Posted September 30, 2012 Sweet az, Im currently running S13 coilovers and s14 hubs/brakes on the factory crossmember & lca's with no problems, just thought it might be easier to bolt in the crossmember my new motor came with but if I have to drill & weld crush tubes in the chassis it will probably be easier just to change the mounts. Thanks Quote Link to comment Share on other sites More sharing options...
cletus Posted September 30, 2012 Share Posted September 30, 2012 FYI,last toyota i looked at (gx61 corona) had very bad amounts of bumpsteer when fitted with silvia spindles. they bolt on, but steering arm pivot points are quite different Quote Link to comment Share on other sites More sharing options...
J2Racing Posted September 30, 2012 Share Posted September 30, 2012 My wifes car has been certified for a motor swap but the registration has not been change . Is this legalize where do we stand with insurance? Quote Link to comment Share on other sites More sharing options...
pusherman Posted October 1, 2012 Share Posted October 1, 2012 any old school freindly cert chaps that would be kind enough to have a pre cert look over and tell me what too do to my escort. i do want to be legaldegal for the summer Quote Link to comment Share on other sites More sharing options...
mikey Posted October 3, 2012 Share Posted October 3, 2012 What dimensions should I make trans mount plates I weld to the floor? if you are going to bolt the x member straight to the floor, id make it 100mm wide, and along the flat part of the floor and up the side of the tunnel, on the top side of the floor, then stitch weld it in So would 100mm x 100mm x 5mm be reasonable sized plate to spread the load? Quote Link to comment Share on other sites More sharing options...
Horse25 Posted October 3, 2012 Share Posted October 3, 2012 What's the story with noisy exhaust tests? i know the ratings but at what RPM is that taken at? does any know how the test is conducted? (preferably motorbike) I found a good explanation for the aussie one but not the nz. Quote Link to comment Share on other sites More sharing options...
morkster Posted October 3, 2012 Share Posted October 3, 2012 What's the story with noisy exhaust tests? i know the ratings but at what RPM is that taken at? does any know how the test is conducted? (preferably motorbike)I found a good explanation for the aussie one but not the nz. Here you are: http://www.lvvta.org.nz/documents/stand ... ssions.pdf Motorcycle engines at 2.6(2); Page 10. Quote Link to comment Share on other sites More sharing options...
cletus Posted October 3, 2012 Share Posted October 3, 2012 My wifes car has been certified for a motor swap but the registration has not been change . Is this legalize where do we stand with insurance? there should be a form available at your local testing station/post office, MR16. fill it out and send away to get details updated Quote Link to comment Share on other sites More sharing options...
cletus Posted October 3, 2012 Share Posted October 3, 2012 What dimensions should I make trans mount plates I weld to the floor? if you are going to bolt the x member straight to the floor, id make it 100mm wide, and along the flat part of the floor and up the side of the tunnel, on the top side of the floor, then stitch weld it in So would 100mm x 100mm x 5mm be reasonable sized plate to spread the load? depends. if its in the middle of a flat bit of floor, possibly not. if the plate overlaps a crossmember or goes up the side of the tunnel, then it might be fine. hard to tell without seeing it Quote Link to comment Share on other sites More sharing options...
OSM Garage Posted October 3, 2012 Share Posted October 3, 2012 My cousin has almost completed an engine swap in his VK commodore. He has put a 5L (originally a 202) in using factory parts. It has a 2 piece driveshaft and he had to cut a hole in the bonnet. I read somewhere that 2 piece driveshafts need 2 driveshaft hoops - Is this correct? Are there rules around holes in bonnets? Quote Link to comment Share on other sites More sharing options...
Dell'orto Posted October 3, 2012 Share Posted October 3, 2012 I want to run a rear swaybar on my KE70, they don't have them factory but the holes in the chassis rail are there...I assume the AE86 has a captive nut on the inside of the rail to bolt to. Can I drill through the rail, use a crush tube and bolt right through the chassis rail, or would I be better off to make a plate with captive nuts to sit inside the chassis rail? Quote Link to comment Share on other sites More sharing options...
cletus Posted October 3, 2012 Share Posted October 3, 2012 I want to run a rear swaybar on my KE70, they don't have them factory but the holes in the chassis rail are there...I assume the AE86 has a captive nut on the inside of the rail to bolt to. Can I drill through the rail, use a crush tube and bolt right through the chassis rail, or would I be better off to make a plate with captive nuts to sit inside the chassis rail? either way would be fine. Quote Link to comment Share on other sites More sharing options...
Dell'orto Posted October 3, 2012 Share Posted October 3, 2012 Cool, crush tube way might be easier! Thanks Quote Link to comment Share on other sites More sharing options...
cletus Posted October 3, 2012 Share Posted October 3, 2012 My cousin has almost completed an engine swap in his VK commodore.He has put a 5L (originally a 202) in using factory parts. It has a 2 piece driveshaft and he had to cut a hole in the bonnet. I read somewhere that 2 piece driveshafts need 2 driveshaft hoops - Is this correct? Are there rules around holes in bonnets? yep 2 loops for 2 piece shafts. holes in bonnet- there are restrictions on how far a scoop etc can stick out the bonnet, also it cant have any sharp edges that could harm pedestrians that are too busy on thier i-thing to notice a car. http://lvvta.org.nz/documents/standards ... ctions.pdf Quote Link to comment Share on other sites More sharing options...
Llama Posted October 3, 2012 Share Posted October 3, 2012 Or just pinch a pedestrian airbag from those swish new volvos Quote Link to comment Share on other sites More sharing options...
brad Posted October 3, 2012 Share Posted October 3, 2012 wanting to create a new exhaust & tip but i've heard rumors that your exhaust isn't allowed to extend further than your bumper? True? if not how far is it allowed to protrude past? (currently pink stickered so i'l have to go through vtnz with it) cheers, oh also just curious about height restrictions as well if it IS allowed? ta. Quote Link to comment Share on other sites More sharing options...
HighLUX Posted October 9, 2012 Share Posted October 9, 2012 Whats the go with getting a green sticker removed? Does it have to be done by VTNZ or can my usual warrant man do it? Quote Link to comment Share on other sites More sharing options...
SHGWAG Posted October 9, 2012 Share Posted October 9, 2012 ^^VTNZ IIRC Quote Link to comment Share on other sites More sharing options...
