cletus Posted April 21, 2021 Posted April 21, 2021 Unfortunately once you have been stickered for exhaust noise, you need an exhaust noise cert regardless of if you put a standard exhaust back on 1 1 2 Quote
CUL8R Posted April 21, 2021 Posted April 21, 2021 Thanks Clint, They would be SFI rated if that makes a difference - but like you say, says they need to be used as a set so no dice unfortunately. Quote
Hemi Posted April 22, 2021 Posted April 22, 2021 Hey @cletus / @KKtrips is this something that can be certed? for some reason i thodught onotching has to be welded, or it the other way around? Quote
Nominal Posted April 22, 2021 Posted April 22, 2021 I don't really get the point in bolting in something like that. You have to cut the chassis apart anyway, so it can hardly be put back to stock. Quote
tortron Posted April 22, 2021 Posted April 22, 2021 I always assumed they used factory hole positions to align it, then leave the bolts in cos american fabricators cant be trusted to weld Quote
cletus Posted April 22, 2021 Posted April 22, 2021 8 hours ago, Hemi said: Hey @cletus / @KKtrips is this something that can be certed? for some reason i thodught onotching has to be welded, or it the other way around? Hide contents Most of the time that sort of thing has to be welded. You might be able to get an exemption from lvvta if you followed the right process but it might be more hassle than its worth. You would probably need to modify parts of it anyway for it to comply so may as well just weld it in Like tortron said its probably to do with the skill level of the installer in its home market, like many other things, the fact that something bolts in/on in america is a big selling point 2 Quote
cletus Posted April 22, 2021 Posted April 22, 2021 iT b0lTs oN sO iTs gOOd It A kIT I bRoUgT fRoM aMuurica 2 5 2 Quote
datlow Posted April 22, 2021 Posted April 22, 2021 To be fair who doesn’t like a nice set of bolt on’s 2 Quote
KKtrips Posted April 23, 2021 Posted April 23, 2021 2 hours ago, cletus said: iT b0lTs oN sO iTs gOOd It A kIT I bRoUgT fRoM aMuurica I died a little / a LOT on the inside. 1 Quote
KKtrips Posted April 23, 2021 Posted April 23, 2021 11 hours ago, Hemi said: Hey @cletus / @KKtrips is this something that can be certed? for some reason i thodught onotching has to be welded, or it the other way around? Hide contents Looks like a serious bit of kit and would probably be overkill for anything other than an uber mega slam. IMHO bolt on = fuck off. Be like Mike and weld it in. Quote
ajg193 Posted April 23, 2021 Posted April 23, 2021 Just like steering bits, only weld them. Never bolt them. 3 2 Quote
chasinthemirage Posted April 28, 2021 Posted April 28, 2021 Zephyr should be getting painted soon, I want to remove the ID tag before it gets painted as I think it will look better than masking it off. Its secured with four pop rivets, am I all good removing it or will I run into issues come time to get it another WOF? Quote
cletus Posted April 28, 2021 Posted April 28, 2021 Correct procedure is to take it to a vtnz or vinz that deals with re registering cars, tell them what you are doing, they will remove the tag, and store it while it's being painted then refit when it's done. 1 1 Quote
xsspeed Posted April 28, 2021 Posted April 28, 2021 can they be trusted to find it when the time comes? 4 Quote
chasinthemirage Posted April 28, 2021 Posted April 28, 2021 Do they use special rivets or anything? Just curious as to whether anyone would be able to tell whether they'd removed it or not. Quote
Bling Posted April 28, 2021 Posted April 28, 2021 Just get good at masking and save the hassle I masked mine up and it came up fine, just spent my time making sure the tape was perfect, and also thin stuff. 2 Quote
cletus Posted April 28, 2021 Posted April 28, 2021 59 minutes ago, xsspeed said: can they be trusted to find it when the time comes? Its risky if you ask me. A 2 year rebuild on a car could mean a bunch of different employees come and go, things go missing, inspection sites lose their authority and throw everything away, etc I find, in practice, nobody knows about this requirement, removes tags for paint, then come in for cert with them re attached with new rivets and new engine bay paint Then we have to send them to vinz or vtnz to confirm that the id tag matches the car . Sometimes they return with a letter from the TSDA saying yep its sweet, some come back with a new 17 digit vin number attached 21 minutes ago, chasinthemirage said: Do they use special rivets or anything? Just curious as to whether anyone would be able to tell whether they'd removed it or not. No special rivets, it's pretty obvious when the tag has been removed for paint and refitted Quote
chasinthemirage Posted April 28, 2021 Posted April 28, 2021 Hmm yeah might just mask it up tbh. With the glacial pace of progress on the car I'd rather not have an irreplaceable part at VTNZ for however long. Just as long as there's nothing under it contamination wise that will affect the new paint. I feel like if I just removed it and went for a wof with it reattached its one of those things that could go either way tbh. Quote
cletus Posted April 28, 2021 Posted April 28, 2021 1 minute ago, chasinthemirage said: I feel like if I just removed it and went for a wof with it reattached its one of those things that could go either way tbh. 95% of the time it will never get picked up. Lvv certifiers have been told to look for it specifically, it's in the wof virm but I'd say most wof inspectors wouldn't fail until theres a training update and then there will be a million cars that fail all of a sudden I got a bollocking from someone at NZTA once for looking at a vehicle that didnt have a vin number on it because it had been removed and lost when it was painted, Not even a proper cert inspection, it was a pre check Quote
cletus Posted April 28, 2021 Posted April 28, 2021 Relevant VIRM page for anyone interested https://vehicleinspection.nzta.govt.nz/virms/in-service-wof-and-cof/general/vehicle-identification/vin-and-chassis-number 1 1 Quote
