Mint found it now. Turns out the phone if been running for the last 2 years has a junk folder hidden away, all this time I have been checking the spam folder, 2 different things apparently
  • Replies 9.6k
Hey guys, sorry if this has been asked.
Just had my starlet fail a WoF for the RCAs under the struts, which have been fitted for 5 or so years. They're Techno Toy Tuning. Anyone had any experience with this? Am I able to get something from a cert guy without paying mega bucks?
I found this:Pdf
I'm currently removing them to go for a recheck.
Cheers
Is it absolutely 100% mandatory to get the welding on my front struts crack tested for cert? It's ages away from any cast parts, and was welded by a skilled fabricator (i.e. not by me).
Depends what bit you have welded.
If you have just welded a threaded part on for an adjustable platform- no
If you have welded a new tube on - yes
If you welded on an adjustable platform and shortened the shock- yes
NZ road code
  • A motor vehicle must not be parked on the road during the hours of darkness unless it is clearly visible to other road users. This means it should be lit by street lights, or you should turn on the tail lights and the side light nearest the centre of the road on the front of the vehicle.
  • A light, flat-decked vehicle that is parked on the street at night must display a rear red light that:
    • is on the side of the vehicle closest to the centre of the road
    • is visible at a distance of 100 metres.
14 minutes ago, tortron said:
Literally never seen anyone use park lights as park lights tho
which is annoying because it is required per WOF. what's the point eh. or what's the point of having reflectors.
i see trucks and that have offside tail light on - do they have different rules?
4 minutes ago, RUNAMUCK said:
What's the going rate for.a revin inspection?
Ive revinned an au falcon and l300 mitsi this year
$400 for the inspection and then to get the plates had to pay $234 and that includes 6 months rego
If you are going to sell it you can just do the revin and its issued its wof and then get the plates/register it when someone buys it
$400.isnt too bad.
I got given a free car last weekend. I reckon for a $300 outlay it would pass a revin. And then be worth $1500-$2k
Apart from being filthy as fuck (I'm going to burn the seats) it's great in the body.
Check with your local revin place as prices vary, I get mine done at the AA in napier as the guy is pretty lax and does them for $400 (normally $450) and vtnz charge $579 and are cunts
