KKtrips Posted September 20, 2013 Share Posted September 20, 2013 http://www.lvvta.org.nz/documents/infosheets/LVVTA_Info_01-2011_'Supreme'-_brand_aftermarket_wheels.pdf Cut and paste this link into your header Quote Link to comment Share on other sites More sharing options...
Nominal Posted September 20, 2013 Share Posted September 20, 2013 Here's a pic of the back of one my 'Astros'. I don't run them anymore. Quote Link to comment Share on other sites More sharing options...
cletus Posted September 20, 2013 Share Posted September 20, 2013 Are bump steer correction kits like this (see below) certable? I think mikuni asked about this kind of thing some time ago (or maybe that was balljoints?) but I haven't been able to find what the resolution was id have to look back thru some of our training notes, im pretty sure adjustable ones were not ok, that might have been the ones with a thread to do the adjusting. there was some talk of extra long adjustable ones causing issues with trying to twist the steering arm also. if it was allowed, and some would be, (you can buy balljoints and tierod ends that have revised pivot points for some cars) you would need a 1D certifier to do a bump steer check as part of the cert to make sure it does actually improve the bumpsteer and not make it worse Quote Link to comment Share on other sites More sharing options...
cletus Posted September 20, 2013 Share Posted September 20, 2013 those astro copies are no good as mentioned. cragar do one that is ok. the funny thing about cragars is the construction method sounds even more hori than those^ they have a aluminium center with steel inserts cast into them, which are then welded to the steel outer rim Quote Link to comment Share on other sites More sharing options...
escortwags Posted September 20, 2013 Share Posted September 20, 2013 Cheers guys Yet another reason why knock off versions of the original wheels are shit I guess These were the wheels in question by the sounds of it they ain't no good http://www.trademe.co.nz/639996938 Quote Link to comment Share on other sites More sharing options...
Snoozin Posted September 20, 2013 Share Posted September 20, 2013 Wooo factory slotted and everything too! Quote Link to comment Share on other sites More sharing options...
escortwags Posted September 20, 2013 Share Posted September 20, 2013 GAAAAH can someone give me a link to these god dam supremes they will be legal in NZ????All I can find are the welded ones not the cast version! Quote Link to comment Share on other sites More sharing options...
cletus Posted September 20, 2013 Share Posted September 20, 2013 http://www.cragarwheel.com/products16-38/CragarSeries377Supreme http://www.summitracing.com/search/product-line/cragar-377-series-supreme-chrome-wheels?tw=cragar%20377&sw=Cragar%20377%20Series%20Supreme%20Chrome%20Wheels bg marketing is a cragar dealer, they dont have these on their website but they might be able to get them for you http://www.bgworldwheels.co.nz/bghome.asp Quote Link to comment Share on other sites More sharing options...
escortwags Posted September 20, 2013 Share Posted September 20, 2013 Cheers dude Time is of the essence so will see how I go. I do know old BG have the standard 2 month wait which is not ideal Quote Link to comment Share on other sites More sharing options...
Nominal Posted September 21, 2013 Share Posted September 21, 2013 It's a pity really, that the regular versions are dodgy, as they look really sweet! Another option is these Radir's - one piece aluminium so not problems there. I'd have a set if I had the bux. Quote Link to comment Share on other sites More sharing options...
MRWEST Posted September 22, 2013 Share Posted September 22, 2013 only dum thing is the crager ones only come in 15s ....i want some for mine 2 as well as the wires but again want "legit" ones that aint going to fly to bits on me. Quote Link to comment Share on other sites More sharing options...
Mitch.W Posted September 25, 2013 Share Posted September 25, 2013 hey clint, just looking into making my own adjustable pan hard rod. just wanting to know if its legal to make one out of a solid bar of steel/something very thick walled and tap a thread in each end and use some big rosejoints on each end to adjust it and hold it up? if that makes any sense? Quote Link to comment Share on other sites More sharing options...
MRWEST Posted September 29, 2013 Share Posted September 29, 2013 Would there be any issue with putting a shim or a spacer between chassis xmember and engine mounting plate to space the engine up say a inch or so? Quote Link to comment Share on other sites More sharing options...
cletus Posted September 29, 2013 Share Posted September 29, 2013 hey clint, just looking into making my own adjustable pan hard rod. just wanting to know if its legal to make one out of a solid bar of steel/something very thick walled and tap a thread in each end and use some big rosejoints on each end to adjust it and hold it up? if that makes any sense? yep that would be fine, use teflon or kevlar lined joints (ie good quality ones) and you will be fine Quote Link to comment Share on other sites More sharing options...
cletus Posted September 29, 2013 Share Posted September 29, 2013 Would there be any issue with putting a shim or a spacer between chassis xmember and engine mounting plate to space the engine up say a inch or so? as long as the bolts on te mount are long enough,engine mount rubbers dont get twisted/stressed and the angle of the driveshaft etc doesnt get silly, then no problem 1 Quote Link to comment Share on other sites More sharing options...
Benno Posted September 29, 2013 Share Posted September 29, 2013 I am planning on shortening the frame slightly on my KZ440, then welding in a new rear loop very similar to that pictured below. Is this likely to cause issues at WOF time? Are there any requirements or specifications I need to adhere to? Cheers Quote Link to comment Share on other sites More sharing options...
MRWEST Posted September 29, 2013 Share Posted September 29, 2013 as long as the bolts on te mount are long enough,engine mount rubbers dont get twisted/stressed and the angle of the driveshaft etc doesnt get silly, then no problem just the answer i wanted....will buy new sump and see how i go! Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted September 29, 2013 Share Posted September 29, 2013 I'm not sure if I've asked this before or not, but how legit (or not) is it to machine some material off the hub mating face on the back of a mag wheel to gain a bit more tyre clearance on the wheel arch lip? Quote Link to comment Share on other sites More sharing options...
brocky41 Posted September 29, 2013 Share Posted September 29, 2013 Hi guys, Dereged car with cert - is cert still valid if re vinning and no more mods are done etc Quote Link to comment Share on other sites More sharing options...
Rookie Posted September 29, 2013 Share Posted September 29, 2013 Nope. 1 Quote Link to comment Share on other sites More sharing options...
