WhangareiKE70 Posted May 27, 2021 Share Posted May 27, 2021 @cletus so for something like this, where the bottom unshielded part is un-contactable, but the top section is exposed, is that acceptable? Obviously with a stack style exhaust there will be a section which is exposed, but is it about limiting that? Quote Link to comment Share on other sites More sharing options...
Shakotom Posted May 27, 2021 Share Posted May 27, 2021 Flapper on the top is mandatory too thanks 6 1 Quote Link to comment Share on other sites More sharing options...
cletus Posted May 27, 2021 Share Posted May 27, 2021 21 minutes ago, WhangareiKE70 said: @cletus so for something like this, where the bottom unshielded part is un-contactable, but the top section is exposed, is that acceptable? Obviously with a stack style exhaust there will be a section which is exposed, but is it about limiting that? That's probably something that will depend on a few things Think of it this way if it's easily contactable ie someone getting in or out of the vehicle or leaning against it could burn themselves then it needs heat shielding. If its 8 feet in the air and you need a ladder to burn yourself then you wont need to worry 1 Quote Link to comment Share on other sites More sharing options...
WhangareiKE70 Posted May 27, 2021 Share Posted May 27, 2021 Perfect, that makes sense to me. Happy days. I shall continue on my merry bogan way, flapper and all. 6 Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted May 28, 2021 Share Posted May 28, 2021 A chick I know has a supercharged CA18det in a 620 flat deck with truck style pipe up the back of the cab. It has that perforated stainless steel shroud around it. Its fucking cool too. Also runs stupidly rich, (something is waaay off with the tune, runs like 10.2:1 afrs) so it blows black like a boss. 1 Quote Link to comment Share on other sites More sharing options...
cletus Posted May 29, 2021 Share Posted May 29, 2021 2 hours ago, RUNAMUCK said: A chick I know has a supercharged CA18det in a 620 flat deck Sounds like the perfect woman for you 2 1 Quote Link to comment Share on other sites More sharing options...
kws Posted June 5, 2021 Share Posted June 5, 2021 If my front fog lamp has a crack in the lens, but doesnt let moisture in, can it pass a WOF or is it an instant fail? Could I use clearcoat on the plastic lens to prove its "sealed"? The VIRM is quite clear on letting moisture in, but not for the crack its self - 6. A lens is missing, or has a hole, crack or other damage that allows moisture or dirt to enter. Quote Link to comment Share on other sites More sharing options...
MightyJoe Posted June 5, 2021 Share Posted June 5, 2021 27 minutes ago, kws said: If my front fog lamp has a crack in the lens, but doesnt let moisture in, can it pass a WOF or is it an instant fail? Could I use clearcoat on the plastic lens to prove its "sealed"? The VIRM is quite clear on letting moisture in, but not for the crack its self - 6. A lens is missing, or has a hole, crack or other damage that allows moisture or dirt to enter. this is prob not a helpful answer, but we've put trucks through multiple times with glad wrap over the lenses covering stone chips. eventually they've been replaced but at the time, the beam pattern was correct and the lens wasnt corroded etc. 3 Quote Link to comment Share on other sites More sharing options...
AllTorque Posted June 5, 2021 Share Posted June 5, 2021 Yes it is ok to seal over the crack. As long as it doesn’t effect the pattern. 1 Quote Link to comment Share on other sites More sharing options...
Bearded Baldy Posted June 6, 2021 Share Posted June 6, 2021 Lightskins are good for that situation. Can/used to be buy from repco. Basically a heavy selfadhesive vinyl. Quote Link to comment Share on other sites More sharing options...
zep Posted June 15, 2021 Share Posted June 15, 2021 For my daily - how can I determine if a strut spacer lift kit will be certable? I'm looking at this one which seems to be well designed and includes subframe spacers to ensure the alignment is not wrecked, as well as adapters for the longer brake hoses, etc. https://lpaventure.com/collections/outback-2010-2013/products/lp-aventure-2-lift-kit-2010-2013-outback The installation PDF in there has heaps of install pics. Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted June 18, 2021 Share Posted June 18, 2021 Todays stupid question, The new cert tag thingies. Does the constabulary scan them, then get a link to a database to read the info? What happens if you encounter the five-0 in a location where theres no mobile reception? (OOODLES of places like that) what then? Pink sticker first, and ask questions later? Quote Link to comment Share on other sites More sharing options...
Nominal Posted June 18, 2021 Share Posted June 18, 2021 Depends on the cop, probably. Anyone can scan them and get a (temporary) link to the deets and photos if you can get your phone close enough to the tag. Quote Link to comment Share on other sites More sharing options...
linearentropy Posted June 19, 2021 Share Posted June 19, 2021 On 18/06/2021 at 13:44, RUNAMUCK said: What happens if you encounter the five-0 in a location where theres no mobile reception? (OOODLES of places like that) what then? Its a valid question. You can get the details up with just the number on the tag and the vin. If they have cell but not internet I imagine they could call and get someone at their home station to look. Whether or not they'd bother is up in the air. I think I'll save the details page as a pdf on my phone for if this situation arises and hope for the best. 2 Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted June 19, 2021 Share Posted June 19, 2021 Especially a car that was mega slammed. This car is too low, im gonna sticker it. But it has cert. *no cell coverage. It's too low, I'm a cop, I know these things. (Like Ian the cop who knew about screamer pipes) it's too low. Have a nice pink sticker........... Quote Link to comment Share on other sites More sharing options...
Bling Posted June 19, 2021 Share Posted June 19, 2021 Mega slammed and certed? Most likely modified since cert lol. Unless it's on bags. Plenty of details aren't on the old cert plates, not a new situation really. Quote Link to comment Share on other sites More sharing options...
cletus Posted June 19, 2021 Share Posted June 19, 2021 On 16/06/2021 at 09:12, zep said: For my daily - how can I determine if a strut spacer lift kit will be certable? I'm looking at this one which seems to be well designed and includes subframe spacers to ensure the alignment is not wrecked, as well as adapters for the longer brake hoses, etc. https://lpaventure.com/collections/outback-2010-2013/products/lp-aventure-2-lift-kit-2010-2013-outback The installation PDF in there has heaps of install pics. Pretty hard to know until you fit it really. I've done 3 or 4 of those kits in Subaru's and all have had problems, mostly with the sway bars hitting the steering or binding at extremes of suspension travel Quote Link to comment Share on other sites More sharing options...
cletus Posted June 19, 2021 Share Posted June 19, 2021 2 hours ago, linearentropy said: I think I'll save the details page as a pdf on my phone for if this situation arises and hope for the best. This or print it out and keep a copy in the glovebox is a good idea to solve the no internet problem 5 Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted June 19, 2021 Share Posted June 19, 2021 14 hours ago, Bling said: Mega slammed and certed? Most likely modified since cert lol. Unless it's on bags. Plenty of details aren't on the old cert plates, not a new situation really. It only takes a cop who thinks they know more than they do to decide your car is too low. I once had a cop try and peer into my wheel arch to check my springs were captive.......... Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted June 20, 2021 Share Posted June 20, 2021 On 18/06/2021 at 13:44, RUNAMUCK said: Todays stupid question, The new cert tag thingies. Does the constabulary scan them, then get a link to a database to read the info? What happens if you encounter the five-0 in a location where theres no mobile reception? (OOODLES of places like that) what then? Pink sticker first, and ask questions later? I'd say it'll be attitude based, like most dealings with cops regarding vehicles. If there's not coverage they can't really sticker you. They'll follow ypu to somewhere that has reception 1 1 Quote Link to comment Share on other sites More sharing options...
